1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: dctimestep.c,v 2.35 2014/09/26 23:33:09 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Compute time-step result using Daylight Coefficient method. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#include <ctype.h> |
11 |
#include "standard.h" |
12 |
#include "cmatrix.h" |
13 |
#include "platform.h" |
14 |
#include "resolu.h" |
15 |
16 |
char *progname; /* global argv[0] */ |
17 |
18 |
/* Sum together a set of images and write result to fout */ |
19 |
static int |
20 |
sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) |
21 |
22 |
int myDT = DTfromHeader; |
23 |
COLOR *scanline = NULL; |
24 |
CMATRIX *pmat = NULL; |
25 |
int myXR=0, myYR=0; |
26 |
int i, y; |
27 |
28 |
if (cv->ncols != 1) |
29 |
error(INTERNAL, "expected vector in sum_images()"); |
30 |
for (i = 0; i < cv->nrows; i++) { |
31 |
const COLORV *scv = cv_lval(cv,i); |
32 |
char fname[1024]; |
33 |
FILE *fp; |
34 |
int dt, xr, yr; |
35 |
COLORV *psp; |
36 |
char *err; |
37 |
/* check for zero */ |
38 |
if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) && |
39 |
(myDT != DTfromHeader) | (i < cv->nrows-1)) |
40 |
continue; |
41 |
/* open next picture */ |
42 |
sprintf(fname, fspec, i); |
43 |
if ((fp = fopen(fname, "rb")) == NULL) { |
44 |
sprintf(errmsg, "cannot open picture '%s'", fname); |
45 |
error(SYSTEM, errmsg); |
46 |
47 |
dt = DTfromHeader; |
48 |
if ((err = cm_getheader(&dt, NULL, NULL, fp)) != NULL) |
49 |
error(USER, err); |
50 |
if ((dt != DTrgbe) & (dt != DTxyze) || |
51 |
!fscnresolu(&xr, &yr, fp)) { |
52 |
sprintf(errmsg, "file '%s' not a picture", fname); |
53 |
error(USER, errmsg); |
54 |
55 |
if (myDT == DTfromHeader) { /* on first one */ |
56 |
myDT = dt; |
57 |
myXR = xr; myYR = yr; |
58 |
scanline = (COLOR *)malloc(sizeof(COLOR)*myXR); |
59 |
if (scanline == NULL) |
60 |
error(SYSTEM, "out of memory in sum_images()"); |
61 |
pmat = cm_alloc(myYR, myXR); |
62 |
memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR); |
63 |
/* finish header */ |
64 |
fputformat((char *)cm_fmt_id[myDT], fout); |
65 |
fputc('\n', fout); |
66 |
fflush(fout); |
67 |
} else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) { |
68 |
sprintf(errmsg, "picture '%s' format/size mismatch", |
69 |
fname); |
70 |
71 |
72 |
psp = pmat->cmem; |
73 |
for (y = 0; y < yr; y++) { /* read it in */ |
74 |
int x; |
75 |
if (freadscan(scanline, xr, fp) < 0) { |
76 |
sprintf(errmsg, "error reading picture '%s'", |
77 |
fname); |
78 |
79 |
80 |
/* sum in scanline */ |
81 |
for (x = 0; x < xr; x++, psp += 3) { |
82 |
multcolor(scanline[x], scv); |
83 |
addcolor(psp, scanline[x]); |
84 |
85 |
86 |
fclose(fp); /* done this picture */ |
87 |
88 |
free(scanline); |
89 |
i = cm_write(pmat, myDT, fout); /* write picture */ |
90 |
cm_free(pmat); /* free data */ |
91 |
return(i); |
92 |
93 |
94 |
/* check to see if a string contains a %d or %o specification */ |
95 |
static int |
96 |
hasNumberFormat(const char *s) |
97 |
98 |
if (s == NULL) |
99 |
return(0); |
