root/radiance/ray/src/util/dctimestep.c
Revision: 2.55
Committed: Sat Jun 7 05:09:46 2025 UTC (2 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.54: +1 -2 lines
2 static const char RCSid[] = "$Id: dctimestep.c,v 2.54 2025/06/06 19:11:21 greg Exp $";
5 * Compute time-step result using Daylight Coefficient method.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "resolu.h"
16
17 /* Sum together a set of images and write result to fout */
18 static int
19 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
20 {
21 static int runcnt = 0;
22 int myDT = DTfromHeader;
23 COLR *scanline = NULL;
24 CMATRIX *pmat = NULL;
25 int myXR=0, myYR=0;
26 int i, y;
27
28 if (cv->ncols != 1)
29 error(INTERNAL, "expected vector in sum_images()");
30 for (i = cv->nrows; i-- > 0; ) {
31 const int r = runcnt&1 ? i : cv->nrows-1 - i;
32 const COLORV *scv = cv_lval(cv,r);
33 int flat_file = 0;
34 char fname[1024];
35 FILE *fp;
36 long data_start;
37 int dt, xr, yr;
38 COLORV *psp;
39 char *err;
40 /* check for zero */
41 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
42 (myDT != DTfromHeader) | (i > 0))
43 continue;
44 /* open next picture */
45 sprintf(fname, fspec, r);
46 if ((fp = fopen(fname, "rb")) == NULL) {
47 sprintf(errmsg, "cannot open picture '%s'", fname);
48 error(SYSTEM, errmsg);
49 }
50 #ifdef getc_unlocked
51 flockfile(fp);
52 #endif
53 dt = DTfromHeader;
54 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
55 error(USER, err);
56 if ((dt != DTrgbe) & (dt != DTxyze) ||
57 !fscnresolu(&xr, &yr, fp)) {
58 sprintf(errmsg, "file '%s' not a picture", fname);
59 error(USER, errmsg);
60 }
61 if (myDT == DTfromHeader) { /* on first one */
62 myDT = dt;
63 myXR = xr; myYR = yr;
64 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
65 if (scanline == NULL)
66 error(SYSTEM, "out of memory in sum_images()");
67 pmat = cm_alloc(myYR, myXR);
68 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
69 /* finish header */
70 fputformat(cm_fmt_id[myDT], fout);
71 fputc('\n', fout);
72 fflush(fout);
73 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
74 sprintf(errmsg, "picture '%s' format/size mismatch",
75 fname);
76 error(USER, errmsg);
77 }
78 /* flat file check */
79 if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
80 flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr);
81 if (fseek(fp, data_start, SEEK_SET) < 0) {
82 sprintf(errmsg, "cannot seek on picture '%s'", fname);
83 error(SYSTEM, errmsg);
84 }
85 }
86 psp = pmat->cmem;
87 for (y = 0; y < yr; y++) { /* read it in */
88 COLOR col;
89 int x;
90 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
91 freadcolrs(scanline, xr, fp) < 0) {
92 sprintf(errmsg, "error reading picture '%s'",
93 fname);
94 error(SYSTEM, errmsg);
95 }
96 /* sum in scanline */
97 for (x = 0; x < xr; x++, psp += 3) {
98 if (!scanline[x][EXP])
99 continue; /* skip zeroes */
100 colr_color(col, scanline[x]);
101 multcolor(col, scv);
102 addcolor(psp, col);
103 }
104 }
105 fclose(fp); /* done this picture */
106 }
107 free(scanline);
108 i = cm_write(pmat, myDT, fout); /* write picture */
109 cm_free(pmat); /* free data */
110 ++runcnt; /* for zig-zagging */
111 return(i);
112 }
113
114 /* adjust matrix dimensions according to user size(s) */
115 static int
116 alt_dim(CMATRIX *cm, int nr, int nc)
117 {
118 if ((nr <= 0) & (nc <= 0))
119 return(0);
120 if ((nr == cm->nrows) & (nc == cm->ncols))
121 return(0);
122 if (nr > 0) {
123 if (nc <= 0)
124 nc = cm->nrows*cm->ncols/nr;
125 if (nr*nc != cm->nrows*cm->ncols) {
126 fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n",
