| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: dctimestep.c,v 2.26 2013/01/11 17:54:17 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Compute time-step result using Daylight Coefficient method.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#include <ctype.h>
| 11 |
#include "standard.h"
| 12 |
#include "platform.h"
| 13 |
#include "paths.h"
| 14 |
#include "color.h"
| 15 |
#include "resolu.h"
| 16 |
#include "bsdf.h"
| 17 |
#include "bsdf_m.h"
| 18 |
| 19 |
char *progname; /* global argv[0] */
| 20 |
| 21 |
/* Data types for file loading */
| 22 |
enum {DTfromHeader, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze};
| 23 |
| 24 |
/* A color coefficient matrix -- vectors have ncols==1 */
| 25 |
typedef struct {
| 26 |
int nrows, ncols;
| 27 |
COLORV cmem[3]; /* extends struct */
| 28 |
} CMATRIX;
| 29 |
| 30 |
#define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf")
| 31 |
| 32 |
#define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c)))
| 33 |
| 34 |
#define cv_lval(cm,i) ((cm)->cmem + 3*(i))
| 35 |
| 36 |
/* Allocate a color coefficient matrix */
| 37 |
static CMATRIX *
| 38 |
cm_alloc(int nrows, int ncols)
| 39 |
| 40 |
CMATRIX *cm;
| 41 |
| 42 |
if ((nrows <= 0) | (ncols <= 0))
| 43 |
error(USER, "attempt to create empty matrix");
| 44 |
cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
| 45 |
3*sizeof(COLORV)*(nrows*ncols - 1));
| 46 |
if (cm == NULL)
| 47 |
error(SYSTEM, "out of memory in cm_alloc()");
| 48 |
cm->nrows = nrows;
| 49 |
cm->ncols = ncols;
| 50 |
return(cm);
| 51 |
| 52 |
| 53 |
#define cm_free(cm) free(cm)
| 54 |
| 55 |
/* Resize color coefficient matrix */
| 56 |
static CMATRIX *
| 57 |
cm_resize(CMATRIX *cm, int nrows)
| 58 |
| 59 |
if (nrows == cm->nrows)
| 60 |
return(cm);
| 61 |
if (nrows <= 0) {
| 62 |
cm_free(cm);
| 63 |
return(NULL);
| 64 |
| 65 |
cm = (CMATRIX *)realloc(cm, sizeof(CMATRIX) +
| 66 |
3*sizeof(COLORV)*(nrows*cm->ncols - 1));
| 67 |
if (cm == NULL)
| 68 |
error(SYSTEM, "out of memory in cm_resize()");
| 69 |
cm->nrows = nrows;
| 70 |
return(cm);
| 71 |
| 72 |
| 73 |
/* Load header to obtain data type */
| 74 |
static int
| 75 |
getDT(char *s, void *p)
| 76 |
| 77 |
char fmt[32];
| 78 |
| 79 |
if (formatval(fmt, s)) {
| 80 |
if (!strcmp(fmt, "ascii"))
| 81 |
*((int *)p) = DTascii;
| 82 |
else if (!strcmp(fmt, "float"))
| 83 |
*((int *)p) = DTfloat;
| 84 |
else if (!strcmp(fmt, "double"))
| 85 |
*((int *)p) = DTdouble;
| 86 |
else if (!strcmp(fmt, COLRFMT))
| 87 |
*((int *)p) = DTrgbe;
| 88 |
else if (!strcmp(fmt, CIEFMT))
| 89 |
*((int *)p) = DTxyze;
| 90 |
| 91 |
return(0);
| 92 |
| 93 |
| 94 |
static int
| 95 |
getDTfromHeader(FILE *fp)
| 96 |
| 97 |
int dt = DTfromHeader;
| 98 |
| 99 |
if (getheader(fp, getDT, &dt) < 0)
| 100 |
error(SYSTEM, "header read error");
| 101 |
