root/radiance/ray/src/util/dayfact.csh
Revision: 1.2
Committed: Wed Jun 5 12:07:43 1991 UTC (32 years, 11 months ago) by greg
Content type: application/x-csh
Changes since 1.1: +10 -8 lines
initial bug fixes
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Interactive script to calculate daylight factors
5 #
6 set nofile="none"
7 set genskyf=$nofile
8 set octree=$nofile
9 set dfpict=$nofile
10 set ilpict=$nofile
11 set wporig=(0 0 0)
12 set wpsize=(1 1)
13 set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .1 .1 .1)
14
15 set maxres=64
16 set iltemp=/usr/tmp/il$$.pic
17 set tempfiles=($iltemp)
18
19 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
20
21 onintr quit
22
23 cat <<_EOF_
24 DAYLIGHT FACTOR CALCULATION
25
26 This script calculates daylight factors and/or illuminance levels on a
27 rectangular workplane and produces a contour plot from the result. The
28 input is a Radiance scene description (and octree) and the output is one
29 or more color Radiance pictures.
30
31 _EOF_
32 readvar octree
33 if ( "$octree" == "$nofile" || ! -f "$octree" ) then
34 echo "You must first create an octree with oconv"
35 echo "before running this script."
36 exit 1
37 endif
38 echo ""
39 echo "In what scene file is the gensky command located?"
40 readvar genskyf
41 if ( "$genskyf" == "$nofile" || ! -r "$genskyf" ) then
42 echo "You will not be able to compute"
43 echo "daylight factors without a gensky file"
44 else
45 set extamb=`xform -e $genskyf|sed -n 's/^# Ground ambient level: //p'`
46 echo extamb = $extamb
47 endif
48 echo -n "Is the z-axis your zenith direction? "
49 if ( "$<" !~ [yY]* ) then
50 echo "I'm sorry, you cannot use this script"
51 exit 1
52 endif
53 echo "What is the origin (smallest x y z coordinates) of the workplane?"
54 readvar wporig
55 set wporig=($wporig)
56 echo "What is the x and y size (width and length) of the workplane?"
57 readvar wpsize
58 set wpsize=($wpsize)
59 set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`)
60 set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`)
61 echo "What calculation options do you want to give to rtrace?"
62 echo "(It is very important to set the -a? options correctly.)"
63 readvar rtargs
64 echo "Illuminance contour picture if you want one"
65 readvar ilpict
66 if ( $?extamb ) then
67 echo "Daylight factor contour picture if you want one"
68 readvar dfpict
69 endif
70 if ( "$ilpict" == "$nofile" && "$dfpict" == "$nofile" ) then
71 echo "Since you don't want any output, I guess we're done."
72 exit 0
73 endif
74 echo "Starting rtrace calculation -- this will take some time..."
75 cnt $wpres[2] $wpres[1] \
76 | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \
77 -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \
78 -e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \
79 | rtrace $rtargs -I -ov -faf $octree \
80 | pvalue -r -x $wpres[1] -y $wpres[2] -df \
81 | pfilt -h 20 -n 0 -x 256 -y 256 -p 1 -r 1 > $iltemp
82 set maxval=`getinfo < $iltemp | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'`
83 if ( "$ilpict" != "$nofile" ) then
84 echo "Making illuminance contour picture $ilpict..."
85 falsecolor -s "$maxval*470" -l Lux -log 2 -cl -pi $iltemp > $ilpict
86 endif
87 if ( "$dfpict" != "$nofile" ) then
88 echo "Making daylight factor contour picture $dfpict..."
89 falsecolor -s "$maxval/$extamb" -m "1/$extamb" -l DF \
90 -log 2 -cl -pi $iltemp > $dfpict
91 endif
92 echo "Done."
93 quit:
94 rm -f $tempfiles
