root/Development/ray/src/util/dcglare.c
Revision: 2.10
Committed: Sat Jun 7 05:09:46 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
2 static const char RCSid[] = "$Id: dcglare.c,v 2.9 2025/06/06 19:11:21 greg Exp $";
5 * Compute time-step glare using imageless DGP calculation method.
6 *
7 * N. Jones
8 */
9
10 /*
11 * Copyright (c) 2017-2019 Nathaniel Jones
12 *
13 * Permission is hereby granted, free of charge, to any person obtaining a copy
14 * of this software and associated documentation files (the "Software"), to deal
15 * in the Software without restriction, including without limitation the rights
16 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
17 * copies of the Software, and to permit persons to whom the Software is
18 * furnished to do so, subject to the following conditions:
19 *
20 * The above copyright notice and this permission notice shall be included in all
21 * copies or substantial portions of the Software.
22 *
23 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
24 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
25 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
26 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
27 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
28 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
29 * SOFTWARE.
30 */
31
32 #include <ctype.h>
33 #include "platform.h"
34 #include "standard.h"
35 #include "cmatrix.h"
36 #include "resolu.h"
37 #include "cmglare.h"
38
39 /* Sum together a set of images and write result to fout */
40 static int
41 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
42 {
43 int myDT = DTfromHeader;
44 COLR *scanline = NULL;
45 CMATRIX *pmat = NULL;
46 int myXR=0, myYR=0;
47 int i, y;
48
49 if (cv->ncols != 1)
50 error(INTERNAL, "expected vector in sum_images()");
51 for (i = 0; i < cv->nrows; i++) {
52 const COLORV *scv = cv_lval(cv,i);
53 int flat_file = 0;
54 char fname[1024];
55 FILE *fp;
56 long data_start;
57 int dt, xr, yr;
58 COLORV *psp;
59 char *err;
60 /* check for zero */
61 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
62 (myDT != DTfromHeader) | (i < cv->nrows-1))
63 continue;
64 /* open next picture */
65 sprintf(fname, fspec, i);
66 if ((fp = fopen(fname, "rb")) == NULL) {
67 sprintf(errmsg, "cannot open picture '%s'", fname);
68 error(SYSTEM, errmsg);
69 }
70 dt = DTfromHeader;
71 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
72 error(USER, err);
73 if ((dt != DTrgbe) & (dt != DTxyze) ||
74 !fscnresolu(&xr, &yr, fp)) {
75 sprintf(errmsg, "file '%s' not a picture", fname);
76 error(USER, errmsg);
77 }
78 if (myDT == DTfromHeader) { /* on first one */
79 myDT = dt;
80 myXR = xr; myYR = yr;
81 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
82 if (scanline == NULL)
83 error(SYSTEM, "out of memory in sum_images()");
84 pmat = cm_alloc(myYR, myXR);
85 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
86 /* finish header */
87 fputformat(cm_fmt_id[myDT], fout);
88 fputc('\n', fout);
89 fflush(fout);
90 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
91 sprintf(errmsg, "picture '%s' format/size mismatch",
92 fname);
93 error(USER, errmsg);
94 }
95 /* flat file check */
96 if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
97 flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr);
98 if (fseek(fp, data_start, SEEK_SET) < 0) {
99 sprintf(errmsg, "cannot seek on picture '%s'", fname);
100 error(SYSTEM, errmsg);
101 }
102 }
103 psp = pmat->cmem;
104 for (y = 0; y < yr; y++) { /* read it in */
105 COLOR col;
106 int x;
107 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
108 freadcolrs(scanline, xr, fp) < 0) {
109 sprintf(errmsg, "error reading picture '%s'",
110 fname);
111 error(SYSTEM, errmsg);
112 }
113 /* sum in scanline */
114 for (x = 0; x < xr; x++, psp += 3) {
115 if (!scanline[x][EXP])