if (dt == DTfromHeader)
| 102 |
error(USER, "missing data format in header");
| 103 |
return(dt);
| 104 |
| 105 |
| 106 |
/* Allocate and load a matrix from the given file (or stdin if NULL) */
| 107 |
static CMATRIX *
| 108 |
cm_load(const char *fname, int nrows, int ncols, int dtype)
| 109 |
| 110 |
FILE *fp = stdin;
| 111 |
CMATRIX *cm;
| 112 |
| 113 |
if (ncols <= 0)
| 114 |
error(USER, "Non-positive number of columns");
| 115 |
if (fname == NULL)
| 116 |
fname = "<stdin>";
| 117 |
else if ((fp = fopen(fname, "r")) == NULL) {
| 118 |
sprintf(errmsg, "cannot open file '%s'", fname);
| 119 |
error(SYSTEM, errmsg);
| 120 |
| 121 |
#ifdef getc_unlocked
| 122 |
flockfile(fp);
| 123 |
#endif
| 124 |
if (dtype != DTascii)
| 125 |
SET_FILE_BINARY(fp); /* doesn't really work */
| 126 |
if (dtype == DTfromHeader)
| 127 |
dtype = getDTfromHeader(fp);
| 128 |
switch (dtype) {
| 129 |
case DTascii:
| 130 |
case DTfloat:
| 131 |
case DTdouble:
| 132 |
break;
| 133 |
default:
| 134 |
error(USER, "unexpected data type in cm_load()");
| 135 |
| 136 |
if (nrows <= 0) { /* don't know length? */
| 137 |
int guessrows = 147; /* usually big enough */
| 138 |
if ((dtype != DTascii) & (fp != stdin)) {
| 139 |
long startpos = ftell(fp);
| 140 |
if (fseek(fp, 0L, SEEK_END) == 0) {
| 141 |
long endpos = ftell(fp);
| 142 |
long elemsiz = 3*(dtype==DTfloat ?
| 143 |
sizeof(float) : sizeof(double));
| 144 |
| 145 |
if ((endpos - startpos) % (ncols*elemsiz)) {
| 146 |
sprintf(errmsg,
| 147 |
"improper length for binary file '%s'",
| 148 |
fname);
| 149 |
error(USER, errmsg);
| 150 |
| 151 |
guessrows = (endpos - startpos)/(ncols*elemsiz);
| 152 |
if (fseek(fp, startpos, SEEK_SET) < 0) {
| 153 |
sprintf(errmsg,
| 154 |
"fseek() error on file '%s'",
| 155 |
fname);
| 156 |
| 157 |
| 158 |
nrows = guessrows; /* we're confident */
| 159 |
| 160 |
| 161 |
cm = cm_alloc(guessrows, ncols);
| 162 |
} else
| 163 |
cm = cm_alloc(nrows, ncols);
| 164 |
if (cm == NULL) /* XXX never happens */
| 165 |
return(NULL);
| 166 |
if (dtype == DTascii) { /* read text file */
| 167 |
int maxrow = (nrows > 0 ? nrows : 32000);
| 168 |
int r, c;
| 169 |
for (r = 0; r < maxrow; r++) {
| 170 |
if (r >= cm->nrows) /* need more space? */
| 171 |
cm = cm_resize(cm, 2*cm->nrows);
| 172 |
for (c = 0; c < ncols; c++) {
| 173 |
COLORV *cv = cm_lval(cm,r,c);
| 174 |
if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3)
| 175 |
if ((nrows <= 0) & (r > 0) & !c) {
| 176 |
cm = cm_resize(cm, maxrow=r);
| 177 |
break;
| 178 |
} else
| 179 |
goto EOFerror;
| 180 |
| 181 |
| 182 |
while ((c = getc(fp)) != EOF)
| 183 |
if (!isspace(c)) {
| 184 |
sprintf(errmsg,
| 185 |
"unexpected data at end of ascii file %s",
| 186 |
fname);
| 187 |
error(WARNING, errmsg);
| 188 |
break;
| 189 |
| 190 |
} else { /* read binary file */
| 191 |