100 |
101 |
while (*s) { |
102 |
while (*s != '%') |
103 |
if (!*s++) |
104 |
return(0); |
105 |
if (*++s == '%') { /* ignore "%%" */ |
106 |
++s; |
107 |
continue; |
108 |
109 |
while (isdigit(*s)) /* field length */ |
110 |
++s; |
111 |
/* field we'll use? */ |
112 |
if ((*s == 'd') | (*s == 'i') | (*s == 'o') | |
113 |
(*s == 'x') | (*s == 'X')) |
114 |
return(1); |
115 |
116 |
return(0); /* didn't find one */ |
117 |
118 |
119 |
int |
120 |
main(int argc, char *argv[]) |
121 |
122 |
int skyfmt = DTfromHeader; |
123 |
int outfmt = DTascii; |
124 |
int headout = 1; |
125 |
int nsteps = 0; |
126 |
char *ofspec = NULL; |
127 |
FILE *ofp = stdout; |
128 |
CMATRIX *cmtx; /* component vector/matrix result */ |
129 |
char fnbuf[256]; |
130 |
int a, i; |
131 |
132 |
progname = argv[0]; |
133 |
/* get options */ |
134 |
for (a = 1; a < argc && argv[a][0] == '-'; a++) |
135 |
switch (argv[a][1]) { |
136 |
case 'n': |
137 |
nsteps = atoi(argv[++a]); |
138 |
if (nsteps < 0) |
139 |
goto userr; |
140 |
skyfmt = nsteps ? DTascii : DTfromHeader; |
141 |
break; |
142 |
case 'h': |
143 |
headout = !headout; |
144 |
break; |
145 |
case 'i': |
146 |
switch (argv[a][2]) { |
147 |
case 'f': |
148 |
skyfmt = DTfloat; |
149 |
break; |
150 |
case 'd': |
151 |
skyfmt = DTdouble; |
152 |
break; |
153 |
case 'a': |
154 |
skyfmt = DTascii; |
155 |
break; |
156 |
default: |
157 |
goto userr; |
158 |
159 |
break; |
160 |
case 'o': |
161 |
162 |
case '\0': /* output specification (not format) */ |
163 |
ofspec = argv[++a]; |
164 |
break; |
165 |
case 'f': |
166 |
outfmt = DTfloat; |
167 |
break; |
168 |
case 'd': |
169 |
outfmt = DTdouble; |
170 |
break; |
171 |
case 'a': |
172 |
outfmt = DTascii; |
173 |
break; |
174 |
default: |
175 |
goto userr; |
176 |
177 |
break; |
178 |
default: |
179 |
goto userr; |
180 |
181 |
if ((argc-a < 1) | (argc-a > 4)) |
182 |
goto userr; |
183 |
184 |
if (argc-a > 2) { /* VTDs expression */ |
185 |
CMATRIX *smtx, *Dmat, *Tmat, *imtx; |
186 |
const char *ccp; |
187 |
/* get sky vector/matrix */ |
188 |
smtx = cm_load(argv[a+3], 0, nsteps, skyfmt); |
189 |
nsteps = smtx->ncols; |
190 |
/* load BSDF */ |
191 |
if (argv[a+1][0] != '!' && |
192 |
(ccp = strrchr(argv[a+1], '.')) != NULL && |
193 |
!strcasecmp(ccp+1, "XML")) |
194 |
Tmat = cm_loadBTDF(argv[a+1]); |
195 |
else |
196 |
Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader); |
197 |
/* load Daylight matrix */ |
198 |
Dmat = cm_load(argv[a+2], Tmat->ncols, |
199 |
smtx->nrows, DTfromHeader); |
200 |
/* multiply vector through */ |
201 |
imtx = cm_multiply(Dmat, smtx); |
202 |
cm_free(Dmat); cm_free(smtx); |
203 |
cmtx = cm_multiply(Tmat, imtx); |
204 |
cm_free(Tmat); |
205 |
cm_free(imtx); |
206 |
} else { /* sky vector/matrix only */ |
207 |
cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt); |
208 |
nsteps = cmtx->ncols; |
209 |
210 |
/* prepare output stream */ |
211 |
if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) { |
212 |
sprintf(fnbuf, ofspec, 1); |
213 |
ofspec = fnbuf; |
214 |
215 |
