root/Development/ray/src/util/dcglare.c
Revision: 2.8
Committed: Wed Mar 5 02:59:58 2025 UTC (9 months ago) by greg
Changes since 2.7: +3 -0 lines
chore: Added missing RCSid
5 * Compute time-step glare using imageless DGP calculation method.
6 *
7 * N. Jones
8 */
9
10 /*
11 * Copyright (c) 2017-2019 Nathaniel Jones
12 *
13 * Permission is hereby granted, free of charge, to any person obtaining a copy
14 * of this software and associated documentation files (the "Software"), to deal
15 * in the Software without restriction, including without limitation the rights
16 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
17 * copies of the Software, and to permit persons to whom the Software is
18 * furnished to do so, subject to the following conditions:
19 *
20 * The above copyright notice and this permission notice shall be included in all
21 * copies or substantial portions of the Software.
22 *
23 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
24 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
25 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
26 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
27 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
28 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
29 * SOFTWARE.
30 */
31
32 #include <ctype.h>
33 #include "platform.h"
34 #include "standard.h"
35 #include "cmatrix.h"
36 #include "resolu.h"
37 #include "cmglare.h"
38
39 char *progname; /* global argv[0] */
40
41 /* Sum together a set of images and write result to fout */
42 static int
43 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
44 {
45 int myDT = DTfromHeader;
46 COLR *scanline = NULL;
47 CMATRIX *pmat = NULL;
48 int myXR=0, myYR=0;
49 int i, y;
50
51 if (cv->ncols != 1)
52 error(INTERNAL, "expected vector in sum_images()");
53 for (i = 0; i < cv->nrows; i++) {
54 const COLORV *scv = cv_lval(cv,i);
55 int flat_file = 0;
56 char fname[1024];
57 FILE *fp;
58 long data_start;
59 int dt, xr, yr;
60 COLORV *psp;
61 char *err;
62 /* check for zero */
63 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
64 (myDT != DTfromHeader) | (i < cv->nrows-1))
65 continue;
66 /* open next picture */
67 sprintf(fname, fspec, i);
68 if ((fp = fopen(fname, "rb")) == NULL) {
69 sprintf(errmsg, "cannot open picture '%s'", fname);
70 error(SYSTEM, errmsg);
71 }
72 dt = DTfromHeader;
73 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
74 error(USER, err);
75 if ((dt != DTrgbe) & (dt != DTxyze) ||
76 !fscnresolu(&xr, &yr, fp)) {
77 sprintf(errmsg, "file '%s' not a picture", fname);
78 error(USER, errmsg);
79 }
80 if (myDT == DTfromHeader) { /* on first one */
81 myDT = dt;
82 myXR = xr; myYR = yr;
83 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
84 if (scanline == NULL)
85 error(SYSTEM, "out of memory in sum_images()");
86 pmat = cm_alloc(myYR, myXR);
87 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
88 /* finish header */
89 fputformat(cm_fmt_id[myDT], fout);
90 fputc('\n', fout);
91 fflush(fout);
92 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
93 sprintf(errmsg, "picture '%s' format/size mismatch",
94 fname);
95 error(USER, errmsg);
96 }
97 /* flat file check */
98 if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
99 flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr);
100 if (fseek(fp, data_start, SEEK_SET) < 0) {
101 sprintf(errmsg, "cannot seek on picture '%s'", fname);
102 error(SYSTEM, errmsg);
103 }
104 }
105 psp = pmat->cmem;
106 for (y = 0; y < yr; y++) { /* read it in */
107 COLOR col;
108 int x;
109 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
110 freadcolrs(scanline, xr, fp) < 0) {
111 sprintf(errmsg, "error reading picture '%s'",
112 fname);
113 error(SYSTEM, errmsg);
114 }
115 /* sum in scanline */
116 for (x = 0; x < xr; x++, psp += 3) {
117 if (!scanline[x][EXP])