if (sizeof(COLORV) == (dtype==DTfloat ? sizeof(float) :
| 192 |
sizeof(double))) {
| 193 |
int nread = 0;
| 194 |
do { /* read all we can */
| 195 |
nread += fread(cm->cmem + 3*nread,
| 196 |
3*sizeof(COLORV),
| 197 |
cm->nrows*cm->ncols - nread,
| 198 |
fp);
| 199 |
if (nrows <= 0) { /* unknown length */
| 200 |
if (nread == cm->nrows*cm->ncols)
| 201 |
| 202 |
| 203 |
else if (nread && !(nread % cm->ncols))
| 204 |
/* seem to be done */
| 205 |
cm = cm_resize(cm, nread/cm->ncols);
| 206 |
else /* ended mid-row */
| 207 |
goto EOFerror;
| 208 |
} else if (nread < cm->nrows*cm->ncols)
| 209 |
goto EOFerror;
| 210 |
} while (nread < cm->nrows*cm->ncols);
| 211 |
| 212 |
} else if (dtype == DTdouble) {
| 213 |
double dc[3]; /* load from double */
| 214 |
COLORV *cvp = cm->cmem;
| 215 |
int n = nrows*ncols;
| 216 |
| 217 |
if (n <= 0)
| 218 |
goto not_handled;
| 219 |
while (n--) {
| 220 |
if (fread(dc, sizeof(double), 3, fp) != 3)
| 221 |
goto EOFerror;
| 222 |
copycolor(cvp, dc);
| 223 |
cvp += 3;
| 224 |
| 225 |
} else /* dtype == DTfloat */ {
| 226 |
float fc[3]; /* load from float */
| 227 |
| 228 |
| 229 |
| 230 |
if (n <= 0)
| 231 |
goto not_handled;
| 232 |
while (n--) {
| 233 |
if (fread(fc, sizeof(float), 3, fp) != 3)
| 234 |
goto EOFerror;
| 235 |
copycolor(cvp, fc);
| 236 |
cvp += 3;
| 237 |
| 238 |
| 239 |
if (fgetc(fp) != EOF) {
| 240 |
sprintf(errmsg,
| 241 |
"unexpected data at end of binary file %s",
| 242 |
fname);
| 243 |
| 244 |
| 245 |
| 246 |
if (fp != stdin)
| 247 |
fclose(fp);
| 248 |
| 249 |
else
| 250 |
funlockfile(fp);
| 251 |
#endif
| 252 |
return(cm);
| 253 |
EOFerror:
| 254 |
sprintf(errmsg, "unexpected EOF reading %s", fname);
| 255 |
| 256 |
not_handled:
| 257 |
error(INTERNAL, "unhandled data size or length in cm_load()");
| 258 |
return(NULL); /* gratis return */
| 259 |
| 260 |
| 261 |
/* Extract a column vector from a matrix */
| 262 |
static CMATRIX *
| 263 |
cm_column(const CMATRIX *cm, int c)
| 264 |
| 265 |
CMATRIX *cvr;
| 266 |
int dr;
| 267 |
| 268 |
if ((c < 0) | (c >= cm->ncols))
| 269 |
error(INTERNAL, "column requested outside matrix");
| 270 |
cvr = cm_alloc(cm->nrows, 1);
| 271 |
if (cvr == NULL)
| 272 |
return(NULL);
| 273 |
for (dr = 0; dr < cm->nrows; dr++) {
| 274 |
const COLORV *sp = cm_lval(cm,dr,c);
| 275 |
COLORV *dp = cv_lval(cvr,dr);
| 276 |
dp[0] = sp[0];
| 277 |
dp[1] = sp[1];
| 278 |
dp[2] = sp[2];
| 279 |
| 280 |
return(cvr);
| 281 |
| 282 |
| 283 |
/* Scale a matrix by a single value */
| 284 |
static CMATRIX *
| 285 |
cm_scale(const CMATRIX *cm1, const COLOR sca)
| 286 |
| 287 |
CMATRIX *cmr;
| 288 |
int dr, dc;
| 289 |
| 290 |
cmr = cm_alloc(cm1->nrows, cm1->ncols);
| 291 |
if (cmr == NULL)
| 292 |
return(NULL);
| 293 |
for (dr = 0; dr < cmr->nrows; dr++)
| 294 |
for (dc = 0; dc < cmr->ncols; dc++) {
| 295 |
