root/radiance/ray/src/util/dctimestep.c
Revision: 2.53
Committed: Thu Mar 27 16:34:23 2025 UTC (5 weeks, 5 days ago) by greg
Changes since 2.52: +8 -5 lines
perf(dctimestep): Added back-and-forth sweep to improve memory access from picture set
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.53 static const char RCSid[] = "$Id: dctimestep.c,v 2.52 2025/03/22 01:27:22 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Compute time-step result using Daylight Coefficient method.
6     *
7     * G. Ward
8     */
9
10     #include <ctype.h>
11 schorsch 2.37 #include "platform.h"
12 greg 2.1 #include "standard.h"
13 greg 2.28 #include "cmatrix.h"
14 greg 2.1 #include "platform.h"
15     #include "resolu.h"
16
17     char *progname; /* global argv[0] */
18
19 greg 2.24 /* Sum together a set of images and write result to fout */
20 greg 2.1 static int
21 greg 2.13 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
22 greg 2.1 {
23 greg 2.53 static int runcnt = 0;
24 greg 2.1 int myDT = DTfromHeader;
25 greg 2.38 COLR *scanline = NULL;
26 greg 2.24 CMATRIX *pmat = NULL;
27     int myXR=0, myYR=0;
28 greg 2.1 int i, y;
29
30     if (cv->ncols != 1)
31 greg 2.35 error(INTERNAL, "expected vector in sum_images()");
32 greg 2.53 for (i = cv->nrows; i-- > 0; ) {
33     const int r = runcnt&1 ? i : cv->nrows-1 - i;
34     const COLORV *scv = cv_lval(cv,r);
35 greg 2.39 int flat_file = 0;
36 greg 2.1 char fname[1024];
37     FILE *fp;
38 greg 2.39 long data_start;
39 greg 2.1 int dt, xr, yr;
40     COLORV *psp;
41 greg 2.31 char *err;
42 greg 2.14 /* check for zero */
43 greg 2.19 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
44 greg 2.53 (myDT != DTfromHeader) | (i > 0))
45 greg 2.14 continue;
46 greg 2.1 /* open next picture */
47 greg 2.53 sprintf(fname, fspec, r);
48 greg 2.31 if ((fp = fopen(fname, "rb")) == NULL) {
49 greg 2.1 sprintf(errmsg, "cannot open picture '%s'", fname);
50     error(SYSTEM, errmsg);
51     }
52 greg 2.50 #ifdef getc_unlocked
53     flockfile(fp);
54     #endif
55 greg 2.31 dt = DTfromHeader;
56 greg 2.45 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
57 greg 2.31 error(USER, err);
58 greg 2.1 if ((dt != DTrgbe) & (dt != DTxyze) ||
59     !fscnresolu(&xr, &yr, fp)) {
60     sprintf(errmsg, "file '%s' not a picture", fname);
61     error(USER, errmsg);
62     }
63     if (myDT == DTfromHeader) { /* on first one */
64     myDT = dt;
65     myXR = xr; myYR = yr;
66 greg 2.38 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
67 greg 2.1 if (scanline == NULL)
68     error(SYSTEM, "out of memory in sum_images()");
69     pmat = cm_alloc(myYR, myXR);
70     memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
71 greg 2.2 /* finish header */
72 greg 2.46 fputformat(cm_fmt_id[myDT], fout);
73 greg 2.13 fputc('\n', fout);
74     fflush(fout);
75 greg 2.1 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
76     sprintf(errmsg, "picture '%s' format/size mismatch",
77     fname);
78     error(USER, errmsg);
79     }
80 greg 2.39 /* flat file check */
81     if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
82 greg 2.51 flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr);
83 greg 2.39 if (fseek(fp, data_start, SEEK_SET) < 0) {
84     sprintf(errmsg, "cannot seek on picture '%s'", fname);
85     error(SYSTEM, errmsg);
86     }
87     }
88 greg 2.1 psp = pmat->cmem;
