root/radiance/ray/src/util/dcglare.c
Revision: 2.3
Committed: Wed Mar 25 01:51:09 2020 UTC (4 years, 1 month ago) by greg
1 /*
2 * Compute time-step glare using imageless DGP calculation method.
3 *
4 * N. Jones
5 */
6
7 /*
8 * Copyright (c) 2017-2019 Nathaniel Jones
9 *
10 * Permission is hereby granted, free of charge, to any person obtaining a copy
11 * of this software and associated documentation files (the "Software"), to deal
12 * in the Software without restriction, including without limitation the rights
13 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
14 * copies of the Software, and to permit persons to whom the Software is
15 * furnished to do so, subject to the following conditions:
16 *
17 * The above copyright notice and this permission notice shall be included in all
18 * copies or substantial portions of the Software.
19 *
20 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
21 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
22 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
23 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
24 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
25 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
26 * SOFTWARE.
27 */
28
29 #include <ctype.h>
30 #include "platform.h"
31 #include "standard.h"
32 #include "cmatrix.h"
33 #include "resolu.h"
34 #include "cmglare.h"
35
36 char *progname; /* global argv[0] */
37
38 /* Sum together a set of images and write result to fout */
39 static int
40 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
41 {
42 int myDT = DTfromHeader;
43 COLR *scanline = NULL;
44 CMATRIX *pmat = NULL;
45 int myXR=0, myYR=0;
46 int i, y;
47
48 if (cv->ncols != 1)
49 error(INTERNAL, "expected vector in sum_images()");
50 for (i = 0; i < cv->nrows; i++) {
51 const COLORV *scv = cv_lval(cv,i);
52 int flat_file = 0;
53 char fname[1024];
54 FILE *fp;
55 long data_start;
56 int dt, xr, yr;
57 COLORV *psp;
58 char *err;
59 /* check for zero */
60 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
61 (myDT != DTfromHeader) | (i < cv->nrows-1))
62 continue;
63 /* open next picture */
64 sprintf(fname, fspec, i);
65 if ((fp = fopen(fname, "rb")) == NULL) {
66 sprintf(errmsg, "cannot open picture '%s'", fname);
67 error(SYSTEM, errmsg);
68 }
69 dt = DTfromHeader;
70 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
71 error(USER, err);
72 if ((dt != DTrgbe) & (dt != DTxyze) ||
73 !fscnresolu(&xr, &yr, fp)) {
74 sprintf(errmsg, "file '%s' not a picture", fname);
75 error(USER, errmsg);
76 }
77 if (myDT == DTfromHeader) { /* on first one */
78 myDT = dt;
79 myXR = xr; myYR = yr;
80 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
81 if (scanline == NULL)
82 error(SYSTEM, "out of memory in sum_images()");
83 pmat = cm_alloc(myYR, myXR);
84 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
85 /* finish header */
86 fputformat((char *)cm_fmt_id[myDT], fout);
87 fputc('\n', fout);
88 fflush(fout);
89 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
90 sprintf(errmsg, "picture '%s' format/size mismatch",
91 fname);
92 error(USER, errmsg);
93 }
94 /* flat file check */
95 if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
96 flat_file = (ftell(fp) == data_start + sizeof(COLR)*xr*yr);
97 if (fseek(fp, data_start, SEEK_SET) < 0) {
98 sprintf(errmsg, "cannot seek on picture '%s'", fname);
99 error(SYSTEM, errmsg);
100 }
101 }
102 psp = pmat->cmem;
103 for (y = 0; y < yr; y++) { /* read it in */
104 COLOR col;
105 int x;
106 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
107 freadcolrs(scanline, xr, fp) < 0) {
108 sprintf(errmsg, "error reading picture '%s'",
109 fname);
110 error(SYSTEM, errmsg);
111 }
112 /* sum in scanline */
113 for (x = 0; x < xr; x++, psp += 3) {
114 if (!scanline[x][EXP])
115 continue; /* skip zeroes */