const COLORV *sp = cm_lval(cm1,dr,dc);
| 296 |
COLORV *dp = cm_lval(cmr,dr,dc);
| 297 |
dp[0] = sp[0] * sca[0];
| 298 |
dp[1] = sp[1] * sca[1];
| 299 |
dp[2] = sp[2] * sca[2];
| 300 |
| 301 |
return(cmr);
| 302 |
| 303 |
| 304 |
/* Multiply two matrices (or a matrix and a vector) and allocate the result */
| 305 |
static CMATRIX *
| 306 |
cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
| 307 |
| 308 |
char *rowcheck=NULL, *colcheck=NULL;
| 309 |
CMATRIX *cmr;
| 310 |
int dr, dc, i;
| 311 |
| 312 |
if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
| 313 |
error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
| 314 |
cmr = cm_alloc(cm1->nrows, cm2->ncols);
| 315 |
if (cmr == NULL)
| 316 |
return(NULL);
| 317 |
/* optimization: check for zero rows & cols */
| 318 |
if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
| 319 |
static const COLOR czero;
| 320 |
rowcheck = (char *)calloc(cmr->nrows, 1);
| 321 |
for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
| 322 |
for (dc = cm1->ncols; dc--; )
| 323 |
if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
| 324 |
rowcheck[dr] = 1;
| 325 |
break;
| 326 |
| 327 |
colcheck = (char *)calloc(cmr->ncols, 1);
| 328 |
for (dc = cm2->ncols*(colcheck != NULL); dc--; )
| 329 |
for (dr = cm2->nrows; dr--; )
| 330 |
if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
| 331 |
colcheck[dc] = 1;
| 332 |
break;
| 333 |
| 334 |
| 335 |
| 336 |
| 337 |
| 338 |
dp[0] = dp[1] = dp[2] = 0;
| 339 |
if (rowcheck != NULL && !rowcheck[dr])
| 340 |
continue;
| 341 |
if (colcheck != NULL && !colcheck[dc])
| 342 |
continue;
| 343 |
for (i = 0; i < cm1->ncols; i++) {
| 344 |
const COLORV *cp1 = cm_lval(cm1,dr,i);
| 345 |
const COLORV *cp2 = cm_lval(cm2,i,dc);
| 346 |
dp[0] += cp1[0] * cp2[0];
| 347 |
dp[1] += cp1[1] * cp2[1];
| 348 |
dp[2] += cp1[2] * cp2[2];
| 349 |
| 350 |
| 351 |
if (rowcheck != NULL) free(rowcheck);
| 352 |
if (colcheck != NULL) free(colcheck);
| 353 |
return(cmr);
| 354 |
| 355 |
| 356 |
/* print out matrix as ASCII text -- no header */
| 357 |
static void
| 358 |
cm_print(const CMATRIX *cm, FILE *fp)
| 359 |
| 360 |
int r, c;
| 361 |
const COLORV *mp = cm->cmem;
| 362 |
| 363 |
for (r = 0; r < cm->nrows; r++) {
| 364 |
for (c = 0; c < cm->ncols; c++, mp += 3)
| 365 |
fprintf(fp, "\t%.6e %.6e %.6e", mp[0], mp[1], mp[2]);
| 366 |
fputc('\n', fp);
| 367 |
| 368 |
| 369 |
| 370 |
/* Convert a BSDF to our matrix representation */
| 371 |
static CMATRIX *
| 372 |
cm_bsdf(const COLOR bsdfLamb, const COLOR specCol, const SDMat *bsdf)
| 373 |
| 374 |
CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc);
| 375 |
int nbadohm = 0;
| 376 |
int nneg = 0;
| 377 |
int r, c;
| 378 |
/* loop over incident angles */
| 379 |
for (c = 0; c < cm->ncols; c++) {
| 380 |
const double dom = mBSDF_incohm(bsdf,c);
| 381 |
/* projected solid angle */