89     for (y = 0; y < yr; y++) { /* read it in */
90 greg 2.38 COLOR col;
91 greg 2.1 int x;
92 greg 2.39 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
93     freadcolrs(scanline, xr, fp) < 0) {
94 greg 2.1 sprintf(errmsg, "error reading picture '%s'",
95     fname);
96     error(SYSTEM, errmsg);
97     }
98     /* sum in scanline */
99     for (x = 0; x < xr; x++, psp += 3) {
100 greg 2.38 if (!scanline[x][EXP])
101     continue; /* skip zeroes */
102     colr_color(col, scanline[x]);
103     multcolor(col, scv);
104     addcolor(psp, col);
105 greg 2.1 }
106     }
107     fclose(fp); /* done this picture */
108     }
109     free(scanline);
110 greg 2.30 i = cm_write(pmat, myDT, fout); /* write picture */
111     cm_free(pmat); /* free data */
112 greg 2.53 ++runcnt; /* for zig-zagging */
113 greg 2.30 return(i);
114 greg 2.1 }
115
116 greg 2.49 /* adjust matrix dimensions according to user size(s) */
117     static int
118     alt_dim(CMATRIX *cm, int nr, int nc)
119     {
120     if ((nr <= 0) & (nc <= 0))
121     return(0);
122     if ((nr == cm->nrows) & (nc == cm->ncols))
123     return(0);
124     if (nr > 0) {
125     if (nc <= 0)
126     nc = cm->nrows*cm->ncols/nr;
127     if (nr*nc != cm->nrows*cm->ncols) {
128     fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n",
129     nr, nc, cm->nrows, cm->ncols);
130     return(-1);
131     }
132     } else /* nc > 0 */ {
133     nr = cm->nrows*cm->ncols/nc;
134     if (nc*nr != cm->nrows*cm->ncols) {
135     fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n",
136     nc, cm->nrows, cm->ncols);
137     return(-1);
138     }
139     }
140     cm->nrows = nr;
141     cm->ncols = nc;
142     return(1);
143     }
144
145 greg 2.11 /* check to see if a string contains a %d or %o specification */
146     static int
147     hasNumberFormat(const char *s)
148 greg 2.1 {
149 greg 2.24 if (s == NULL)
150     return(0);
151
152 greg 2.18 while (*s) {
153     while (*s != '%')
154     if (!*s++)
155     return(0);
156     if (*++s == '%') { /* ignore "%%" */
157     ++s;
158     continue;
159     }
160     while (isdigit(*s)) /* field length */
161     ++s;
162     /* field we'll use? */
163     if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
164     (*s == 'x') | (*s == 'X'))
165     return(1);
166     }
167     return(0); /* didn't find one */
168 greg 2.1 }
169
170     int
171     main(int argc, char *argv[])
172     {
173 greg 2.34 int skyfmt = DTfromHeader;
174 greg 2.30 int outfmt = DTascii;
175 greg 2.34 int headout = 1;
176     int nsteps = 0;
177 greg 2.24 char *ofspec = NULL;
178     FILE *ofp = stdout;
179 greg 2.47 int xres=0, yres=0;
180 greg 2.24 CMATRIX *cmtx; /* component vector/matrix result */
181     char fnbuf[256];
182     int a, i;
183 greg 2.1
184     progname = argv[0];
185 greg 2.24 /* get options */
186 greg 2.25 for (a = 1; a < argc && argv[a][0] == '-'; a++)
187     switch (argv[a][1]) {
188 greg 2.24 case 'n':
189     nsteps = atoi(argv[++a]);
190 greg 2.31 if (nsteps < 0)
191 greg 2.24 goto userr;
192 greg 2.34 skyfmt = nsteps ? DTascii : DTfromHeader;
193     break;
194     case 'h':
195     headout = !headout;
196 greg 2.24 break;
197 greg 2.25 case 'i':
198     switch (argv[a][2]) {
199     case 'f':
200     skyfmt = DTfloat;
201     break;
202     case 'd':
203     skyfmt = DTdouble;
204     break;