if (ofspec != NULL && !hasNumberFormat(ofspec)) { |
216 |
if ((ofp = fopen(ofspec, "w")) == NULL) { |
217 |
fprintf(stderr, "%s: cannot open '%s' for output\n", |
218 |
progname, ofspec); |
219 |
return(1); |
220 |
221 |
ofspec = NULL; /* only need to open once */ |
222 |
223 |
if (hasNumberFormat(argv[a])) { /* generating image(s) */ |
224 |
if (ofspec == NULL) { |
225 |
SET_FILE_BINARY(ofp); |
226 |
newheader("RADIANCE", ofp); |
227 |
printargs(argc, argv, ofp); |
228 |
fputnow(ofp); |
229 |
230 |
if (nsteps > 1) /* multiple output frames? */ |
231 |
for (i = 0; i < nsteps; i++) { |
232 |
CMATRIX *cvec = cm_column(cmtx, i); |
233 |
if (ofspec != NULL) { |
234 |
sprintf(fnbuf, ofspec, i+1); |
235 |
if ((ofp = fopen(fnbuf, "wb")) == NULL) { |
236 |
fprintf(stderr, |
237 |
238 |
progname, fnbuf); |
239 |
return(1); |
240 |
241 |
242 |
243 |
fputnow(ofp); |
244 |
245 |
fprintf(ofp, "FRAME=%d\n", i+1); |
246 |
if (!sum_images(argv[a], cvec, ofp)) |
247 |
return(1); |
248 |
249 |
if (fclose(ofp) == EOF) { |
250 |
fprintf(stderr, |
251 |
"%s: error writing to '%s'\n", |
252 |
progname, fnbuf); |
253 |
return(1); |
254 |
255 |
ofp = stdout; |
256 |
257 |
cm_free(cvec); |
258 |
259 |
else if (!sum_images(argv[a], cmtx, ofp)) |
260 |
return(1); |
261 |
} else { /* generating vector/matrix */ |
262 |
CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader); |
263 |
CMATRIX *rmtx = cm_multiply(Vmat, cmtx); |
264 |
cm_free(Vmat); |
265 |
if (ofspec != NULL) { /* multiple vector files? */ |
266 |
const char *wtype = (outfmt==DTascii) ? "w" : "wb"; |
267 |
268 |
CMATRIX *rvec = cm_column(rmtx, i); |
269 |
270 |
if ((ofp = fopen(fnbuf, wtype)) == NULL) { |
271 |
fprintf(stderr, |
272 |
273 |
progname, fnbuf); |
274 |
return(1); |
275 |
276 |
#ifdef getc_unlocked |
277 |
flockfile(ofp); |
278 |
#endif |
279 |
if (headout) { /* header output */ |
280 |
281 |
282 |
fputnow(ofp); |
283 |
284 |
fprintf(ofp, "NROWS=%d\n", rvec->nrows); |
285 |
fputs("NCOLS=1\nNCOMP=3\n", ofp); |
286 |
fputformat((char *)cm_fmt_id[outfmt], ofp); |
287 |
fputc('\n', ofp); |
288 |
289 |
cm_write(rvec, outfmt, ofp); |
290 |
291 |
fprintf(stderr, |
292 |
293 |
progname, fnbuf); |
294 |
return(1); |
295 |
296 |
ofp = stdout; |
297 |
cm_free(rvec); |
298 |
299 |
} else { |
300 |
301 |
flockfile(ofp); |
302 |
#endif |
303 |
if (outfmt != DTascii) |
304 |
305 |
306 |
307 |
308 |
fputnow(ofp); |
309 |
fprintf(ofp, "NROWS=%d\n", rmtx->nrows); |
310 |
fprintf(ofp, "NCOLS=%d\n", rmtx->ncols); |
311 |
fputs("NCOMP=3\n", ofp); |
312 |
313 |
fputc('\n', ofp); |
314 |
315 |
cm_write(rmtx, outfmt, ofp); |
316 |
317 |
cm_free(rmtx); |
318 |
319 |
if (fflush(ofp) == EOF) { /* final clean-up */ |
320 |
fprintf(stderr, "%s: write error on output\n", progname); |
321 |
return(1); |
322 |
323 |
cm_free(cmtx); |
324 |
return(0); |
325 |
userr: |
326 |
fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n", |
327 |
progname); |
328 |
fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n", |
329 |
progname); |
330 |
return(1); |
331 |