116 colr_color(col, scanline[x]);
117 multcolor(col, scv);
118 addcolor(psp, col);
119 }
120 }
121 fclose(fp); /* done this picture */
122 }
123 free(scanline);
124 i = cm_write(pmat, myDT, fout); /* write picture */
125 cm_free(pmat); /* free data */
126 return(i);
127 }
128
129 /* check to see if a string contains a %d or %o specification */
130 static int
131 hasNumberFormat(const char *s)
132 {
133 if (s == NULL)
134 return(0);
135
136 while (*s) {
137 while (*s != '%')
138 if (!*s++)
139 return(0);
140 if (*++s == '%') { /* ignore "%%" */
141 ++s;
142 continue;
143 }
144 while (isdigit(*s)) /* field length */
145 ++s;
146 /* field we'll use? */
147 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
148 (*s == 'x') | (*s == 'X'))
149 return(1);
150 }
151 return(0); /* didn't find one */
152 }
153
154 int
155 main(int argc, char *argv[])
156 {
157 int skyfmt = DTfromHeader;
158 int outfmt = DTascii;
159 int headout = 1;
160 int nsteps = 0;
161 char *ofspec = NULL;
162 FILE *ofp = stdout;
163 CMATRIX *cmtx; /* component vector/matrix result */
164 char fnbuf[256];
165 int a, i;
166 #ifdef DC_GLARE
167 char *direct_path = NULL;
168 char *schedule_path = NULL;
169 int *occupancy = NULL;
170 int start_hour = 0;
171 int end_hour = 24;
172 double dgp_limit = -1;
173 double dgp_threshold = 2000;
174 char *view_path = NULL;
175 FILE *fp;
176 float *dgp_values = NULL;
177 FVECT vdir, vup;
178 FVECT *views = NULL;
179 int viewfmt = DTascii;
180
181 vdir[0] = vdir[1] = vdir[2] = vup[0] = vup[1] = 0;
182 vup[2] = 1;
183
184 clock_t timer = clock();
185 #endif /* DC_GLARE */
186
187 progname = argv[0];
188 /* get options */
189 for (a = 1; a < argc && argv[a][0] == '-'; a++)
190 switch (argv[a][1]) {
191 case 'n':
192 nsteps = atoi(argv[++a]);
193 if (nsteps < 0)
194 goto userr;
195 skyfmt = nsteps ? DTascii : DTfromHeader;
196 break;
197 case 'h':
198 headout = !headout;
199 break;
200 case 'i':
201 switch (argv[a][2]) {
202 case 'f':
203 skyfmt = DTfloat;
204 break;
205 case 'd':
206 skyfmt = DTdouble;
207 break;
208 case 'a':
209 skyfmt = DTascii;
210 break;
211 default:
212 goto userr;
213 }
214 break;
215 case 'o':
216 switch (argv[a][2]) {
217 #ifndef DC_GLARE
218 case '\0': /* output specification (not format) */
219 ofspec = argv[++a];
220 break;
221 #endif /* DC_GLARE */
222 case 'f':
223 outfmt = DTfloat;
224 break;
225 case 'd':
226 outfmt = DTdouble;
227 break;
228 case 'a':
229 outfmt = DTascii;
230 break;
231 default:
232 goto userr;
233 }
234 break;
235 #ifdef DC_GLARE
236 case 's':
237 switch (argv[a][2]) {
238 case 'f': /* occupancy schedule file */
239 schedule_path = argv[++a];
240 break;
241 case 's': /* occupancy start hour */
242 start_hour = atoi(argv[++a]);
243 break;
244 case 'e': /* occupancy end hour */
245 end_hour = atoi(argv[++a]);
246 break;
247 default:
248 goto userr;
249 }
250 break;
251 case 'l': /* perceptible glare threshold */
252 dgp_limit = atof(argv[++a]);
253 break;
254 case 'b': /* luminance threshold */
255 dgp_threshold = atof(argv[++a]);
256 break;
257 case 'v':
258 switch (argv[a][2]) {
259 case 'd': /* forward */
260 //check(3, "fff");
261 vdir[0] = atof(argv[++a]);
262 vdir[1] = atof(argv[++a]);
263 vdir[2] = atof(argv[++a]);
264 if (normalize(vdir) == 0.0) goto userr;
265 break;
266 case 'u': /* up */
267 //check(3, "fff");
268 vup[0] = atof(argv[++a]);
269 vup[1] = atof(argv[++a]);
270 vup[2] = atof(argv[++a]);
271 if (normalize(vup) == 0.0) goto userr;
272 break;
273 case 'f': /* view directions file */
274 //check(2, "s");
275 view_path = argv[++a];
276 break;
277 case 'i':
278 switch (argv[a][3]) {
279 case 'f':
280 viewfmt = DTfloat;
281 break;
282 case 'd':
283 viewfmt = DTdouble;
284 break;
285 case 'a':
286 viewfmt = DTascii;
287 break;
288 default:
289 goto userr;
290 }
291 default:
