root/radiance/ray/src/util/dayfact.csh
Revision: 2.7
Committed: Thu Oct 6 05:49:44 2005 UTC (18 years, 5 months ago) by greg
Content type: application/x-csh
CVS Tags: rad3R8, rad3R9
# User Rev Content
1 greg 1.1 #!/bin/csh -f
2 greg 2.7 # RCSid: $Id: dayfact.csh,v 2.6 2005/02/16 05:40:12 greg Exp $
3 greg 1.1 #
4     # Interactive script to calculate daylight factors
5     #
6     set nofile="none"
7 greg 2.2 set illumpic=$nofile
8 greg 1.1 set octree=$nofile
9     set dfpict=$nofile
10     set ilpict=$nofile
11 greg 2.2 set dspict=$nofile
12     set nodaysav=1
13 greg 1.4 set fcopts=($*)
14 greg 2.2 set designlvl=500
15 greg 1.1 set wporig=(0 0 0)
16     set wpsize=(1 1)
17 greg 2.2 set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .3 .3 .3)
18 greg 1.3 set maxres=128
19 greg 1.1
20     alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
21
22     cat <<_EOF_
23     DAYLIGHT FACTOR CALCULATION
24
25 greg 2.2 This script calculates daylight factors, illuminance levels, and/or
26     energy savings due to daylight on a rectangular workplane and produces
27     a contour plot from the result. The input is a Radiance scene description
28     (and octree) and the output is one or more color Radiance pictures.
29 greg 1.1
30     _EOF_
31 greg 2.3 echo "Have you already calculated an illuminance picture using dayfact?"
32     readvar illumpic
33     if ( $illumpic != $nofile ) then
34 greg 2.2 if ( ! -r $illumpic ) then
35     echo "Cannot read $illumpic"
36     exit 1
37     endif
38     set title=$illumpic:r
39     set gotillumpic
40     goto getgenskyf
41     endif
42
43 greg 1.1 readvar octree
44 greg 2.2 if ( $octree == $nofile || ! -f $octree ) then
45 greg 1.6 echo "You must first create an octree with"
46     echo "oconv before running this script."
47 greg 1.1 exit 1
48     endif
49 greg 1.5 set title="$octree:r"
50 greg 1.2 echo -n "Is the z-axis your zenith direction? "
51     if ( "$<" !~ [yY]* ) then
52 greg 1.1 echo "I'm sorry, you cannot use this script"
53     exit 1
54     endif
55     echo "What is the origin (smallest x y z coordinates) of the workplane?"
56     readvar wporig
57     set wporig=($wporig)
58     echo "What is the x and y size (width and length) of the workplane?"
59 greg 1.2 readvar wpsize
60 greg 1.1 set wpsize=($wpsize)
61     set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`)
62     set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`)
63     echo "What calculation options do you want to give to rtrace?"
64 greg 1.6 echo "(It is very important to set the -a* options correctly.)"
65 greg 1.1 readvar rtargs
66 greg 2.2 echo "Do you want to save the illuminance picture for later runs?"
67     readvar illumpic
68     ############
69     getgenskyf:
70     set genskyf=$nofile
71     echo "In what scene file is the gensky command located?"
72     readvar genskyf
73     if ( $genskyf == $nofile ) then
74     echo "You will not be able to compute daylight factors"
75     echo "or energy savings since there is no gensky file."
76     else
77 greg 2.6 xform -e $genskyf > /tmp/gsf$$
78     grep '^# gensky ' /tmp/gsf$$
79 greg 2.2 if ( $status ) then
80     echo "The file $genskyf does not contain a gensky command\!"
81 greg 2.6 rm -f /tmp/gsf$$
82 greg 2.2 goto getgenskyf
83     endif
84 greg 2.6 set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' /tmp/gsf$$`
85     set extamb=`sed -n 's/^# Ground ambient level: //p' /tmp/gsf$$`
86     grep -s '^# gensky .* -c' /tmp/gsf$$
87 greg 2.2 set nodaysav=$status
88 greg 2.6 rm -f /tmp/gsf$$
89 greg 2.2 if ( $nodaysav ) then
90     echo "The gensky command was not done for an overcast sky"
91     echo "(-c option), so energy savings cannot be calculated."
