root/radiance/ray/src/util/dctimestep.c
Revision: 2.36
Committed: Tue Jul 14 16:08:28 2015 UTC (8 years, 11 months ago) by greg
Changes since 2.35: +11 -5 lines
Added ability for dctimestep to accept matrix files in place of XML for T
2 static const char RCSid[] = "$Id: dctimestep.c,v 2.35 2014/09/26 23:33:09 greg Exp $";
5 * Compute time-step result using Daylight Coefficient method.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "standard.h"
12 #include "cmatrix.h"
13 #include "platform.h"
14 #include "resolu.h"
15
16 char *progname; /* global argv[0] */
17
18 /* Sum together a set of images and write result to fout */
19 static int
20 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
21 {
22 int myDT = DTfromHeader;
23 COLOR *scanline = NULL;
24 CMATRIX *pmat = NULL;
25 int myXR=0, myYR=0;
26 int i, y;
27
28 if (cv->ncols != 1)
29 error(INTERNAL, "expected vector in sum_images()");
30 for (i = 0; i < cv->nrows; i++) {
31 const COLORV *scv = cv_lval(cv,i);
32 char fname[1024];
33 FILE *fp;
34 int dt, xr, yr;
35 COLORV *psp;
36 char *err;
37 /* check for zero */
38 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
39 (myDT != DTfromHeader) | (i < cv->nrows-1))
40 continue;
41 /* open next picture */
42 sprintf(fname, fspec, i);
43 if ((fp = fopen(fname, "rb")) == NULL) {
44 sprintf(errmsg, "cannot open picture '%s'", fname);
45 error(SYSTEM, errmsg);
46 }
47 dt = DTfromHeader;
48 if ((err = cm_getheader(&dt, NULL, NULL, fp)) != NULL)
49 error(USER, err);
50 if ((dt != DTrgbe) & (dt != DTxyze) ||
51 !fscnresolu(&xr, &yr, fp)) {
52 sprintf(errmsg, "file '%s' not a picture", fname);
53 error(USER, errmsg);
54 }
55 if (myDT == DTfromHeader) { /* on first one */
56 myDT = dt;
57 myXR = xr; myYR = yr;
58 scanline = (COLOR *)malloc(sizeof(COLOR)*myXR);
59 if (scanline == NULL)
60 error(SYSTEM, "out of memory in sum_images()");
61 pmat = cm_alloc(myYR, myXR);
62 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
63 /* finish header */
64 fputformat((char *)cm_fmt_id[myDT], fout);
65 fputc('\n', fout);
66 fflush(fout);
67 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
68 sprintf(errmsg, "picture '%s' format/size mismatch",
69 fname);
70 error(USER, errmsg);
71 }
72 psp = pmat->cmem;
73 for (y = 0; y < yr; y++) { /* read it in */
74 int x;
75 if (freadscan(scanline, xr, fp) < 0) {
76 sprintf(errmsg, "error reading picture '%s'",
77 fname);
78 error(SYSTEM, errmsg);
79 }
80 /* sum in scanline */
81 for (x = 0; x < xr; x++, psp += 3) {
82 multcolor(scanline[x], scv);
83 addcolor(psp, scanline[x]);
84 }
85 }
86 fclose(fp); /* done this picture */
87 }
88 free(scanline);
89 i = cm_write(pmat, myDT, fout); /* write picture */
90 cm_free(pmat); /* free data */
91 return(i);
92 }
93
94 /* check to see if a string contains a %d or %o specification */
95 static int
96 hasNumberFormat(const char *s)
97 {
98 if (s == NULL)
99 return(0);
100
101 while (*s) {
102 while (*s != '%')
103 if (!*s++)
104 return(0);
105 if (*++s == '%') { /* ignore "%%" */
106 ++s;
107 continue;
108 }
109 while (isdigit(*s)) /* field length */
110 ++s;
111 /* field we'll use? */
112 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
113 (*s == 'x') | (*s == 'X'))
114 return(1);
115 }
116 return(0); /* didn't find one */
117 }
118
119 int
120 main(int argc, char *argv[])
121 {
122 int skyfmt = DTfromHeader;
123 int outfmt = DTascii;
124 int headout = 1;
125 int nsteps = 0;
126 char *ofspec = NULL;
127 FILE *ofp = stdout;
128 CMATRIX *cmtx; /* component vector/matrix result */
129 char fnbuf[256];
130 int a, i;
131
132 progname = argv[0];
133 /* get options */
134 for (a = 1; a < argc && argv[a][0] == '-'; a++)
135 switch (argv[a][1]) {
136 case 'n':
137 nsteps = atoi(argv[++a]);
138 if (nsteps < 0)
139 goto userr;
140 skyfmt = nsteps ? DTascii : DTfromHeader;
141 break;
142 case 'h':
143 headout = !headout;
144 break;
145 case 'i':
146 switch (argv[a][2]) {
147 case 'f':
148 skyfmt = DTfloat;
149 break;
150 case 'd':
151 skyfmt = DTdouble;
152 break;
153 case 'a':
154 skyfmt = DTascii;
155 break;
156 default:
157 goto userr;
158 }
159 break;
160 case 'o':
161 switch (argv[a][2]) {
162 case '\0': /* output specification (not format) */
163 ofspec = argv[++a];
164 break;
165 case 'f':
166 outfmt = DTfloat;
167 break;
168 case 'd':
169 outfmt = DTdouble;
170 break;
171 case 'a':
172 outfmt = DTascii;
173 break;
174 default:
175 goto userr;
176 }
177 break;
