| 1 |
#!/bin/csh -f |
| 2 |
# RCSid: $Id: dayfact.csh,v 2.5 2003/02/22 02:07:30 greg Exp $ |
| 3 |
| 4 |
# Interactive script to calculate daylight factors |
| 5 |
| 6 |
set nofile="none" |
| 7 |
set illumpic=$nofile |
| 8 |
set octree=$nofile |
| 9 |
set dfpict=$nofile |
| 10 |
set ilpict=$nofile |
| 11 |
set dspict=$nofile |
| 12 |
set nodaysav=1 |
| 13 |
set fcopts=($*) |
| 14 |
set designlvl=500 |
| 15 |
set wporig=(0 0 0) |
| 16 |
set wpsize=(1 1) |
| 17 |
set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .3 .3 .3) |
| 18 |
set maxres=128 |
| 19 |
| 20 |
alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' |
| 21 |
| 22 |
cat <<_EOF_ |
| 23 |
DAYLIGHT FACTOR CALCULATION |
| 24 |
| 25 |
This script calculates daylight factors, illuminance levels, and/or |
| 26 |
energy savings due to daylight on a rectangular workplane and produces |
| 27 |
a contour plot from the result. The input is a Radiance scene description |
| 28 |
(and octree) and the output is one or more color Radiance pictures. |
| 29 |
| 30 |
_EOF_ |
| 31 |
echo "Have you already calculated an illuminance picture using dayfact?" |
| 32 |
readvar illumpic |
| 33 |
if ( $illumpic != $nofile ) then |
| 34 |
if ( ! -r $illumpic ) then |
| 35 |
echo "Cannot read $illumpic" |
| 36 |
exit 1 |
| 37 |
endif |
| 38 |
set title=$illumpic:r |
| 39 |
set gotillumpic |
| 40 |
goto getgenskyf |
| 41 |
endif |
| 42 |
| 43 |
readvar octree |
| 44 |
if ( $octree == $nofile || ! -f $octree ) then |
| 45 |
echo "You must first create an octree with" |
| 46 |
echo "oconv before running this script." |
| 47 |
exit 1 |
| 48 |
endif |
| 49 |
set title="$octree:r" |
| 50 |
echo -n "Is the z-axis your zenith direction? " |
| 51 |
if ( "$<" !~ [yY]* ) then |
| 52 |
echo "I'm sorry, you cannot use this script" |
| 53 |
exit 1 |
| 54 |
endif |
| 55 |
echo "What is the origin (smallest x y z coordinates) of the workplane?" |
| 56 |
readvar wporig |
| 57 |
set wporig=($wporig) |
| 58 |
echo "What is the x and y size (width and length) of the workplane?" |
| 59 |
readvar wpsize |
| 60 |
set wpsize=($wpsize) |
| 61 |
set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`) |
| 62 |
set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`) |
| 63 |
echo "What calculation options do you want to give to rtrace?" |
| 64 |
echo "(It is very important to set the -a* options correctly.)" |
| 65 |
readvar rtargs |
| 66 |
echo "Do you want to save the illuminance picture for later runs?" |
| 67 |
readvar illumpic |
| 68 |
| 69 |
getgenskyf: |
| 70 |
set genskyf=$nofile |
| 71 |
echo "In what scene file is the gensky command located?" |
| 72 |
readvar genskyf |
| 73 |
if ( $genskyf == $nofile ) then |
| 74 |
echo "You will not be able to compute daylight factors" |
| 75 |
echo "or energy savings since there is no gensky file." |
| 76 |
else |
| 77 |
xform -e $genskyf > /tmp/gsf$$ |
| 78 |
grep '^# gensky ' /tmp/gsf$$ |
| 79 |
if ( $status ) then |
| 80 |
echo "The file $genskyf does not contain a gensky command\!" |
| 81 |
rm -f /tmp/gsf$$ |
| 82 |
goto getgenskyf |
| 83 |
endif |
| 84 |
set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' /tmp/gsf$$` |
| 85 |
set extamb=`sed -n 's/^# Ground ambient level: //p' /tmp/gsf$$` |