118 continue; /* skip zeroes */
119 colr_color(col, scanline[x]);
120 multcolor(col, scv);
121 addcolor(psp, col);
122 }
123 }
124 fclose(fp); /* done this picture */
125 }
126 free(scanline);
127 i = cm_write(pmat, myDT, fout); /* write picture */
128 cm_free(pmat); /* free data */
129 return(i);
130 }
131
132 /* check to see if a string contains a %d or %o specification */
133 static int
134 hasNumberFormat(const char *s)
135 {
136 if (s == NULL)
137 return(0);
138
139 while (*s) {
140 while (*s != '%')
141 if (!*s++)
142 return(0);
143 if (*++s == '%') { /* ignore "%%" */
144 ++s;
145 continue;
146 }
147 while (isdigit(*s)) /* field length */
148 ++s;
149 /* field we'll use? */
150 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
151 (*s == 'x') | (*s == 'X'))
152 return(1);
153 }
154 return(0); /* didn't find one */
155 }
156
157 int
158 main(int argc, char *argv[])
159 {
160 int skyfmt = DTfromHeader;
161 int outfmt = DTascii;
162 int headout = 1;
163 int nsteps = 0;
164 char *ofspec = NULL;
165 FILE *ofp = stdout;
166 CMATRIX *cmtx; /* component vector/matrix result */
167 char fnbuf[256];
168 int a, i;
169 #ifdef DC_GLARE
170 char *direct_path = NULL;
171 char *schedule_path = NULL;
172 int *occupancy = NULL;
173 int start_hour = 0;
174 int end_hour = 24;
175 double dgp_limit = -1;
176 double dgp_threshold = 2000;
177 char *view_path = NULL;
178 FILE *fp;
179 float *dgp_values = NULL;
180 FVECT vdir, vup;
181 FVECT *views = NULL;
182 int viewfmt = DTascii;
183
184 vdir[0] = vdir[1] = vdir[2] = vup[0] = vup[1] = 0;
185 vup[2] = 1;
186
187 clock_t timer = clock();
188 #endif /* DC_GLARE */
189
190 progname = argv[0];
191 /* get options */
192 for (a = 1; a < argc && argv[a][0] == '-'; a++)
193 switch (argv[a][1]) {
194 case 'n':
195 nsteps = atoi(argv[++a]);
196 if (nsteps < 0)
197 goto userr;
198 skyfmt = nsteps ? DTascii : DTfromHeader;
199 break;
200 case 'h':
201 headout = !headout;
202 break;
203 case 'i':
204 switch (argv[a][2]) {
205 case 'f':
206 skyfmt = DTfloat;
207 break;
208 case 'd':
209 skyfmt = DTdouble;
210 break;
211 case 'a':
212 skyfmt = DTascii;
213 break;
214 default:
215 goto userr;
216 }
217 break;
218 case 'o':
219 switch (argv[a][2]) {
220 #ifndef DC_GLARE
221 case '\0': /* output specification (not format) */
222 ofspec = argv[++a];
223 break;
224 #endif /* DC_GLARE */
225 case 'f':
226 outfmt = DTfloat;
227 break;
228 case 'd':
229 outfmt = DTdouble;
230 break;
231 case 'a':
232 outfmt = DTascii;
233 break;
234 default:
235 goto userr;
236 }
237 break;
238 #ifdef DC_GLARE
239 case 's':
240 switch (argv[a][2]) {
241 case 'f': /* occupancy schedule file */
242 schedule_path = argv[++a];
243 break;
244 case 's': /* occupancy start hour */
245 start_hour = atoi(argv[++a]);
246 break;
247 case 'e': /* occupancy end hour */
248 end_hour = atoi(argv[++a]);
249 break;
250 default:
251 goto userr;
252 }
253 break;
254 case 'l': /* perceptible glare threshold */
255 dgp_limit = atof(argv[++a]);
256 break;
257 case 'b': /* luminance threshold */
258 dgp_threshold = atof(argv[++a]);
259 break;
260 case 'v':
261 switch (argv[a][2]) {
262 case 'd': /* forward */
263 //check(3, "fff");
264 vdir[0] = atof(argv[++a]);
265 vdir[1] = atof(argv[++a]);
266 vdir[2] = atof(argv[++a]);
267 if (normalize(vdir) == 0.0) goto userr;
268 break;
269 case 'u': /* up */
270 //check(3, "fff");
271 vup[0] = atof(argv[++a]);
272 vup[1] = atof(argv[++a]);
273 vup[2] = atof(argv[++a]);
274 if (normalize(vup) == 0.0) goto userr;
275 break;
276 case 'f': /* view directions file */
277 //check(2, "s");
278 view_path = argv[++a];
279 break;
280 case 'i':
281 switch (argv[a][3]) {
282 case 'f':
283 viewfmt = DTfloat;
284 break;
285 case 'd':
286 viewfmt = DTdouble;
287 break;
288 case 'a':
289 viewfmt = DTascii;
290 break;
291 default:
292 goto userr;
