root/radiance/ray/src/util/dctimestep.c
Fri Oct 21 16:31:03 2011 UTC (12 years, 8 months ago) by greg
Changes since 2.17: +17 -11 lines
Diff to previous 2.17 , to selected 2.16
Made format check a little more robust
Fri Apr 15 18:43:57 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.16
Eliminated unused variable
Revision 2.16 - (view) (download) (annotate) - [selected]
Mon Apr 11 03:47:46 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.15: +20 -56 lines
Diff to previous 2.15
Final fix to Klems angles -- I hope
Fri Apr 8 18:13:48 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.14: +99 -34 lines
Diff to previous 2.14 , to selected 2.16
Sun Apr 3 03:06:19 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 2.16
Added check for zero components when adding images
Thu Jul 1 22:44:25 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.12: +9 -9 lines
Diff to previous 2.12 , to selected 2.16
Bug fix in last change
Thu Jul 1 21:54:56 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.11: +37 -27 lines
Diff to previous 2.11 , to selected 2.16
Wed Dec 9 20:33:48 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.10: +6 -6 lines
Diff to previous 2.10 , to selected 2.16
Made input image name format more flexible.
Thu Jul 2 02:13:08 2009 UTC (14 years, 11 months ago) by greg
Diff to previous 2.9 , to selected 2.16
Sun Jun 21 21:53:10 2009 UTC (15 years ago) by greg
Diff to previous 2.8 , to selected 2.16
Minor tweaks
Sun Jun 21 21:49:13 2009 UTC (15 years ago) by greg
Changes since 2.7: +4 -3 lines
Diff to previous 2.7 , to selected 2.16
Fixed bug in previous change
Sun Jun 21 21:42:12 2009 UTC (15 years ago) by greg
Changes since 2.6: +17 -14 lines
Diff to previous 2.6 , to selected 2.16
Improved BSDF conversion efficiency
Sat Jun 20 04:37:43 2009 UTC (15 years ago) by greg
Diff to previous 2.5 , to selected 2.16
Added check against empty input
Sat Jun 20 04:27:18 2009 UTC (15 years ago) by greg
Changes since 2.4: +5 -7 lines
Diff to previous 2.4 , to selected 2.16
Changed order of matrix reading to fix size
Fri Jun 19 14:24:06 2009 UTC (15 years ago) by greg
Diff to previous 2.3 , to selected 2.16
Fixed problem in error reporting
Fri Jun 19 14:21:42 2009 UTC (15 years ago) by greg
Changes since 2.2: +26 -3 lines
Diff to previous 2.2 , to selected 2.16
Fixed conversion of BTDF to matrix
Fri Jun 19 06:49:42 2009 UTC (15 years ago) by greg
Changes since 2.1: +20 -15 lines
Diff to previous 2.1 , to selected 2.16
Improvements and bug fixes
Wed Jun 17 20:41:47 2009 UTC (15 years ago) by greg
Diff to selected 2.16
