Made format check a little more robust
Eliminated unused variable
Final fix to Klems angles -- I hope
Added check for zero components when adding images
Bug fix in last change
Made input image name format more flexible.
Minor tweaks
Fixed bug in previous change
Improved BSDF conversion efficiency
Added check against empty input
Changed order of matrix reading to fix size
Fixed problem in error reporting
Fixed conversion of BTDF to matrix
Improvements and bug fixes