| 382 |
nbadohm += (dom <= 0);
| 383 |
| 384 |
| 385 |
float f = mBSDF_value(bsdf,c,r);
| 386 |
COLORV *mp = cm_lval(cm,r,c);
| 387 |
/* check BSDF value */
| 388 |
if ((f <= 0) | (dom <= 0)) {
| 389 |
nneg += (f < -FTINY);
| 390 |
f = .0f;
| 391 |
| 392 |
copycolor(mp, specCol);
| 393 |
scalecolor(mp, f);
| 394 |
addcolor(mp, bsdfLamb);
| 395 |
scalecolor(mp, dom);
| 396 |
| 397 |
| 398 |
if (nneg | nbadohm) {
| 399 |
sprintf(errmsg,
| 400 |
"BTDF has %d negatives and %d bad incoming solid angles",
| 401 |
nneg, nbadohm);
| 402 |
| 403 |
| 404 |
return(cm);
| 405 |
| 406 |
| 407 |
/* Convert between input and output indices for reciprocity */
| 408 |
static int
| 409 |
recip_out_from_in(const SDMat *bsdf, int in_recip)
| 410 |
| 411 |
FVECT v;
| 412 |
| 413 |
if (!mBSDF_incvec(v, bsdf, in_recip+.5))
| 414 |
return(in_recip); /* XXX should be error! */
| 415 |
v[2] = -v[2];
| 416 |
return(mBSDF_outndx(bsdf, v));
| 417 |
| 418 |
| 419 |
/* Convert between output and input indices for reciprocity */
| 420 |
static int
| 421 |
recip_in_from_out(const SDMat *bsdf, int out_recip)
| 422 |
| 423 |
FVECT v;
| 424 |
| 425 |
if (!mBSDF_outvec(v, bsdf, out_recip+.5))
| 426 |
return(out_recip); /* XXX should be error! */
| 427 |
v[2] = -v[2];
| 428 |
return(mBSDF_incndx(bsdf, v));
| 429 |
| 430 |
| 431 |
/* Convert a BSDF to our matrix representation, applying reciprocity */
| 432 |
static CMATRIX *
| 433 |
cm_bsdf_recip(const COLOR bsdfLamb, const COLOR specCol, const SDMat *bsdf)
| 434 |
| 435 |
CMATRIX *cm = cm_alloc(bsdf->ninc, bsdf->nout);
| 436 |
int nbadohm = 0;
| 437 |
int nneg = 0;
| 438 |
int r, c;
| 439 |
| 440 |
| 441 |
const int ro = recip_out_from_in(bsdf,c);
| 442 |
const double dom = mBSDF_outohm(bsdf,ro);
| 443 |
| 444 |
| 445 |
| 446 |
| 447 |
const int ri = recip_in_from_out(bsdf,r);
| 448 |
float f = mBSDF_value(bsdf,ri,ro);
| 449 |
| 450 |
| 451 |
| 452 |
| 453 |
f = .0f;
| 454 |
| 455 |
| 456 |
scalecolor(mp, f);
| 457 |
| 458 |
| 459 |
| 460 |
| 461 |
| 462 |
sprintf(errmsg,
| 463 |
| 464 |
nneg, nbadohm);
| 465 |
| 466 |
| 467 |
return(cm);
| 468 |
| 469 |
| 470 |
/* Load and convert a matrix BSDF from the given XML file */
| 471 |
static CMATRIX *
| 472 |
cm_loadBSDF(char *fname, COLOR cLamb)
| 473 |
| 474 |
CMATRIX *Tmat;
| 475 |
char *fpath;
| 476 |
int recip;
| 477 |
SDError ec;
| 478 |
SDData myBSDF;
| 479 |
SDSpectralDF *tdf;
| 480 |
COLOR bsdfLamb, specCol;
| 481 |
/* find path to BSDF file */
| 482 |
fpath = getpath(fname, getrlibpath(), R_OK);
| 483 |
if (fpath == NULL) {
| 484 |
sprintf(errmsg, "cannot find BSDF file '%s'", fname);
| 485 |
| 486 |
| 487 |
SDclearBSDF(&myBSDF, fname); /* load XML and check type */
| 488 |
ec = SDloadFile(&myBSDF, fpath);
| 489 |
if (ec)
| 490 |
error(USER, transSDError(ec));
| 491 |