127 nr, nc, cm->nrows, cm->ncols);
128 return(-1);
129 }
130 } else /* nc > 0 */ {
131 nr = cm->nrows*cm->ncols/nc;
132 if (nc*nr != cm->nrows*cm->ncols) {
133 fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n",
134 nc, cm->nrows, cm->ncols);
135 return(-1);
136 }
137 }
138 cm->nrows = nr;
139 cm->ncols = nc;
140 return(1);
141 }
142
143 /* check to see if a string contains a %d or %o specification */
144 static int
145 hasNumberFormat(const char *s)
146 {
147 if (s == NULL)
148 return(0);
149
150 while (*s) {
151 while (*s != '%')
152 if (!*s++)
153 return(0);
154 if (*++s == '%') { /* ignore "%%" */
155 ++s;
156 continue;
157 }
158 while (isdigit(*s)) /* field length */
159 ++s;
160 /* field we'll use? */
161 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
162 (*s == 'x') | (*s == 'X'))
163 return(1);
164 }
165 return(0); /* didn't find one */
166 }
167
168 int
169 main(int argc, char *argv[])
170 {
171 int skyfmt = DTfromHeader;
172 int outfmt = DTascii;
173 int headout = 1;
174 int nsteps = 0;
175 char *ofspec = NULL;
176 FILE *ofp = stdout;
177 int xres=0, yres=0;
178 CMATRIX *cmtx; /* component vector/matrix result */
179 char fnbuf[256];
180 int a, i;
181 /* set global progname */
182 fixargv0(argv[0]);
183 /* get options */
184 for (a = 1; a < argc && argv[a][0] == '-'; a++)
185 switch (argv[a][1]) {
186 case 'n':
187 nsteps = atoi(argv[++a]);
188 if (nsteps < 0)
189 goto userr;
190 skyfmt = nsteps ? DTascii : DTfromHeader;
191 break;
192 case 'h':
193 headout = !headout;
194 break;
195 case 'i':
196 switch (argv[a][2]) {
197 case 'f':
198 skyfmt = DTfloat;
199 break;
200 case 'd':
201 skyfmt = DTdouble;
202 break;
203 case 'a':
204 skyfmt = DTascii;
205 break;
206 default:
207 goto userr;
208 }
209 break;
210 case 'o':
211 switch (argv[a][2]) {
212 case '\0': /* output specification (not format) */
213 ofspec = argv[++a];
214 break;
215 case 'f':
216 outfmt = DTfloat;
217 break;
218 case 'd':
219 outfmt = DTdouble;
220 break;
221 case 'a':
222 outfmt = DTascii;
223 break;
224 case 'c':
225 outfmt = DTrgbe;
226 break;
227 default:
228 goto userr;
229 }
230 break;
231 case 'x':
232 xres = atoi(argv[++a]);
233 break;
234 case 'y':
235 yres = atoi(argv[++a]);
236 break;
237 default:
238 goto userr;
239 }
240 if ((argc-a < 1) | (argc-a > 4))
241 goto userr;
242
243 if (argc-a > 2) { /* VTDs expression */
244 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
245 const char *ccp;
246 /* get sky vector/matrix */
247 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
248 nsteps = smtx->ncols;
249 /* load BSDF */
250 if (argv[a+1][0] != '!' &&
251 (ccp = strrchr(argv[a+1], '.')) > argv[a+1] &&
252 !strcasecmp(ccp+1, "XML"))
253 Tmat = cm_loadBTDF(argv[a+1]);
254 else
255 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
256 /* load Daylight matrix */
257 Dmat = cm_load(argv[a+2], Tmat->ncols,
258 smtx->nrows, DTfromHeader);
259 /* multiply vector through */
260 imtx = cm_multiply(Dmat, smtx);
261 cm_free(Dmat); cm_free(smtx);
262 cmtx = cm_multiply(Tmat, imtx);
263 cm_free(Tmat);
264 cm_free(imtx);
265 } else { /* sky vector/matrix only */
266 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
267 nsteps = cmtx->ncols;
268 }
269 /* prepare output stream */
270 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
271 sprintf(fnbuf, ofspec, 0);
272 ofspec = fnbuf;
273 }
274 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
275 if ((ofp = fopen(ofspec, "w")) == NULL) {
276 fprintf(stderr, "%s: cannot open '%s' for output\n",
277 progname, ofspec);
278 return(1);
