root/radiance/ray/src/util/dctimestep.c
Revision: 2.38
Committed: Tue Apr 10 23:22:42 2018 UTC (6 years, 2 months ago) by greg
Changes since 2.37: +10 -6 lines
Improved speed on zero-valued pixels in summation
2 static const char RCSid[] = "$Id: dctimestep.c,v 2.37 2016/03/06 01:13:18 schorsch Exp $";
5 * Compute time-step result using Daylight Coefficient method.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "resolu.h"
16
17 char *progname; /* global argv[0] */
18
19 /* Sum together a set of images and write result to fout */
20 static int
21 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
22 {
23 int myDT = DTfromHeader;
24 COLR *scanline = NULL;
25 CMATRIX *pmat = NULL;
26 int myXR=0, myYR=0;
27 int i, y;
28
29 if (cv->ncols != 1)
30 error(INTERNAL, "expected vector in sum_images()");
31 for (i = 0; i < cv->nrows; i++) {
32 const COLORV *scv = cv_lval(cv,i);
33 char fname[1024];
34 FILE *fp;
35 int dt, xr, yr;
36 COLORV *psp;
37 char *err;
38 /* check for zero */
39 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
40 (myDT != DTfromHeader) | (i < cv->nrows-1))
41 continue;
42 /* open next picture */
43 sprintf(fname, fspec, i);
44 if ((fp = fopen(fname, "rb")) == NULL) {
45 sprintf(errmsg, "cannot open picture '%s'", fname);
46 error(SYSTEM, errmsg);
47 }
48 dt = DTfromHeader;
49 if ((err = cm_getheader(&dt, NULL, NULL, fp)) != NULL)
50 error(USER, err);
51 if ((dt != DTrgbe) & (dt != DTxyze) ||
52 !fscnresolu(&xr, &yr, fp)) {
53 sprintf(errmsg, "file '%s' not a picture", fname);
54 error(USER, errmsg);
55 }
56 if (myDT == DTfromHeader) { /* on first one */
57 myDT = dt;
58 myXR = xr; myYR = yr;
59 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
60 if (scanline == NULL)
61 error(SYSTEM, "out of memory in sum_images()");
62 pmat = cm_alloc(myYR, myXR);
63 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
64 /* finish header */
65 fputformat((char *)cm_fmt_id[myDT], fout);
66 fputc('\n', fout);
67 fflush(fout);
68 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
69 sprintf(errmsg, "picture '%s' format/size mismatch",
70 fname);
71 error(USER, errmsg);
72 }
73 psp = pmat->cmem;
74 for (y = 0; y < yr; y++) { /* read it in */
75 COLOR col;
76 int x;
77 if (freadcolrs(scanline, xr, fp) < 0) {
78 sprintf(errmsg, "error reading picture '%s'",
79 fname);
80 error(SYSTEM, errmsg);
81 }
82 /* sum in scanline */
83 for (x = 0; x < xr; x++, psp += 3) {
84 if (!scanline[x][EXP])
85 continue; /* skip zeroes */
86 colr_color(col, scanline[x]);
87 multcolor(col, scv);
88 addcolor(psp, col);
89 }
90 }
91 fclose(fp); /* done this picture */
92 }
93 free(scanline);
94 i = cm_write(pmat, myDT, fout); /* write picture */
95 cm_free(pmat); /* free data */
96 return(i);
97 }
98
99 /* check to see if a string contains a %d or %o specification */
100 static int
101 hasNumberFormat(const char *s)
102 {
103 if (s == NULL)
104 return(0);
105
106 while (*s) {
107 while (*s != '%')
108 if (!*s++)
109 return(0);
110 if (*++s == '%') { /* ignore "%%" */
111 ++s;
112 continue;
113 }
114 while (isdigit(*s)) /* field length */
115 ++s;
116 /* field we'll use? */
117 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
118 (*s == 'x') | (*s == 'X'))
119 return(1);
120 }
121 return(0); /* didn't find one */
122 }
123
124 int
125 main(int argc, char *argv[])
126 {
127 int skyfmt = DTfromHeader;
128 int outfmt = DTascii;
129 int headout = 1;
130 int nsteps = 0;
131 char *ofspec = NULL;
132 FILE *ofp = stdout;
133 CMATRIX *cmtx; /* component vector/matrix result */
134 char fnbuf[256];
135 int a, i;
136
137 progname = argv[0];
138 /* get options */
139 for (a = 1; a < argc && argv[a][0] == '-'; a++)
140 switch (argv[a][1]) {
141 case 'n':
142 nsteps = atoi(argv[++a]);
143 if (nsteps < 0)
144 goto userr;
145 skyfmt = nsteps ? DTascii : DTfromHeader;
146 break;
147 case 'h':
148 headout = !headout;
149 break;
150 case 'i':
151 switch (argv[a][2]) {
152 case 'f':
153 skyfmt = DTfloat;
154 break;
155 case 'd':
156 skyfmt = DTdouble;
157 break;
158 case 'a':
159 skyfmt = DTascii;
160 break;
161 default:
162 goto userr;
163 }
164 break;
165 case 'o':
166 switch (argv[a][2]) {
167 case '\0': /* output specification (not format) */
168 ofspec = argv[++a];
169 break;
170 case 'f':
171 outfmt = DTfloat;
172 break;
173 case 'd':
174 outfmt = DTdouble;
175 break;
176 case 'a':
177 outfmt = DTascii;
178 break;
179 default:
180 goto userr;
181 }