ccy2rgb(&myBSDF.tLamb.spec, myBSDF.tLamb.cieY/PI, bsdfLamb);
| 492 |
recip = (myBSDF.tb == NULL);
| 493 |
tdf = recip ? myBSDF.tf : myBSDF.tb;
| 494 |
if (tdf == NULL) { /* no non-Lambertian transmission? */
| 495 |
if (cLamb != NULL)
| 496 |
copycolor(cLamb, bsdfLamb);
| 497 |
SDfreeBSDF(&myBSDF);
| 498 |
return(NULL);
| 499 |
| 500 |
if (tdf->ncomp != 1 || tdf->comp[0].func != &SDhandleMtx) {
| 501 |
sprintf(errmsg, "unsupported BSDF '%s'", fpath);
| 502 |
| 503 |
| 504 |
/* convert BTDF to matrix */
| 505 |
ccy2rgb(&tdf->comp[0].cspec[0], 1., specCol);
| 506 |
Tmat = recip ? cm_bsdf_recip(bsdfLamb, specCol, (SDMat *)tdf->comp[0].dist)
| 507 |
: cm_bsdf(bsdfLamb, specCol, (SDMat *)tdf->comp[0].dist);
| 508 |
if (cLamb != NULL) /* Lambertian is included */
| 509 |
setcolor(cLamb, .0, .0, .0);
| 510 |
/* free BSDF and return */
| 511 |
| 512 |
return(Tmat);
| 513 |
| 514 |
| 515 |
/* Sum together a set of images and write result to fout */
| 516 |
static int
| 517 |
sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
| 518 |
| 519 |
int myDT = DTfromHeader;
| 520 |
COLOR *scanline = NULL;
| 521 |
CMATRIX *pmat = NULL;
| 522 |
int myXR=0, myYR=0;
| 523 |
int i, y;
| 524 |
| 525 |
if (cv->ncols != 1)
| 526 |
error(INTERNAL, "expected vector in sum_images()");
| 527 |
for (i = 0; i < cv->nrows; i++) {
| 528 |
const COLORV *scv = cv_lval(cv,i);
| 529 |
char fname[1024];
| 530 |
FILE *fp;
| 531 |
int dt, xr, yr;
| 532 |
COLORV *psp;
| 533 |
/* check for zero */
| 534 |
if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
| 535 |
(myDT != DTfromHeader) | (i < cv->nrows-1))
| 536 |
continue;
| 537 |
/* open next picture */
| 538 |
sprintf(fname, fspec, i);
| 539 |
| 540 |
sprintf(errmsg, "cannot open picture '%s'", fname);
| 541 |
| 542 |
| 543 |
| 544 |
dt = getDTfromHeader(fp);
| 545 |
if ((dt != DTrgbe) & (dt != DTxyze) ||
| 546 |
!fscnresolu(&xr, &yr, fp)) {
| 547 |
sprintf(errmsg, "file '%s' not a picture", fname);
| 548 |
| 549 |
| 550 |
if (myDT == DTfromHeader) { /* on first one */
| 551 |
myDT = dt;
| 552 |
myXR = xr; myYR = yr;
| 553 |
scanline = (COLOR *)malloc(sizeof(COLOR)*myXR);
| 554 |
if (scanline == NULL)
| 555 |
error(SYSTEM, "out of memory in sum_images()");
| 556 |
pmat = cm_alloc(myYR, myXR);
| 557 |
memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
| 558 |
/* finish header */
| 559 |
fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, fout);
| 560 |
fputc('\n', fout);
| 561 |
fprtresolu(myXR, myYR, fout);
| 562 |
fflush(fout);
| 563 |
} else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
| 564 |
sprintf(errmsg, "picture '%s' format/size mismatch",
| 565 |
fname);
| 566 |
| 567 |
| 568 |
psp = pmat->cmem;
| 569 |
for (y = 0; y < yr; y++) { /* read it in */
| 570 |
int x;
| 571 |
if (freadscan(scanline, xr, fp) < 0) {
| 572 |
sprintf(errmsg, "error reading picture '%s'",