293 }
294 default:
295 goto userr;
296 }
297 break;
298 #endif /* DC_GLARE */
299 default:
300 goto userr;
301 }
302 #ifdef DC_GLARE
303 if ((argc-a < 2) | (argc-a > 5))
304 goto userr;
305 /* single bounce daylight coefficients file */
306 direct_path = argv[a++];
307 #else
308 if ((argc-a < 1) | (argc-a > 4))
309 goto userr;
310 #endif /* DC_GLARE */
311
312 if (argc-a > 2) { /* VTDs expression */
313 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
314 const char *ccp;
315 /* get sky vector/matrix */
316 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
317 nsteps = smtx->ncols;
318 /* load BSDF */
319 if (argv[a+1][0] != '!' &&
320 (ccp = strrchr(argv[a+1], '.')) != NULL &&
321 !strcasecmp(ccp+1, "XML"))
322 Tmat = cm_loadBTDF(argv[a+1]);
323 else
324 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
325 /* load Daylight matrix */
326 Dmat = cm_load(argv[a+2], Tmat->ncols,
327 smtx->nrows, DTfromHeader);
328 /* multiply vector through */
329 imtx = cm_multiply(Dmat, smtx);
330 cm_free(Dmat); cm_free(smtx);
331 cmtx = cm_multiply(Tmat, imtx);
332 cm_free(Tmat);
333 cm_free(imtx);
334 } else { /* sky vector/matrix only */
335 //TIMER(timer, "read args");
336 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
337 nsteps = cmtx->ncols;
338 //TIMER(timer, "load sky matrix");
339 }
340 /* prepare output stream */
341 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
342 sprintf(fnbuf, ofspec, 1);
343 ofspec = fnbuf;
344 }
345 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
346 if ((ofp = fopen(ofspec, "w")) == NULL) {
347 fprintf(stderr, "%s: cannot open '%s' for output\n",
348 progname, ofspec);
349 return(1);
350 }
351 ofspec = NULL; /* only need to open once */
352 }
353 if (hasNumberFormat(argv[a])) { /* generating image(s) */
354 if (ofspec == NULL) {
355 SET_FILE_BINARY(ofp);
356 newheader("RADIANCE", ofp);
357 printargs(argc, argv, ofp);
358 fputnow(ofp);
359 }
360 if (nsteps > 1) /* multiple output frames? */
361 for (i = 0; i < nsteps; i++) {
362 CMATRIX *cvec = cm_column(cmtx, i);
363 if (ofspec != NULL) {
364 sprintf(fnbuf, ofspec, i);
365 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
366 fprintf(stderr,
367 "%s: cannot open '%s' for output\n",
368 progname, fnbuf);
369 return(1);
370 }
371 newheader("RADIANCE", ofp);
372 printargs(argc, argv, ofp);
373 fputnow(ofp);
374 }
375 fprintf(ofp, "FRAME=%d\n", i);
376 if (!sum_images(argv[a], cvec, ofp))
377 return(1);
378 if (ofspec != NULL) {
379 if (fclose(ofp) == EOF) {
380 fprintf(stderr,
381 "%s: error writing to '%s'\n",
382 progname, fnbuf);
383 return(1);
384 }
385 ofp = stdout;
386 }
387 cm_free(cvec);
388 }
389 else if (!sum_images(argv[a], cmtx, ofp))
390 return(1);
391 } else { /* generating vector/matrix */
392 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
393 //TIMER(timer, "load view matrix");
394 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
395 //TIMER(timer, "multiply");
396 cm_free(Vmat);
397 #ifdef DC_GLARE
398 if (direct_path) { /* Do glare autonomy calculation */
399 /* Load occupancy schedule */
400 occupancy = (int*)malloc(nsteps * sizeof(int));
401 if (!occupancy) {
402 fprintf(stderr,
403 "%s: out of memory for schedule\n",
404 progname);
405 return(1);
406 }
407 if (schedule_path) {
408 if ((fp = fopen(schedule_path, "r")) == NULL) {
409 fprintf(stderr,
410 "%s: cannot open input file \"%s\"\n",
411 progname, schedule_path);
412 return(1);
413 }
414 if (cm_load_schedule(nsteps, occupancy, fp) < 0) return(1);
415 }
416 else {
417 for (i = 0; i < nsteps; i++) {
418 /* Assume hourly spacing */
419 int hour = i % 24;
420 occupancy[i] = ((hour >= start_hour) & (hour < end_hour));
421 }
422 }
423 //TIMER(timer, "load occupancy schedule");
424
425 /* Load view directions */
426 if (view_path == NULL) {