205     case 'a':
206     skyfmt = DTascii;
207     break;
208     default:
209     goto userr;
210     }
211     break;
212 greg 2.30 case 'o':
213     switch (argv[a][2]) {
214     case '\0': /* output specification (not format) */
215     ofspec = argv[++a];
216     break;
217     case 'f':
218     outfmt = DTfloat;
219     break;
220     case 'd':
221     outfmt = DTdouble;
222     break;
223     case 'a':
224     outfmt = DTascii;
225     break;
226 greg 2.43 case 'c':
227     outfmt = DTrgbe;
228     break;
229 greg 2.30 default:
230     goto userr;
231     }
232     break;
233 greg 2.47 case 'x':
234     xres = atoi(argv[++a]);
235     break;
236     case 'y':
237     yres = atoi(argv[++a]);
238     break;
239 greg 2.24 default:
240     goto userr;
241     }
242     if ((argc-a < 1) | (argc-a > 4))
243     goto userr;
244 greg 2.1
245 greg 2.24 if (argc-a > 2) { /* VTDs expression */
246 greg 2.36 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
247     const char *ccp;
248 greg 2.24 /* get sky vector/matrix */
249 greg 2.25 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
250 greg 2.35 nsteps = smtx->ncols;
251 greg 2.12 /* load BSDF */
252 greg 2.36 if (argv[a+1][0] != '!' &&
253 greg 2.52 (ccp = strrchr(argv[a+1], '.')) > argv[a+1] &&
254 greg 2.36 !strcasecmp(ccp+1, "XML"))
255     Tmat = cm_loadBTDF(argv[a+1]);
256     else
257     Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
258 greg 2.5 /* load Daylight matrix */
259 greg 2.36 Dmat = cm_load(argv[a+2], Tmat->ncols,
260 greg 2.24 smtx->nrows, DTfromHeader);
261 greg 2.1 /* multiply vector through */
262 greg 2.24 imtx = cm_multiply(Dmat, smtx);
263     cm_free(Dmat); cm_free(smtx);
264 greg 2.29 cmtx = cm_multiply(Tmat, imtx);
265     cm_free(Tmat);
266 greg 2.24 cm_free(imtx);
267     } else { /* sky vector/matrix only */
268 greg 2.25 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
269 greg 2.35 nsteps = cmtx->ncols;
270 greg 2.24 }
271     /* prepare output stream */
272     if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
273 greg 2.52 sprintf(fnbuf, ofspec, 0);
274 greg 2.24 ofspec = fnbuf;
275     }
276     if (ofspec != NULL && !hasNumberFormat(ofspec)) {
277     if ((ofp = fopen(ofspec, "w")) == NULL) {
278     fprintf(stderr, "%s: cannot open '%s' for output\n",
279     progname, ofspec);
280     return(1);
281     }
282     ofspec = NULL; /* only need to open once */
283 greg 2.12 }
284 greg 2.52 if (hasNumberFormat(argv[a])) { /* loading image vector(s) */
285 greg 2.44 if (outfmt != DTrgbe) {
286     error(WARNING, "changing output type to -oc");
287     outfmt = DTrgbe;
288     }
289 greg 2.24 if (ofspec == NULL) {
290     SET_FILE_BINARY(ofp);
291     newheader("RADIANCE", ofp);
292     printargs(argc, argv, ofp);
293     fputnow(ofp);
294     }
295     if (nsteps > 1) /* multiple output frames? */
296     for (i = 0; i < nsteps; i++) {
297     CMATRIX *cvec = cm_column(cmtx, i);
298     if (ofspec != NULL) {
299 greg 2.40 sprintf(fnbuf, ofspec, i);
300 greg 2.24 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
301     fprintf(stderr,
302     "%s: cannot open '%s' for output\n",
303     progname, fnbuf);
304     return(1);
305     }
306     newheader("RADIANCE", ofp);
307     printargs(argc, argv, ofp);
308     fputnow(ofp);
309     }
310 greg 2.40 fprintf(ofp, "FRAME=%d\n", i);