292 goto userr;
293 }
294 break;
295 #endif /* DC_GLARE */
296 default:
297 goto userr;
298 }
299 #ifdef DC_GLARE
300 if ((argc-a < 2) | (argc-a > 5))
301 goto userr;
302 /* single bounce daylight coefficients file */
303 direct_path = argv[++a];
304 #else
305 if ((argc-a < 1) | (argc-a > 4))
306 goto userr;
307 #endif /* DC_GLARE */
308
309 if (argc-a > 2) { /* VTDs expression */
310 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
311 const char *ccp;
312 /* get sky vector/matrix */
313 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
314 nsteps = smtx->ncols;
315 /* load BSDF */
316 if (argv[a+1][0] != '!' &&
317 (ccp = strrchr(argv[a+1], '.')) != NULL &&
318 !strcasecmp(ccp+1, "XML"))
319 Tmat = cm_loadBTDF(argv[a+1]);
320 else
321 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
322 /* load Daylight matrix */
323 Dmat = cm_load(argv[a+2], Tmat->ncols,
324 smtx->nrows, DTfromHeader);
325 /* multiply vector through */
326 imtx = cm_multiply(Dmat, smtx);
327 cm_free(Dmat); cm_free(smtx);
328 cmtx = cm_multiply(Tmat, imtx);
329 cm_free(Tmat);
330 cm_free(imtx);
331 } else { /* sky vector/matrix only */
332 //TIMER(timer, "read args");
333 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
334 nsteps = cmtx->ncols;
335 //TIMER(timer, "load sky matrix");
336 }
337 /* prepare output stream */
338 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
339 sprintf(fnbuf, ofspec, 1);
340 ofspec = fnbuf;
341 }
342 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
343 if ((ofp = fopen(ofspec, "w")) == NULL) {
344 fprintf(stderr, "%s: cannot open '%s' for output\n",
345 progname, ofspec);
346 return(1);
347 }
348 ofspec = NULL; /* only need to open once */
349 }
350 if (hasNumberFormat(argv[a])) { /* generating image(s) */
351 if (ofspec == NULL) {
352 SET_FILE_BINARY(ofp);
353 newheader("RADIANCE", ofp);
354 printargs(argc, argv, ofp);
355 fputnow(ofp);
356 }
357 if (nsteps > 1) /* multiple output frames? */
358 for (i = 0; i < nsteps; i++) {
359 CMATRIX *cvec = cm_column(cmtx, i);
360 if (ofspec != NULL) {
361 sprintf(fnbuf, ofspec, i);
362 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
363 fprintf(stderr,
364 "%s: cannot open '%s' for output\n",
365 progname, fnbuf);
366 return(1);
367 }
368 newheader("RADIANCE", ofp);
369 printargs(argc, argv, ofp);
370 fputnow(ofp);
371 }
372 fprintf(ofp, "FRAME=%d\n", i);
373 if (!sum_images(argv[a], cvec, ofp))
374 return(1);
375 if (ofspec != NULL) {
376 if (fclose(ofp) == EOF) {
377 fprintf(stderr,
378 "%s: error writing to '%s'\n",
379 progname, fnbuf);
380 return(1);
381 }
382 ofp = stdout;
383 }
384 cm_free(cvec);
385 }
386 else if (!sum_images(argv[a], cmtx, ofp))
387 return(1);
388 } else { /* generating vector/matrix */
389 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
390 //TIMER(timer, "load view matrix");
391 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
392 //TIMER(timer, "multiply");
393 cm_free(Vmat);
394 #ifdef DC_GLARE
395 if (direct_path) { /* Do glare autonomy calculation */
396 /* Load occupancy schedule */
397 occupancy = (int*)malloc(nsteps * sizeof(int));
398 if (!occupancy) {
399 fprintf(stderr,
400 "%s: out of memory for schedule\n",
401 progname);
402 return(1);
403 }
404 if (schedule_path) {
405 if ((fp = fopen(schedule_path, "r")) == NULL) {
406 fprintf(stderr,
407 "%s: cannot open input file \"%s\"\n",
408 progname, schedule_path);
409 return(1);
410 }
411 if (cm_load_schedule(nsteps, occupancy, fp) < 0) return(1);
412 }
413 else {
414 for (i = 0; i < nsteps; i++) {
415 /* Assume hourly spacing */
416 int hour = i % 24;
417 occupancy[i] = ((hour >= start_hour) & (hour < end_hour));
418 }
419 }
420 //TIMER(timer, "load occupancy schedule");
421
422 /* Load view directions */
423 if (view_path == NULL) {