| 86 |
grep -s '^# gensky .* -c' /tmp/gsf$$ |
| 87 |
set nodaysav=$status |
| 88 |
rm -f /tmp/gsf$$ |
| 89 |
if ( $nodaysav ) then |
| 90 |
echo "The gensky command was not done for an overcast sky" |
| 91 |
echo "(-c option), so energy savings cannot be calculated." |
| 92 |
echo -n "Continue anyway? " |
| 93 |
if ( "$<" =~ [nN]* ) then |
| 94 |
exit 0 |
| 95 |
endif |
| 96 |
endif |
| 97 |
endif |
| 98 |
echo "Illuminance contour picture if you want one" |
| 99 |
readvar ilpict |
| 100 |
if ( $?extamb ) then |
| 101 |
echo "Daylight factor contour picture if you want one" |
| 102 |
readvar dfpict |
| 103 |
endif |
| 104 |
if ( ! $nodaysav ) then |
| 105 |
echo "Energy savings contour picture if you want one" |
| 106 |
readvar dspict |
| 107 |
if ( $dspict != $nofile ) then |
| 108 |
echo "Workplane design level (lux)" |
| 109 |
readvar designlvl |
| 110 |
endif |
| 111 |
endif |
| 112 |
if ( $ilpict == $nofile && $dfpict == $nofile && $dspict == $nofile ) then |
| 113 |
echo "Since you don't want any output, I guess we're done." |
| 114 |
exit 0 |
| 115 |
endif |
| 116 |
echo "Title for output picture" |
| 117 |
readvar title |
| 118 |
set sctemp=/tmp/sc$$.csh |
| 119 |
cat <<'_EOF_' > $sctemp |
| 120 |
| 121 |
set iltemp="" |
| 122 |
else |
| 123 |
set iltemp=/tmp/il$$.pic |
| 124 |
set illumpic=$iltemp |
| 125 |
endif |
| 126 |
set tltemp=/tmp/tl$$.pic |
| 127 |
set dstemp=/tmp/ds$$.pic |
| 128 |
set temp1=/tmp/tfa$$ |
| 129 |
set tempfiles=($iltemp $sctemp $tltemp $dstemp $temp1) |
| 130 |
echo "Your dayfact job is finished." |
| 131 |
echo "Please check for error messages below." |
| 132 |
echo "" |
| 133 |
set echo |
| 134 |
if ( ! $?gotillumpic ) then |
| 135 |
cnt $wpres[2] $wpres[1] \ |
| 136 |
| rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \ |
| 137 |
-e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \ |
| 138 |
-e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \ |
| 139 |
| rtrace $rtargs -h+ -I+ -ov -fac -x $wpres[1] -y $wpres[2] $octree \ |
| 140 |
> $temp1 |
| 141 |
pfilt -h 20 -n 0 -x 300 -y 300 -p 1 -r 1 $temp1 > $illumpic |
| 142 |
endif |
| 143 |
set maxval=`getinfo < $illumpic | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'` |
| 144 |
psign -h 42 " $title " | pfilt -1 -x /2 -y /2 > $tltemp |
| 145 |
'_EOF_' |
| 146 |
if ( $ilpict != $nofile ) then |
| 147 |
echo 'falsecolor -cb -l Lux -s "$maxval*179" \\ |
| 148 |
$fcopts -m 179 -ip $illumpic \\ |
| 149 |
| pcompos -a 1 - $tltemp > $ilpict' >> $sctemp |
| 150 |
endif |
| 151 |
if ( $dfpict != $nofile ) then |
| 152 |
echo 'falsecolor -cb -l DF -s 50 \\ |
| 153 |
$fcopts -m "100/PI/$extamb" -ip $illumpic \\ |
| 154 |
| pcompos -a 1 - $tltemp > $dfpict' >> $sctemp |
| 155 |
endif |
| 156 |
| 157 |
echo 'pcomb -e "lo=1-$designlvl/20000*3.1416*$extamb/li(1)" \\ |
| 158 |
-o $illumpic | falsecolor -cb -l "%Save" -s 100 \\ |
| 159 |
$fcopts -m 100 -p $illumpic \\ |
| 160 |
| pcompos -a 1 - $tltemp > $dspict' >> $sctemp |
| 161 |
endif |
| 162 |
echo 'rm -f $tempfiles' >> $sctemp |
| 163 |
(source $sctemp) |& mail `whoami` & |
| 164 |
echo "Your job is started in the background." |
| 165 |
echo "You will be notified by mail when it is done." |