116 continue; /* skip zeroes */
117 colr_color(col, scanline[x]);
118 multcolor(col, scv);
119 addcolor(psp, col);
120 }
121 }
122 fclose(fp); /* done this picture */
123 }
124 free(scanline);
125 i = cm_write(pmat, myDT, fout); /* write picture */
126 cm_free(pmat); /* free data */
127 return(i);
128 }
129
130 /* check to see if a string contains a %d or %o specification */
131 static int
132 hasNumberFormat(const char *s)
133 {
134 if (s == NULL)
135 return(0);
136
137 while (*s) {
138 while (*s != '%')
139 if (!*s++)
140 return(0);
141 if (*++s == '%') { /* ignore "%%" */
142 ++s;
143 continue;
144 }
145 while (isdigit(*s)) /* field length */
146 ++s;
147 /* field we'll use? */
148 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
149 (*s == 'x') | (*s == 'X'))
150 return(1);
151 }
152 return(0); /* didn't find one */
153 }
154
155 int
156 main(int argc, char *argv[])
157 {
158 int skyfmt = DTfromHeader;
159 int outfmt = DTascii;
160 int headout = 1;
161 int nsteps = 0;
162 char *ofspec = NULL;
163 FILE *ofp = stdout;
164 CMATRIX *cmtx; /* component vector/matrix result */
165 char fnbuf[256];
166 int a, i;
167 #ifdef DC_GLARE
168 char *direct_path = NULL;
169 char *schedule_path = NULL;
170 int *occupancy = NULL;
171 int start_hour = 0;
172 int end_hour = 24;
173 double dgp_limit = -1;
174 double dgp_threshold = 2000;
175 char *view_path = NULL;
176 FILE *fp;
177 float *dgp_values = NULL;
178 FVECT vdir, vup;
179 FVECT *views = NULL;
180 int viewfmt = DTascii;
181
182 vdir[0] = vdir[1] = vdir[2] = vup[0] = vup[1] = 0;
183 vup[2] = 1;
184
185 clock_t timer = clock();
186 #endif /* DC_GLARE */
187
188 fixargv0(argv[0]);
189 /* get options */
190 for (a = 1; a < argc && argv[a][0] == '-'; a++)
191 switch (argv[a][1]) {
192 case 'n':
193 nsteps = atoi(argv[++a]);
194 if (nsteps < 0)
195 goto userr;
196 skyfmt = nsteps ? DTascii : DTfromHeader;
197 break;
198 case 'h':
199 headout = !headout;
200 break;
201 case 'i':
202 switch (argv[a][2]) {
203 case 'f':
204 skyfmt = DTfloat;
205 break;
206 case 'd':
207 skyfmt = DTdouble;
208 break;
209 case 'a':
210 skyfmt = DTascii;
211 break;
212 default:
213 goto userr;
214 }
215 break;
216 case 'o':
217 switch (argv[a][2]) {
218 #ifndef DC_GLARE
219 case '\0': /* output specification (not format) */
220 ofspec = argv[++a];
221 break;
222 #endif /* DC_GLARE */
223 case 'f':
224 outfmt = DTfloat;
225 break;
226 case 'd':
227 outfmt = DTdouble;
228 break;
229 case 'a':
230 outfmt = DTascii;
231 break;
232 default:
233 goto userr;
234 }
235 break;
236 #ifdef DC_GLARE
237 case 's':
238 switch (argv[a][2]) {
239 case 'f': /* occupancy schedule file */
240 schedule_path = argv[++a];
241 break;
242 case 's': /* occupancy start hour */
243 start_hour = atoi(argv[++a]);
244 break;
245 case 'e': /* occupancy end hour */
246 end_hour = atoi(argv[++a]);
247 break;
248 default:
249 goto userr;
250 }
251 break;
252 case 'l': /* perceptible glare threshold */
253 dgp_limit = atof(argv[++a]);
254 break;
255 case 'b': /* luminance threshold */
256 dgp_threshold = atof(argv[++a]);
257 break;
258 case 'v':
259 switch (argv[a][2]) {
260 case 'd': /* forward */
261 //check(3, "fff");
262 vdir[0] = atof(argv[++a]);
263 vdir[1] = atof(argv[++a]);
264 vdir[2] = atof(argv[++a]);
265 if (normalize(vdir) == 0.0) goto userr;
266 break;
267 case 'u': /* up */
268 //check(3, "fff");
269 vup[0] = atof(argv[++a]);
270 vup[1] = atof(argv[++a]);
271 vup[2] = atof(argv[++a]);
272 if (normalize(vup) == 0.0) goto userr;
273 break;
274 case 'f': /* view directions file */
275 //check(2, "s");
276 view_path = argv[++a];
277 break;
278 case 'i':
279 switch (argv[a][3]) {
280 case 'f':
281 viewfmt = DTfloat;
282 break;
283 case 'd':
284 viewfmt = DTdouble;
285 break;
286 case 'a':
287 viewfmt = DTascii;
288 break;
289 default:
290 goto userr;
291 }
292 default:
293 goto userr;
294 }
295 break;
296 #endif /* DC_GLARE */
297 default:
298 goto userr;
299 }
300 #ifdef DC_GLARE
301 if ((argc-a < 2) | (argc-a > 5))
302 goto userr;
303 /* single bounce daylight coefficients file */
304 direct_path = argv[a++];
305 #else
306 if ((argc-a < 1) | (argc-a > 4))
307 goto userr;
308 #endif /* DC_GLARE */
309
310 if (argc-a > 2) { /* VTDs expression */
311 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
312 const char *ccp;
313 /* get sky vector/matrix */
314 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
315 nsteps = smtx->ncols;
316 /* load BSDF */
317 if (argv[a+1][0] != '!' &&
318 (ccp = strrchr(argv[a+1], '.')) != NULL &&
319 !strcasecmp(ccp+1, "XML"))
320 Tmat = cm_loadBTDF(argv[a+1]);
321 else
322 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
323 /* load Daylight matrix */
324 Dmat = cm_load(argv[a+2], Tmat->ncols,
325 smtx->nrows, DTfromHeader);
326 /* multiply vector through */
327 imtx = cm_multiply(Dmat, smtx);
328 cm_free(Dmat); cm_free(smtx);
329 cmtx = cm_multiply(Tmat, imtx);
330 cm_free(Tmat);
331 cm_free(imtx);
332 } else { /* sky vector/matrix only */
333 //TIMER(timer, "read args");
334 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
335 nsteps = cmtx->ncols;
336 //TIMER(timer, "load sky matrix");
337 }
338 /* prepare output stream */
339 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
340 sprintf(fnbuf, ofspec, 1);
341 ofspec = fnbuf;
342 }
343 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
344 if ((ofp = fopen(ofspec, "w")) == NULL) {
345 fprintf(stderr, "%s: cannot open '%s' for output\n",
346 progname, ofspec);
347 return(1);
348 }
349 ofspec = NULL; /* only need to open once */
350 }
351 if (hasNumberFormat(argv[a])) { /* generating image(s) */
352 if (ofspec == NULL) {
353 SET_FILE_BINARY(ofp);
354 newheader("RADIANCE", ofp);
355 printargs(argc, argv, ofp);
356 fputnow(ofp);
357 }
358 if (nsteps > 1) /* multiple output frames? */
359 for (i = 0; i < nsteps; i++) {
360 CMATRIX *cvec = cm_column(cmtx, i);
361 if (ofspec != NULL) {
362 sprintf(fnbuf, ofspec, i);
363 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
364 fprintf(stderr,
365 "%s: cannot open '%s' for output\n",
366 progname, fnbuf);
367 return(1);
368 }
369 newheader("RADIANCE", ofp);
370 printargs(argc, argv, ofp);
371 fputnow(ofp);
372 }
373 fprintf(ofp, "FRAME=%d\n", i);
374 if (!sum_images(argv[a], cvec, ofp))
375 return(1);
376 if (ofspec != NULL) {
377 if (fclose(ofp) == EOF) {
378 fprintf(stderr,
379 "%s: error writing to '%s'\n",
380 progname, fnbuf);
381 return(1);
382 }
383 ofp = stdout;
384 }
385 cm_free(cvec);
386 }
387 else if (!sum_images(argv[a], cmtx, ofp))
388 return(1);
389 } else { /* generating vector/matrix */
390 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
391 //TIMER(timer, "load view matrix");
392 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
393 //TIMER(timer, "multiply");
394 cm_free(Vmat);
395 #ifdef DC_GLARE
396 if (direct_path) { /* Do glare autonomy calculation */
397 /* Load occupancy schedule */
398 occupancy = (int*)malloc(nsteps * sizeof(int));
399 if (!occupancy) {
400 fprintf(stderr,
401 "%s: out of memory for schedule\n",
402 progname);
403 return(1);
404 }
405 if (schedule_path) {
406 if ((fp = fopen(schedule_path, "r")) == NULL) {
407 fprintf(stderr,
408 "%s: cannot open input file \"%s\"\n",
409 progname, schedule_path);
410 return(1);
411 }
412 if (cm_load_schedule(nsteps, occupancy, fp) < 0) return(1);
413 }
414 else {
415 for (i = 0; i < nsteps; i++) {
416 /* Assume hourly spacing */
417 int hour = i % 24;
418 occupancy[i] = ((hour >= start_hour) & (hour < end_hour));
419 }
420 }
421 //TIMER(timer, "load occupancy schedule");
422
423 /* Load view directions */
424 if (view_path == NULL) {