| 573 |
fname);
| 574 |
| 575 |
| 576 |
/* sum in scanline */
| 577 |
for (x = 0; x < xr; x++, psp += 3) {
| 578 |
multcolor(scanline[x], scv);
| 579 |
addcolor(psp, scanline[x]);
| 580 |
| 581 |
| 582 |
fclose(fp); /* done this picture */
| 583 |
| 584 |
free(scanline);
| 585 |
/* write scanlines */
| 586 |
for (y = 0; y < myYR; y++)
| 587 |
if (fwritescan((COLOR *)cm_lval(pmat, y, 0), myXR, fout) < 0)
| 588 |
return(0);
| 589 |
cm_free(pmat); /* all done */
| 590 |
return(fflush(fout) == 0);
| 591 |
| 592 |
| 593 |
/* check to see if a string contains a %d or %o specification */
| 594 |
static int
| 595 |
hasNumberFormat(const char *s)
| 596 |
| 597 |
if (s == NULL)
| 598 |
return(0);
| 599 |
| 600 |
while (*s) {
| 601 |
while (*s != '%')
| 602 |
if (!*s++)
| 603 |
return(0);
| 604 |
if (*++s == '%') { /* ignore "%%" */
| 605 |
++s;
| 606 |
continue;
| 607 |
| 608 |
while (isdigit(*s)) /* field length */
| 609 |
++s;
| 610 |
/* field we'll use? */
| 611 |
if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
| 612 |
(*s == 'x') | (*s == 'X'))
| 613 |
return(1);
| 614 |
| 615 |
return(0); /* didn't find one */
| 616 |
| 617 |
| 618 |
int
| 619 |
main(int argc, char *argv[])
| 620 |
| 621 |
int skyfmt = DTascii;
| 622 |
int nsteps = 1;
| 623 |
char *ofspec = NULL;
| 624 |
FILE *ofp = stdout;
| 625 |
CMATRIX *cmtx; /* component vector/matrix result */
| 626 |
char fnbuf[256];
| 627 |
int a, i;
| 628 |
| 629 |
progname = argv[0];
| 630 |
/* get options */
| 631 |
for (a = 1; a < argc && argv[a][0] == '-'; a++)
| 632 |
switch (argv[a][1]) {
| 633 |
case 'n':
| 634 |
nsteps = atoi(argv[++a]);
| 635 |
if (nsteps <= 0)
| 636 |
goto userr;
| 637 |
break;
| 638 |
case 'o':
| 639 |
ofspec = argv[++a];
| 640 |
break;
| 641 |
case 'i':
| 642 |
switch (argv[a][2]) {
| 643 |
case 'f':
| 644 |
skyfmt = DTfloat;
| 645 |
break;
| 646 |
case 'd':
| 647 |
skyfmt = DTdouble;
| 648 |
break;
| 649 |
case 'a':
| 650 |
skyfmt = DTascii;
| 651 |
break;
| 652 |
default:
| 653 |
goto userr;
| 654 |
| 655 |
break;
| 656 |
default:
| 657 |
goto userr;
| 658 |
| 659 |
if ((argc-a < 1) | (argc-a > 4))
| 660 |
goto userr;
| 661 |
| 662 |
if (argc-a > 2) { /* VTDs expression */
| 663 |
CMATRIX *smtx, *Dmat, *Tmat, *imtx;
| 664 |
COLOR tLamb;
| 665 |
/* get sky vector/matrix */
| 666 |
smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
| 667 |
/* load BSDF */
| 668 |
Tmat = cm_loadBSDF(argv[a+1], tLamb);
| 669 |
/* load Daylight matrix */
| 670 |
Dmat = cm_load(argv[a+2], Tmat==NULL ? 0 : Tmat->ncols,
| 671 |
smtx->nrows, DTfromHeader);
| 672 |
/* multiply vector through */
| 673 |
imtx = cm_multiply(Dmat, smtx);
| 674 |
cm_free(Dmat); cm_free(smtx);
| 675 |
if (Tmat == NULL) { /* diffuse only */
| 676 |
cmtx = cm_scale(imtx, tLamb);
| 677 |
} else { /* else apply BTDF matrix */