178 default:
179 goto userr;
180 }
181 if ((argc-a < 1) | (argc-a > 4))
182 goto userr;
183
184 if (argc-a > 2) { /* VTDs expression */
185 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
186 const char *ccp;
187 /* get sky vector/matrix */
188 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
189 nsteps = smtx->ncols;
190 /* load BSDF */
191 if (argv[a+1][0] != '!' &&
192 (ccp = strrchr(argv[a+1], '.')) != NULL &&
193 !strcasecmp(ccp+1, "XML"))
194 Tmat = cm_loadBTDF(argv[a+1]);
195 else
196 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
197 /* load Daylight matrix */
198 Dmat = cm_load(argv[a+2], Tmat->ncols,
199 smtx->nrows, DTfromHeader);
200 /* multiply vector through */
201 imtx = cm_multiply(Dmat, smtx);
202 cm_free(Dmat); cm_free(smtx);
203 cmtx = cm_multiply(Tmat, imtx);
204 cm_free(Tmat);
205 cm_free(imtx);
206 } else { /* sky vector/matrix only */
207 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
208 nsteps = cmtx->ncols;
209 }
210 /* prepare output stream */
211 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
212 sprintf(fnbuf, ofspec, 1);
213 ofspec = fnbuf;
214 }
215 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
216 if ((ofp = fopen(ofspec, "w")) == NULL) {
217 fprintf(stderr, "%s: cannot open '%s' for output\n",
218 progname, ofspec);
219 return(1);
220 }
221 ofspec = NULL; /* only need to open once */
222 }
223 if (hasNumberFormat(argv[a])) { /* generating image(s) */
224 if (ofspec == NULL) {
225 SET_FILE_BINARY(ofp);
226 newheader("RADIANCE", ofp);
227 printargs(argc, argv, ofp);
228 fputnow(ofp);
229 }
230 if (nsteps > 1) /* multiple output frames? */
231 for (i = 0; i < nsteps; i++) {
232 CMATRIX *cvec = cm_column(cmtx, i);
233 if (ofspec != NULL) {
234 sprintf(fnbuf, ofspec, i+1);
235 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
236 fprintf(stderr,
237 "%s: cannot open '%s' for output\n",
238 progname, fnbuf);
239 return(1);
240 }
241 newheader("RADIANCE", ofp);
242 printargs(argc, argv, ofp);
243 fputnow(ofp);
244 }
245 fprintf(ofp, "FRAME=%d\n", i+1);
246 if (!sum_images(argv[a], cvec, ofp))
247 return(1);
248 if (ofspec != NULL) {
249 if (fclose(ofp) == EOF) {
250 fprintf(stderr,
251 "%s: error writing to '%s'\n",
252 progname, fnbuf);
253 return(1);
254 }
255 ofp = stdout;
256 }
257 cm_free(cvec);
258 }
259 else if (!sum_images(argv[a], cmtx, ofp))
260 return(1);
261 } else { /* generating vector/matrix */
262 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
263 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
264 cm_free(Vmat);
265 if (ofspec != NULL) { /* multiple vector files? */
266 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
267 for (i = 0; i < nsteps; i++) {
268 CMATRIX *rvec = cm_column(rmtx, i);
269 sprintf(fnbuf, ofspec, i+1);
270 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
271 fprintf(stderr,
272 "%s: cannot open '%s' for output\n",
273 progname, fnbuf);
274 return(1);
275 }
276 #ifdef getc_unlocked
277 flockfile(ofp);
278 #endif
279 if (headout) { /* header output */
280 newheader("RADIANCE", ofp);
281 printargs(argc, argv, ofp);
282 fputnow(ofp);
283 fprintf(ofp, "FRAME=%d\n", i+1);
284 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
285 fputs("NCOLS=1\nNCOMP=3\n", ofp);
286 fputformat((char *)cm_fmt_id[outfmt], ofp);
287 fputc('\n', ofp);
288 }
289 cm_write(rvec, outfmt, ofp);
290 if (fclose(ofp) == EOF) {
291 fprintf(stderr,
292 "%s: error writing to '%s'\n",
293 progname, fnbuf);
294 return(1);
295 }
296 ofp = stdout;
297 cm_free(rvec);
298 }
299 } else {
300 #ifdef getc_unlocked
301 flockfile(ofp);
302 #endif
303 if (outfmt != DTascii)
304 SET_FILE_BINARY(ofp);
305 if (headout) { /* header output */
306 newheader("RADIANCE", ofp);
307 printargs(argc, argv, ofp);
308 fputnow(ofp);
309 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
310 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
311 fputs("NCOMP=3\n", ofp);
312 fputformat((char *)cm_fmt_id[outfmt], ofp);
313 fputc('\n', ofp);
314 }
315 cm_write(rmtx, outfmt, ofp);
316 }
317 cm_free(rmtx);
318 }
319 if (fflush(ofp) == EOF) { /* final clean-up */
320 fprintf(stderr, "%s: write error on output\n", progname);
321 return(1);
322 }
323 cm_free(cmtx);
324 return(0);
325 userr:
326 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n",
327 progname);
328 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n",
329 progname);
330 return(1);
331 }