425 if (vdir[0] == 0.0f && vdir[1] == 0.0f && vdir[2] == 0.0f) {
426 fprintf(stderr,
427 "%s: missing view direction\n",
428 progname);
429 return(1);
430 }
431 }
432 else {
433 if ((fp = fopen(view_path, "r")) == NULL) {
434 fprintf(stderr,
435 "%s: cannot open input file \"%s\"\n",
436 progname, view_path);
437 return(1);
438 }
439 if (viewfmt != DTascii)
440 SET_FILE_BINARY(fp);
441 views = cm_load_views(rmtx->nrows, viewfmt, fp);
442 if (!views) return(1);
443 //TIMER(timer, "load views");
444 }
445
446 /* Calculate glare values */
447 Vmat = cm_load(direct_path, 0, cmtx->nrows, DTfromHeader);
448 //TIMER(timer, "load direct matrix");
449 dgp_values = cm_glare(Vmat, rmtx, cmtx, occupancy, dgp_limit, dgp_threshold, views, vdir, vup);
450 //TIMER(timer, "calculate dgp");
451 free(views);
452 cm_free(Vmat);
453
454 /* Check successful calculation */
455 if (!dgp_values) return(1);
456 }
457 #endif /* DC_GLARE */
458 if (ofspec != NULL) { /* multiple vector files? */
459 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
460 for (i = 0; i < nsteps; i++) {
461 CMATRIX *rvec = cm_column(rmtx, i);
462 sprintf(fnbuf, ofspec, i);
463 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
464 fprintf(stderr,
465 "%s: cannot open '%s' for output\n",
466 progname, fnbuf);
467 return(1);
468 }
469 #ifdef getc_unlocked
470 flockfile(ofp);
471 #endif
472 if (headout) { /* header output */
473 newheader("RADIANCE", ofp);
474 printargs(argc, argv, ofp);
475 fputnow(ofp);
476 fprintf(ofp, "FRAME=%d\n", i);
477 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
478 fputs("NCOLS=1\nNCOMP=3\n", ofp);
479 if ((outfmt == DTfloat) | (outfmt == DTdouble))
480 fputendian(ofp);
481 fputformat(cm_fmt_id[outfmt], ofp);
482 fputc('\n', ofp);
483 }
484 cm_write(rvec, outfmt, ofp);
485 if (fclose(ofp) == EOF) {
486 fprintf(stderr,
487 "%s: error writing to '%s'\n",
488 progname, fnbuf);
489 return(1);
490 }
491 ofp = stdout;
492 cm_free(rvec);
493 }
494 } else {
495 #ifdef getc_unlocked
496 flockfile(ofp);
497 #endif
498 if (outfmt != DTascii)
499 SET_FILE_BINARY(ofp);
500 if (headout) { /* header output */
501 newheader("RADIANCE", ofp);
502 printargs(argc, argv, ofp);
503 fputnow(ofp);
504 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
505 #ifdef DC_GLARE
506 fprintf(ofp, "NCOLS=%d\n", (!dgp_values || dgp_limit < 0) ? rmtx->ncols : 1);
507 fprintf(ofp, "NCOMP=%d\n", dgp_values ? 1 : 3);
508 #else
509 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
510 fputs("NCOMP=3\n", ofp);
511 #endif /* DC_GLARE */
512 if ((outfmt == DTfloat) | (outfmt == DTdouble))
513 fputendian(ofp);
514 fputformat(cm_fmt_id[outfmt], ofp);
515 fputc('\n', ofp);
516 }
517 #ifdef DC_GLARE
518 if (dgp_values) { /* Write glare autonomy */
519 cm_write_glare(dgp_values, rmtx->nrows, dgp_limit < 0 ? rmtx->ncols : 1, outfmt, ofp);
520 free(dgp_values);
521 //TIMER(timer, "write");
522 }
523 else
524 #endif /* DC_GLARE */
525 cm_write(rmtx, outfmt, ofp);
526 }
527 cm_free(rmtx);
528 }
529 if (fflush(ofp) == EOF) { /* final clean-up */
530 fprintf(stderr, "%s: write error on output\n", progname);
531 return(1);
532 }
533 cm_free(cmtx);
534 return(0);
535 userr:
536 #ifdef DC_GLARE
537 fprintf(stderr, "Usage: %s [-n nsteps][-i{f|d|h}][-o{f|d}][-l limit][-b threshold][{-sf occupancy|-ss start -se end}]{-vf views [-vi{f|d}]|-vd x y z}[-vu x y z] DCdirect DCtotal [skyf]\n",
538 progname);
539 fprintf(stderr, " or: %s [-n nsteps][-i{f|d|h}][-o{f|d}][-l limit][-b threshold][{-sf occupancy|-ss start -se end}]{-vf views [-vi{f|d}]|-vd x y z}[-vu x y z] DCdirect Vspec Tbsdf Dmat.dat [skyf]\n",
540 progname);
541 #else
542 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n",
543 progname);
544 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n",
545 progname);
546 #endif /* DC_GLARE */
547 return(1);
548 }