| 678 |
cmtx = cm_multiply(Tmat, imtx);
| 679 |
cm_free(Tmat);
| 680 |
| 681 |
cm_free(imtx);
| 682 |
} else { /* sky vector/matrix only */
| 683 |
cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
| 684 |
| 685 |
/* prepare output stream */
| 686 |
if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
| 687 |
sprintf(fnbuf, ofspec, 1);
| 688 |
ofspec = fnbuf;
| 689 |
| 690 |
if (ofspec != NULL && !hasNumberFormat(ofspec)) {
| 691 |
if ((ofp = fopen(ofspec, "w")) == NULL) {
| 692 |
fprintf(stderr, "%s: cannot open '%s' for output\n",
| 693 |
progname, ofspec);
| 694 |
return(1);
| 695 |
| 696 |
ofspec = NULL; /* only need to open once */
| 697 |
| 698 |
if (hasNumberFormat(argv[a])) { /* generating image(s) */
| 699 |
if (ofspec == NULL) {
| 700 |
SET_FILE_BINARY(ofp);
| 701 |
newheader("RADIANCE", ofp);
| 702 |
printargs(argc, argv, ofp);
| 703 |
fputnow(ofp);
| 704 |
| 705 |
if (nsteps > 1) /* multiple output frames? */
| 706 |
for (i = 0; i < nsteps; i++) {
| 707 |
CMATRIX *cvec = cm_column(cmtx, i);
| 708 |
if (ofspec != NULL) {
| 709 |
sprintf(fnbuf, ofspec, i+1);
| 710 |
if ((ofp = fopen(fnbuf, "wb")) == NULL) {
| 711 |
fprintf(stderr,
| 712 |
| 713 |
progname, fnbuf);
| 714 |
return(1);
| 715 |
| 716 |
| 717 |
| 718 |
fputnow(ofp);
| 719 |
| 720 |
fprintf(ofp, "FRAME=%d\n", i+1);
| 721 |
if (!sum_images(argv[a], cvec, ofp))
| 722 |
return(1);
| 723 |
| 724 |
if (fclose(ofp) == EOF) {
| 725 |
fprintf(stderr,
| 726 |
"%s: error writing to '%s'\n",
| 727 |
progname, fnbuf);
| 728 |
return(1);
| 729 |
| 730 |
ofp = stdout;
| 731 |
| 732 |
cm_free(cvec);
| 733 |
| 734 |
else if (!sum_images(argv[a], cmtx, ofp))
| 735 |
return(1);
| 736 |
} else { /* generating vector/matrix */
| 737 |
CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
| 738 |
CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
| 739 |
cm_free(Vmat);
| 740 |
if (ofspec != NULL) /* multiple vector files? */
| 741 |
| 742 |
CMATRIX *rvec = cm_column(rmtx, i);
| 743 |
| 744 |
if ((ofp = fopen(fnbuf, "w")) == NULL) {
| 745 |
fprintf(stderr,
| 746 |
| 747 |
progname, fnbuf);
| 748 |
return(1);
| 749 |
| 750 |
cm_print(rvec, ofp);
| 751 |
| 752 |
fprintf(stderr,
| 753 |
| 754 |
progname, fnbuf);
| 755 |
return(1);
| 756 |
| 757 |
ofp = stdout;
| 758 |
cm_free(rvec);
| 759 |
| 760 |
else
| 761 |
cm_print(rmtx, ofp);
| 762 |
cm_free(rmtx);
| 763 |
| 764 |
if (fflush(ofp) == EOF) { /* final clean-up */
| 765 |
fprintf(stderr, "%s: write error on output\n", progname);
| 766 |
return(1);
| 767 |
| 768 |
cm_free(cmtx);
| 769 |
return(0);
| 770 |
userr:
| 771 |
fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d}] DCspec [skyf]\n",
| 772 |
progname);
| 773 |
fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d}] Vspec Tbsdf.xml Dmat.dat [skyf]\n",
| 774 |
progname);
| 775 |
return(1);
| 776 |