427 if (vdir[0] == 0.0f && vdir[1] == 0.0f && vdir[2] == 0.0f) {
428 fprintf(stderr,
429 "%s: missing view direction\n",
430 progname);
431 return(1);
432 }
433 }
434 else {
435 if ((fp = fopen(view_path, "r")) == NULL) {
436 fprintf(stderr,
437 "%s: cannot open input file \"%s\"\n",
438 progname, view_path);
439 return(1);
440 }
441 if (viewfmt != DTascii)
442 SET_FILE_BINARY(fp);
443 views = cm_load_views(rmtx->nrows, viewfmt, fp);
444 if (!views) return(1);
445 //TIMER(timer, "load views");
446 }
447
448 /* Calculate glare values */
449 Vmat = cm_load(direct_path, 0, cmtx->nrows, DTfromHeader);
450 //TIMER(timer, "load direct matrix");
451 dgp_values = cm_glare(Vmat, rmtx, cmtx, occupancy, dgp_limit, dgp_threshold, views, vdir, vup);
452 //TIMER(timer, "calculate dgp");
453 free(views);
454 cm_free(Vmat);
455
456 /* Check successful calculation */
457 if (!dgp_values) return(1);
458 }
459 #endif /* DC_GLARE */
460 if (ofspec != NULL) { /* multiple vector files? */
461 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
462 for (i = 0; i < nsteps; i++) {
463 CMATRIX *rvec = cm_column(rmtx, i);
464 sprintf(fnbuf, ofspec, i);
465 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
466 fprintf(stderr,
467 "%s: cannot open '%s' for output\n",
468 progname, fnbuf);
469 return(1);
470 }
471 #ifdef getc_unlocked
472 flockfile(ofp);
473 #endif
474 if (headout) { /* header output */
475 newheader("RADIANCE", ofp);
476 printargs(argc, argv, ofp);
477 fputnow(ofp);
478 fprintf(ofp, "FRAME=%d\n", i);
479 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
480 fputs("NCOLS=1\nNCOMP=3\n", ofp);
481 if ((outfmt == DTfloat) | (outfmt == DTdouble))
482 fputendian(ofp);
483 fputformat(cm_fmt_id[outfmt], ofp);
484 fputc('\n', ofp);
485 }
486 cm_write(rvec, outfmt, ofp);
487 if (fclose(ofp) == EOF) {
488 fprintf(stderr,
489 "%s: error writing to '%s'\n",
490 progname, fnbuf);
491 return(1);
492 }
493 ofp = stdout;
494 cm_free(rvec);
495 }
496 } else {
497 #ifdef getc_unlocked
498 flockfile(ofp);
499 #endif
500 if (outfmt != DTascii)
501 SET_FILE_BINARY(ofp);
502 if (headout) { /* header output */
503 newheader("RADIANCE", ofp);
504 printargs(argc, argv, ofp);
505 fputnow(ofp);
506 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
507 #ifdef DC_GLARE
508 fprintf(ofp, "NCOLS=%d\n", (!dgp_values || dgp_limit < 0) ? rmtx->ncols : 1);
509 fprintf(ofp, "NCOMP=%d\n", dgp_values ? 1 : 3);
510 #else
511 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
512 fputs("NCOMP=3\n", ofp);
513 #endif /* DC_GLARE */
514 if ((outfmt == DTfloat) | (outfmt == DTdouble))
515 fputendian(ofp);
516 fputformat(cm_fmt_id[outfmt], ofp);
517 fputc('\n', ofp);
518 }
519 #ifdef DC_GLARE
520 if (dgp_values) { /* Write glare autonomy */
521 cm_write_glare(dgp_values, rmtx->nrows, dgp_limit < 0 ? rmtx->ncols : 1, outfmt, ofp);
522 free(dgp_values);
523 //TIMER(timer, "write");
524 }
525 else
526 #endif /* DC_GLARE */
527 cm_write(rmtx, outfmt, ofp);
528 }
529 cm_free(rmtx);
530 }
531 if (fflush(ofp) == EOF) { /* final clean-up */
532 fprintf(stderr, "%s: write error on output\n", progname);
533 return(1);
534 }
535 cm_free(cmtx);
536 return(0);
537 userr:
538 #ifdef DC_GLARE
539 fprintf(stderr, "Usage: %s [-n nsteps][-i{f|d|h}][-o{f|d}][-l limit][-b threshold][{-sf occupancy|-ss start -se end}]{-vf views [-vi{f|d}]|-vd x y z}[-vu x y z] DCdirect DCtotal [skyf]\n",
540 progname);
541 fprintf(stderr, " or: %s [-n nsteps][-i{f|d|h}][-o{f|d}][-l limit][-b threshold][{-sf occupancy|-ss start -se end}]{-vf views [-vi{f|d}]|-vd x y z}[-vu x y z] DCdirect Vspec Tbsdf Dmat.dat [skyf]\n",
542 progname);
543 #else
544 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n",
545 progname);
546 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n",
547 progname);
548 #endif /* DC_GLARE */
549 return(1);
550 }