311 greg 2.24 if (!sum_images(argv[a], cvec, ofp))
312     return(1);
313     if (ofspec != NULL) {
314     if (fclose(ofp) == EOF) {
315     fprintf(stderr,
316     "%s: error writing to '%s'\n",
317     progname, fnbuf);
318     return(1);
319     }
320     ofp = stdout;
321     }
322     cm_free(cvec);
323     }
324     else if (!sum_images(argv[a], cmtx, ofp))
325 greg 2.1 return(1);
326 greg 2.52 } else { /* loading view matrix */
327 greg 2.24 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
328     CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
329 greg 2.1 cm_free(Vmat);
330 greg 2.30 if (ofspec != NULL) { /* multiple vector files? */
331     const char *wtype = (outfmt==DTascii) ? "w" : "wb";
332 greg 2.24 for (i = 0; i < nsteps; i++) {
333     CMATRIX *rvec = cm_column(rmtx, i);
334 greg 2.49 if (alt_dim(rvec, yres, xres) < 0)
335     return(1);
336 greg 2.40 sprintf(fnbuf, ofspec, i);
337 greg 2.30 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
338 greg 2.24 fprintf(stderr,
339     "%s: cannot open '%s' for output\n",
340     progname, fnbuf);
341     return(1);
342     }
343 greg 2.31 #ifdef getc_unlocked
344     flockfile(ofp);
345     #endif
346 greg 2.34 if (headout) { /* header output */
347     newheader("RADIANCE", ofp);
348     printargs(argc, argv, ofp);
349     fputnow(ofp);
350 greg 2.40 fprintf(ofp, "FRAME=%d\n", i);
351 greg 2.47 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
352     fprintf(ofp, "NROWS=%d\n", rvec->nrows);
353     fprintf(ofp, "NCOLS=%d\n", rvec->ncols);
354 greg 2.52 fputncomp(3, ofp);
355 greg 2.47 }
356     if ((outfmt == DTfloat) | (outfmt == DTdouble))
357 greg 2.42 fputendian(ofp);
358 greg 2.46 fputformat(cm_fmt_id[outfmt], ofp);
359 greg 2.34 fputc('\n', ofp);
360     }
361 greg 2.30 cm_write(rvec, outfmt, ofp);
362 greg 2.24 if (fclose(ofp) == EOF) {
363     fprintf(stderr,
364     "%s: error writing to '%s'\n",
365     progname, fnbuf);
366     return(1);
367     }
368     ofp = stdout;
369     cm_free(rvec);
370     }
371 greg 2.30 } else {
372 greg 2.31 #ifdef getc_unlocked
373     flockfile(ofp);
374     #endif
375 greg 2.30 if (outfmt != DTascii)
376     SET_FILE_BINARY(ofp);
377 greg 2.49 if (alt_dim(rmtx, yres, xres) < 0)
378     return(1);
379 greg 2.34 if (headout) { /* header output */
380 greg 2.30 newheader("RADIANCE", ofp);
381     printargs(argc, argv, ofp);
382     fputnow(ofp);
383 greg 2.47 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
384     fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
385     fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
386 greg 2.52 fputncomp(3, ofp);
387 greg 2.47 }
388     if ((outfmt == DTfloat) | (outfmt == DTdouble))
389 greg 2.42 fputendian(ofp);
390 greg 2.46 fputformat(cm_fmt_id[outfmt], ofp);
391 greg 2.30 fputc('\n', ofp);
392     }
393     cm_write(rmtx, outfmt, ofp);
394     }
395 greg 2.24 cm_free(rmtx);
396     }
397     if (fflush(ofp) == EOF) { /* final clean-up */
398     fprintf(stderr, "%s: write error on output\n", progname);
399     return(1);
400 greg 2.1 }
401 greg 2.24 cm_free(cmtx);
402 greg 2.1 return(0);
403 greg 2.24 userr:
404 greg 2.48 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n",
405 greg 2.24 progname);
406 greg 2.48 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n",
407 greg 2.24 progname);
408     return(1);
409 greg 2.1 }