279 }
280 ofspec = NULL; /* only need to open once */
281 }
282 if (hasNumberFormat(argv[a])) { /* loading image vector(s) */
283 if (outfmt != DTrgbe) {
284 error(WARNING, "changing output type to -oc");
285 outfmt = DTrgbe;
286 }
287 if (ofspec == NULL) {
288 SET_FILE_BINARY(ofp);
289 newheader("RADIANCE", ofp);
290 printargs(argc, argv, ofp);
291 fputnow(ofp);
292 }
293 if (nsteps > 1) /* multiple output frames? */
294 for (i = 0; i < nsteps; i++) {
295 CMATRIX *cvec = cm_column(cmtx, i);
296 if (ofspec != NULL) {
297 sprintf(fnbuf, ofspec, i);
298 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
299 fprintf(stderr,
300 "%s: cannot open '%s' for output\n",
301 progname, fnbuf);
302 return(1);
303 }
304 newheader("RADIANCE", ofp);
305 printargs(argc, argv, ofp);
306 fputnow(ofp);
307 }
308 fprintf(ofp, "FRAME=%d\n", i);
309 if (!sum_images(argv[a], cvec, ofp))
310 return(1);
311 if (ofspec != NULL) {
312 if (fclose(ofp) == EOF) {
313 fprintf(stderr,
314 "%s: error writing to '%s'\n",
315 progname, fnbuf);
316 return(1);
317 }
318 ofp = stdout;
319 }
320 cm_free(cvec);
321 }
322 else if (!sum_images(argv[a], cmtx, ofp))
323 return(1);
324 } else { /* loading view matrix */
325 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
326 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
327 cm_free(Vmat);
328 if (ofspec != NULL) { /* multiple vector files? */
329 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
330 for (i = 0; i < nsteps; i++) {
331 CMATRIX *rvec = cm_column(rmtx, i);
332 if (alt_dim(rvec, yres, xres) < 0)
333 return(1);
334 sprintf(fnbuf, ofspec, i);
335 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
336 fprintf(stderr,
337 "%s: cannot open '%s' for output\n",
338 progname, fnbuf);
339 return(1);
340 }
341 #ifdef getc_unlocked
342 flockfile(ofp);
343 #endif
344 if (headout) { /* header output */
345 newheader("RADIANCE", ofp);
346 printargs(argc, argv, ofp);
347 fputnow(ofp);
348 fprintf(ofp, "FRAME=%d\n", i);
349 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
350 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
351 fprintf(ofp, "NCOLS=%d\n", rvec->ncols);
352 fputncomp(3, ofp);
353 }
354 if ((outfmt == DTfloat) | (outfmt == DTdouble))
355 fputendian(ofp);
356 fputformat(cm_fmt_id[outfmt], ofp);
357 fputc('\n', ofp);
358 }
359 cm_write(rvec, outfmt, ofp);
360 if (fclose(ofp) == EOF) {
361 fprintf(stderr,
362 "%s: error writing to '%s'\n",
363 progname, fnbuf);
364 return(1);
365 }
366 ofp = stdout;
367 cm_free(rvec);
368 }
369 } else {
370 #ifdef getc_unlocked
371 flockfile(ofp);
372 #endif
373 if (outfmt != DTascii)
374 SET_FILE_BINARY(ofp);
375 if (alt_dim(rmtx, yres, xres) < 0)
376 return(1);
377 if (headout) { /* header output */
378 newheader("RADIANCE", ofp);
379 printargs(argc, argv, ofp);
380 fputnow(ofp);
381 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
382 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
383 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
384 fputncomp(3, ofp);
385 }
386 if ((outfmt == DTfloat) | (outfmt == DTdouble))
387 fputendian(ofp);
388 fputformat(cm_fmt_id[outfmt], ofp);
389 fputc('\n', ofp);
390 }
391 cm_write(rmtx, outfmt, ofp);
392 }
393 cm_free(rmtx);
394 }
395 if (fflush(ofp) == EOF) { /* final clean-up */
396 fprintf(stderr, "%s: write error on output\n", progname);
397 return(1);
398 }
399 cm_free(cmtx);
400 return(0);
401 userr:
402 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n",
403 progname);
404 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n",
405 progname);
406 return(1);
407 }
