Fixed bug in handling of sky matrices with default -n 0
Added number of rows to dctimestep output and rmtxop to cmake build
Fixed usage message
Fixed improper handling of diffuse transmission matrix
Improved efficiency of large matrix multiplications containing zero vectors
Minor fix in unreachable error
Fixed bug using wrong side of BTDF (thanks to David G-M)
Fixed reciprocity calculation
Added support for "Transmission Front" data
Bug fix for all-zero sky vector and image output
Made format check a little more robust
Eliminated unused variable
Final fix to Klems angles -- I hope
Added check for zero components when adding images
Bug fix in last change
Made input image name format more flexible.
Minor tweaks
Fixed bug in previous change
Improved BSDF conversion efficiency
Added check against empty input
Changed order of matrix reading to fix size
Fixed problem in error reporting
Fixed conversion of BTDF to matrix
Improvements and bug fixes