424 if (vdir[0] == 0.0f && vdir[1] == 0.0f && vdir[2] == 0.0f) {
425 fprintf(stderr,
426 "%s: missing view direction\n",
427 progname);
428 return(1);
429 }
430 }
431 else {
432 if ((fp = fopen(view_path, "r")) == NULL) {
433 fprintf(stderr,
434 "%s: cannot open input file \"%s\"\n",
435 progname, view_path);
436 return(1);
437 }
438 if (viewfmt != DTascii)
439 SET_FILE_BINARY(fp);
440 views = cm_load_views(rmtx->nrows, viewfmt, fp);
441 if (!views) return(1);
442 //TIMER(timer, "load views");
443 }
444
445 /* Calculate glare values */
446 Vmat = cm_load(direct_path, 0, cmtx->nrows, DTfromHeader);
447 //TIMER(timer, "load direct matrix");
448 dgp_values = cm_glare(Vmat, rmtx, cmtx, occupancy, dgp_limit, dgp_threshold, views, vdir, vup);
449 //TIMER(timer, "calculate dgp");
450 free(views);
451 cm_free(Vmat);
452
453 /* Check successful calculation */
454 if (!dgp_values) return(1);
455 }
456 #endif /* DC_GLARE */
457 if (ofspec != NULL) { /* multiple vector files? */
458 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
459 for (i = 0; i < nsteps; i++) {
460 CMATRIX *rvec = cm_column(rmtx, i);
461 sprintf(fnbuf, ofspec, i);
462 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
463 fprintf(stderr,
464 "%s: cannot open '%s' for output\n",
465 progname, fnbuf);
466 return(1);
467 }
468 #ifdef getc_unlocked
469 flockfile(ofp);
470 #endif
471 if (headout) { /* header output */
472 newheader("RADIANCE", ofp);
473 printargs(argc, argv, ofp);
474 fputnow(ofp);
475 fprintf(ofp, "FRAME=%d\n", i);
476 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
477 fputs("NCOLS=1\nNCOMP=3\n", ofp);
478 if ((outfmt == 'f') | (outfmt == 'd'))
479 fputendian(ofp);
480 fputformat((char *)cm_fmt_id[outfmt], ofp);
481 fputc('\n', ofp);
482 }
483 cm_write(rvec, outfmt, ofp);
484 if (fclose(ofp) == EOF) {
485 fprintf(stderr,
486 "%s: error writing to '%s'\n",
487 progname, fnbuf);
488 return(1);
489 }
490 ofp = stdout;
491 cm_free(rvec);
492 }
493 } else {
494 #ifdef getc_unlocked
495 flockfile(ofp);
496 #endif
497 if (outfmt != DTascii)
498 SET_FILE_BINARY(ofp);
499 if (headout) { /* header output */
500 newheader("RADIANCE", ofp);
501 printargs(argc, argv, ofp);
502 fputnow(ofp);
503 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
504 #ifdef DC_GLARE
505 fprintf(ofp, "NCOLS=%d\n", (!dgp_values || dgp_limit < 0) ? rmtx->ncols : 1);
506 fprintf(ofp, "NCOMP=%d\n", dgp_values ? 1 : 3);
507 #else
508 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
509 fputs("NCOMP=3\n", ofp);
510 #endif /* DC_GLARE */
511 if ((outfmt == 'f') | (outfmt == 'd'))
512 fputendian(ofp);
513 fputformat((char *)cm_fmt_id[outfmt], ofp);
514 fputc('\n', ofp);
515 }
516 #ifdef DC_GLARE
517 if (dgp_values) { /* Write glare autonomy */
518 cm_write_glare(dgp_values, rmtx->nrows, dgp_limit < 0 ? rmtx->ncols : 1, outfmt, ofp);
519 free(dgp_values);
520 //TIMER(timer, "write");
521 }
522 else
523 #endif /* DC_GLARE */
524 cm_write(rmtx, outfmt, ofp);
525 }
526 cm_free(rmtx);
527 }
528 if (fflush(ofp) == EOF) { /* final clean-up */
529 fprintf(stderr, "%s: write error on output\n", progname);
530 return(1);
531 }
532 cm_free(cmtx);
533 return(0);
534 userr:
535 #ifdef DC_GLARE
536 fprintf(stderr, "Usage: %s [-n nsteps][-i{f|d|h}][-o{f|d}][-l limit][-b threshold][{-sf occupancy|-ss start -se end}]{-vf views [-vi{f|d}]|-vd x y z}[-vu x y z] DCdirect DCtotal [skyf]\n",
537 progname);
538 fprintf(stderr, " or: %s [-n nsteps][-i{f|d|h}][-o{f|d}][-l limit][-b threshold][{-sf occupancy|-ss start -se end}]{-vf views [-vi{f|d}]|-vd x y z}[-vu x y z] DCdirect Vspec Tbsdf Dmat.dat [skyf]\n",
539 progname);
540 #else
541 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n",
542 progname);
543 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n",
544 progname);
545 #endif /* DC_GLARE */
546 return(1);
547 }
