--- ray/src/util/dctimestep.c 2011/04/11 03:47:46 2.16 +++ ray/src/util/dctimestep.c 2012/08/07 18:17:17 2.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.16 2011/04/11 03:47:46 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.20 2012/08/07 18:17:17 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -252,8 +252,29 @@ not_handled: return(NULL); /* gratis return */ } -/* Multiply two matrices (or a matrix and a vector) and allocate the result*/ +/* Scale a matrix by a single value */ static CMATRIX * +cm_scale(const CMATRIX *cm1, const COLOR sca) +{ + CMATRIX *cmr; + int dr, dc; + + cmr = cm_alloc(cm1->nrows, cm1->ncols); + if (cmr == NULL) + return(NULL); + for (dr = 0; dr < cmr->nrows; dr++) + for (dc = 0; dc < cmr->ncols; dc++) { + const COLORV *sp = cm_lval(cm1,dr,dc); + COLORV *dp = cm_lval(cmr,dr,dc); + dp[0] = sp[0] * sca[0]; + dp[1] = sp[1] * sca[1]; + dp[2] = sp[2] * sca[2]; + } + return(cmr); +} + +/* Multiply two matrices (or a matrix and a vector) and allocate the result */ +static CMATRIX * cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) { CMATRIX *cmr; @@ -300,13 +321,11 @@ cm_bsdf(const COLOR bsdfLamb, const COLOR specCol, con CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc); int nbadohm = 0; int nneg = 0; - float dom; - int doforward; int r, c; /* reciprocity is "transparent" */ for (c = 0; c < cm->ncols; c++) { - /* get projected solid angle */ - dom = mBSDF_incohm(bsdf,c); + const double dom = mBSDF_incohm(bsdf,c); + /* projected solid angle */ nbadohm += (dom <= 0); for (r = 0; r < cm->nrows; r++) { @@ -334,7 +353,7 @@ cm_bsdf(const COLOR bsdfLamb, const COLOR specCol, con /* Load and convert a matrix BSDF from the given XML file */ static CMATRIX * -cm_loadBSDF(char *fname) +cm_loadBSDF(char *fname, COLOR cLamb) { CMATRIX *Tmat; char *fpath; @@ -351,15 +370,22 @@ cm_loadBSDF(char *fname) ec = SDloadFile(&myBSDF, fpath); if (ec) error(USER, transSDError(ec)); - if (myBSDF.tf == NULL || myBSDF.tf->ncomp != 1 || - myBSDF.tf->comp[0].func != &SDhandleMtx) { + ccy2rgb(&myBSDF.tLamb.spec, myBSDF.tLamb.cieY/PI, bsdfLamb); + if (myBSDF.tf == NULL) { /* no non-Lambertian transmission? */ + if (cLamb != NULL) + copycolor(cLamb, bsdfLamb); + SDfreeBSDF(&myBSDF); + return(NULL); + } + if (myBSDF.tf->ncomp != 1 || myBSDF.tf->comp[0].func != &SDhandleMtx) { sprintf(errmsg, "unsupported BSDF '%s'", fpath); error(USER, errmsg); } /* convert BTDF to matrix */ - ccy2rgb(&myBSDF.tLamb.spec, myBSDF.tLamb.cieY/PI, bsdfLamb); ccy2rgb(&myBSDF.tf->comp[0].cspec[0], 1., specCol); Tmat = cm_bsdf(bsdfLamb, specCol, (SDMat *)myBSDF.tf->comp[0].dist); + if (cLamb != NULL) /* Lambertian is included */ + setcolor(cLamb, .0, .0, .0); /* free BSDF and return */ SDfreeBSDF(&myBSDF); return(Tmat); @@ -384,7 +410,8 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE int dt, xr, yr; COLORV *psp; /* check for zero */ - if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0)) + if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) && + (myDT != DTfromHeader) | (i < cv->nrows-1)) continue; /* open next picture */ sprintf(fname, fspec, i); @@ -446,22 +473,28 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE static int hasNumberFormat(const char *s) { - while (*s && *s != '%') - s++; - if (!*s) - return(0); - do - ++s; - while (isdigit(*s)); - - return((*s == 'd') | (*s == 'i') | (*s == 'o') | - (*s == 'x') | (*s == 'X')); + while (*s) { + while (*s != '%') + if (!*s++) + return(0); + if (*++s == '%') { /* ignore "%%" */ + ++s; + continue; + } + while (isdigit(*s)) /* field length */ + ++s; + /* field we'll use? */ + if ((*s == 'd') | (*s == 'i') | (*s == 'o') | + (*s == 'x') | (*s == 'X')) + return(1); + } + return(0); /* didn't find one */ } int main(int argc, char *argv[]) { - CMATRIX *cvec; + CMATRIX *cvec; /* component vector result */ progname = argv[0]; @@ -474,17 +507,24 @@ main(int argc, char *argv[]) if (argc > 3) { /* VTDs expression */ CMATRIX *svec, *Dmat, *Tmat, *ivec; + COLOR tLamb; /* get sky vector */ svec = cm_load(argv[4], 0, 1, DTascii); /* load BSDF */ - Tmat = cm_loadBSDF(argv[2]); + Tmat = cm_loadBSDF(argv[2], tLamb); /* load Daylight matrix */ - Dmat = cm_load(argv[3], Tmat->ncols, svec->nrows, DTfromHeader); + Dmat = cm_load(argv[3], Tmat==NULL ? 0 : Tmat->ncols, + svec->nrows, DTfromHeader); /* multiply vector through */ ivec = cm_multiply(Dmat, svec); cm_free(Dmat); cm_free(svec); - cvec = cm_multiply(Tmat, ivec); /* cvec = component vector */ - cm_free(Tmat); cm_free(ivec); + if (Tmat == NULL) { /* diffuse only */ + cvec = cm_scale(ivec, tLamb); + } else { /* else apply BTDF matrix */ + cvec = cm_multiply(Tmat, ivec); + cm_free(Tmat); + } + cm_free(ivec); } else { /* else just use sky vector */ cvec = cm_load(argv[2], 0, 1, DTascii); }