92     echo -n "Continue anyway? "
93     if ( "$<" =~ [nN]* ) then
94     exit 0
95     endif
96     endif
97     endif
98 greg 1.1 echo "Illuminance contour picture if you want one"
99     readvar ilpict
100     if ( $?extamb ) then
101     echo "Daylight factor contour picture if you want one"
102     readvar dfpict
103     endif
104 greg 2.2 if ( ! $nodaysav ) then
105     echo "Energy savings contour picture if you want one"
106     readvar dspict
107     if ( $dspict != $nofile ) then
108     echo "Workplane design level (lux)"
109     readvar designlvl
110     endif
111     endif
112     if ( $ilpict == $nofile && $dfpict == $nofile && $dspict == $nofile ) then
113 greg 1.1 echo "Since you don't want any output, I guess we're done."
114     exit 0
115     endif
116 greg 1.5 echo "Title for output picture"
117     readvar title
118 greg 2.6 set sctemp=/tmp/sc$$.csh
119 greg 1.4 cat <<'_EOF_' > $sctemp
120 greg 2.2 if ( $illumpic != $nofile ) then
121     set iltemp=""
122     else
123 greg 2.6 set iltemp=/tmp/il$$.pic
124 greg 2.2 set illumpic=$iltemp
125     endif
126 greg 2.6 set tltemp=/tmp/tl$$.pic
127     set dstemp=/tmp/ds$$.pic
128     set temp1=/tmp/tfa$$
129 greg 2.2 set tempfiles=($iltemp $sctemp $tltemp $dstemp $temp1)
130 greg 1.4 echo "Your dayfact job is finished."
131     echo "Please check for error messages below."
132     echo ""
133     set echo
134 greg 2.2 if ( ! $?gotillumpic ) then
135     cnt $wpres[2] $wpres[1] \
136 greg 1.2 | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \
137     -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \
138     -e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \
139 greg 2.4 | rtrace $rtargs -h+ -I+ -ov -fac -x $wpres[1] -y $wpres[2] $octree \
140     > $temp1
141 greg 2.2 pfilt -h 20 -n 0 -x 300 -y 300 -p 1 -r 1 $temp1 > $illumpic
142     endif
143     set maxval=`getinfo < $illumpic | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'`
144 greg 2.7 if ("$maxval" == "") set maxval=3
145 greg 2.2 psign -h 42 " $title " | pfilt -1 -x /2 -y /2 > $tltemp
146 greg 1.4 '_EOF_'
147 greg 2.2 if ( $ilpict != $nofile ) then
148     echo 'falsecolor -cb -l Lux -s "$maxval*179" \\
149     $fcopts -m 179 -ip $illumpic \\
150 greg 1.5 | pcompos -a 1 - $tltemp > $ilpict' >> $sctemp
151 greg 1.1 endif
152 greg 2.2 if ( $dfpict != $nofile ) then
153 greg 2.7 echo 'falsecolor -cb -l DF -s 16 \\
154 greg 2.2 $fcopts -m "100/PI/$extamb" -ip $illumpic \\
155 greg 1.5 | pcompos -a 1 - $tltemp > $dfpict' >> $sctemp
156 greg 2.2 endif
157     if ( $dspict != $nofile ) then
158     echo 'pcomb -e "lo=1-$designlvl/20000*3.1416*$extamb/li(1)" \\
159     -o $illumpic | falsecolor -cb -l "%Save" -s 100 \\
160     $fcopts -m 100 -p $illumpic \\
161     | pcompos -a 1 - $tltemp > $dspict' >> $sctemp
162 greg 1.1 endif
163 greg 1.4 echo 'rm -f $tempfiles' >> $sctemp
164     (source $sctemp) |& mail `whoami` &
165     echo "Your job is started in the background."
166 greg 1.6 echo "You will be notified by mail when it is done."