182 break;
183 default:
184 goto userr;
185 }
186 if ((argc-a < 1) | (argc-a > 4))
187 goto userr;
188
189 if (argc-a > 2) { /* VTDs expression */
190 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
191 const char *ccp;
192 /* get sky vector/matrix */
193 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
194 nsteps = smtx->ncols;
195 /* load BSDF */
196 if (argv[a+1][0] != '!' &&
197 (ccp = strrchr(argv[a+1], '.')) != NULL &&
198 !strcasecmp(ccp+1, "XML"))
199 Tmat = cm_loadBTDF(argv[a+1]);
200 else
201 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
202 /* load Daylight matrix */
203 Dmat = cm_load(argv[a+2], Tmat->ncols,
204 smtx->nrows, DTfromHeader);
205 /* multiply vector through */
206 imtx = cm_multiply(Dmat, smtx);
207 cm_free(Dmat); cm_free(smtx);
208 cmtx = cm_multiply(Tmat, imtx);
209 cm_free(Tmat);
210 cm_free(imtx);
211 } else { /* sky vector/matrix only */
212 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
213 nsteps = cmtx->ncols;
214 }
215 /* prepare output stream */
216 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
217 sprintf(fnbuf, ofspec, 1);
218 ofspec = fnbuf;
219 }
220 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
221 if ((ofp = fopen(ofspec, "w")) == NULL) {
222 fprintf(stderr, "%s: cannot open '%s' for output\n",
223 progname, ofspec);
224 return(1);
225 }
226 ofspec = NULL; /* only need to open once */
227 }
228 if (hasNumberFormat(argv[a])) { /* generating image(s) */
229 if (ofspec == NULL) {
230 SET_FILE_BINARY(ofp);
231 newheader("RADIANCE", ofp);
232 printargs(argc, argv, ofp);
233 fputnow(ofp);
234 }
235 if (nsteps > 1) /* multiple output frames? */
236 for (i = 0; i < nsteps; i++) {
237 CMATRIX *cvec = cm_column(cmtx, i);
238 if (ofspec != NULL) {
239 sprintf(fnbuf, ofspec, i+1);
240 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
241 fprintf(stderr,
242 "%s: cannot open '%s' for output\n",
243 progname, fnbuf);
244 return(1);
245 }
246 newheader("RADIANCE", ofp);
247 printargs(argc, argv, ofp);
248 fputnow(ofp);
249 }
250 fprintf(ofp, "FRAME=%d\n", i+1);
251 if (!sum_images(argv[a], cvec, ofp))
252 return(1);
253 if (ofspec != NULL) {
254 if (fclose(ofp) == EOF) {
255 fprintf(stderr,
256 "%s: error writing to '%s'\n",
257 progname, fnbuf);
258 return(1);
259 }
260 ofp = stdout;
261 }
262 cm_free(cvec);
263 }
264 else if (!sum_images(argv[a], cmtx, ofp))
265 return(1);
266 } else { /* generating vector/matrix */
267 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
268 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
269 cm_free(Vmat);
270 if (ofspec != NULL) { /* multiple vector files? */
271 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
272 for (i = 0; i < nsteps; i++) {
273 CMATRIX *rvec = cm_column(rmtx, i);
274 sprintf(fnbuf, ofspec, i+1);
275 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
276 fprintf(stderr,
277 "%s: cannot open '%s' for output\n",
278 progname, fnbuf);
279 return(1);
280 }
281 #ifdef getc_unlocked
282 flockfile(ofp);
283 #endif
284 if (headout) { /* header output */
285 newheader("RADIANCE", ofp);
286 printargs(argc, argv, ofp);
287 fputnow(ofp);
288 fprintf(ofp, "FRAME=%d\n", i+1);
289 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
290 fputs("NCOLS=1\nNCOMP=3\n", ofp);
291 fputformat((char *)cm_fmt_id[outfmt], ofp);
292 fputc('\n', ofp);
293 }
294 cm_write(rvec, outfmt, ofp);
295 if (fclose(ofp) == EOF) {
296 fprintf(stderr,
297 "%s: error writing to '%s'\n",
298 progname, fnbuf);
299 return(1);
300 }
301 ofp = stdout;
302 cm_free(rvec);
303 }
304 } else {
305 #ifdef getc_unlocked
306 flockfile(ofp);
307 #endif
308 if (outfmt != DTascii)
309 SET_FILE_BINARY(ofp);
310 if (headout) { /* header output */
311 newheader("RADIANCE", ofp);
312 printargs(argc, argv, ofp);
313 fputnow(ofp);
314 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
315 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
316 fputs("NCOMP=3\n", ofp);
317 fputformat((char *)cm_fmt_id[outfmt], ofp);
318 fputc('\n', ofp);
319 }
320 cm_write(rmtx, outfmt, ofp);
321 }
322 cm_free(rmtx);
323 }
324 if (fflush(ofp) == EOF) { /* final clean-up */
325 fprintf(stderr, "%s: write error on output\n", progname);
326 return(1);
327 }
328 cm_free(cmtx);
329 return(0);
330 userr:
331 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n",
332 progname);
333 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n",
334 progname);
335 return(1);
336 }
