root/radiance/ray/src/util/dctimestep.c
Sun Mar 6 01:13:18 2016 UTC (8 years, 1 month ago) by schorsch
Diff to previous 2.36 , to selected 2.35
Tue Jul 14 16:08:28 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.35: +11 -5 lines
Diff to previous 2.35
Added ability for dctimestep to accept matrix files in place of XML for T
Revision 2.35 - (view) (download) (annotate) - [selected]
Fri Sep 26 23:33:09 2014 UTC (9 years, 7 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.34: +4 -2 lines
Diff to previous 2.34
Fixed bug in handling of sky matrices with default -n 0
Wed Sep 17 22:40:49 2014 UTC (9 years, 7 months ago) by greg
Changes since 2.33: +19 -7 lines
Diff to previous 2.33 , to selected 2.35
Sun Jun 1 03:20:29 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Diff to previous 2.32 , to selected 2.35
Added number of rows to dctimestep output and rmtxop to cmake build
Fri May 30 00:07:37 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.31 , to selected 2.35
Fixed usage message
Fri May 30 00:00:54 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.30: +19 -6 lines
Diff to previous 2.30 , to selected 2.35
Sat Feb 8 01:28:06 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.29: +42 -19 lines
Diff to previous 2.29 , to selected 2.35
Mon Jan 20 22:18:29 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.28: +4 -9 lines
Diff to previous 2.28 , to selected 2.35
Fixed improper handling of diffuse transmission matrix
Mon Jan 20 21:29:04 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.27: +2 -499 lines
Diff to previous 2.27 , to selected 2.35
Sat Jan 19 22:30:55 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.26: +26 -1 lines
Diff to previous 2.26 , to selected 2.35
Improved efficiency of large matrix multiplications containing zero vectors
Fri Jan 11 17:54:17 2013 UTC (11 years, 3 months ago) by greg
Diff to previous 2.25 , to selected 2.35
Minor fix in unreachable error
Fri Jan 11 17:21:39 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.24: +34 -12 lines
Diff to previous 2.24 , to selected 2.35
Fri Jan 11 05:07:47 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.23: +153 -40 lines
Diff to previous 2.23 , to selected 2.35
Fri Nov 2 00:26:55 2012 UTC (11 years, 5 months ago) by greg
Diff to previous 2.22 , to selected 2.35
Fixed bug using wrong side of BTDF (thanks to David G-M)
Tue Oct 23 22:24:09 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.21: +70 -4 lines
Diff to previous 2.21 , to selected 2.35
Fixed reciprocity calculation
Tue Oct 16 15:53:04 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.20: +12 -10 lines
Diff to previous 2.20 , to selected 2.35
Added support for "Transmission Front" data
Tue Aug 7 18:17:17 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.19: +46 -11 lines
Diff to previous 2.19 , to selected 2.35
Tue Feb 21 20:09:25 2012 UTC (12 years, 2 months ago) by greg
Diff to previous 2.18 , to selected 2.35
Bug fix for all-zero sky vector and image output
Fri Oct 21 16:31:03 2011 UTC (12 years, 6 months ago) by greg
Changes since 2.17: +17 -11 lines
Diff to previous 2.17 , to selected 2.35
Made format check a little more robust
Fri Apr 15 18:43:57 2011 UTC (13 years ago) by greg
Diff to previous 2.16 , to selected 2.35
Eliminated unused variable
Mon Apr 11 03:47:46 2011 UTC (13 years ago) by greg
Changes since 2.15: +20 -56 lines
Diff to previous 2.15 , to selected 2.35
Final fix to Klems angles -- I hope
Fri Apr 8 18:13:48 2011 UTC (13 years ago) by greg
Changes since 2.14: +99 -34 lines
Diff to previous 2.14 , to selected 2.35
Sun Apr 3 03:06:19 2011 UTC (13 years ago) by greg
Diff to previous 2.13 , to selected 2.35
Added check for zero components when adding images
Thu Jul 1 22:44:25 2010 UTC (13 years, 9 months ago) by greg
Changes since 2.12: +9 -9 lines
Diff to previous 2.12 , to selected 2.35
Bug fix in last change
Thu Jul 1 21:54:56 2010 UTC (13 years, 9 months ago) by greg
Changes since 2.11: +37 -27 lines
Diff to previous 2.11 , to selected 2.35
Wed Dec 9 20:33:48 2009 UTC (14 years, 4 months ago) by greg
Changes since 2.10: +6 -6 lines
Diff to previous 2.10 , to selected 2.35
Made input image name format more flexible.
Thu Jul 2 02:13:08 2009 UTC (14 years, 9 months ago) by greg
Diff to previous 2.9 , to selected 2.35
Sun Jun 21 21:53:10 2009 UTC (14 years, 10 months ago) by greg
Diff to previous 2.8 , to selected 2.35
Minor tweaks
Sun Jun 21 21:49:13 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.7: +4 -3 lines
Diff to previous 2.7 , to selected 2.35
Fixed bug in previous change
Sun Jun 21 21:42:12 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.6: +17 -14 lines
Diff to previous 2.6 , to selected 2.35
Improved BSDF conversion efficiency
Sat Jun 20 04:37:43 2009 UTC (14 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 2.35
Added check against empty input
Sat Jun 20 04:27:18 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.4: +5 -7 lines
Diff to previous 2.4 , to selected 2.35
Changed order of matrix reading to fix size
Fri Jun 19 14:24:06 2009 UTC (14 years, 10 months ago) by greg
Diff to previous 2.3 , to selected 2.35
Fixed problem in error reporting
Fri Jun 19 14:21:42 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.2: +26 -3 lines
Diff to previous 2.2 , to selected 2.35
Fixed conversion of BTDF to matrix
Fri Jun 19 06:49:42 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.1: +20 -15 lines
Diff to previous 2.1 , to selected 2.35
Improvements and bug fixes
Wed Jun 17 20:41:47 2009 UTC (14 years, 10 months ago) by greg
Diff to selected 2.35
