--- ray/src/util/dayfact.csh 1991/06/05 12:49:16 1.3 +++ ray/src/util/dayfact.csh 1991/06/07 17:21:18 1.7 @@ -8,18 +8,14 @@ set genskyf=$nofile set octree=$nofile set dfpict=$nofile set ilpict=$nofile +set fcopts=($*) set wporig=(0 0 0) set wpsize=(1 1) set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .1 .1 .1) - set maxres=128 -set iltemp=/usr/tmp/il$$.pic -set tempfiles=($iltemp) alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' -onintr quit - cat <<_EOF_ DAYLIGHT FACTOR CALCULATION @@ -31,16 +27,18 @@ or more color Radiance pictures. _EOF_ readvar octree if ( "$octree" == "$nofile" || ! -f "$octree" ) then - echo "You must first create an octree with oconv" - echo "before running this script." + echo "You must first create an octree with" + echo "oconv before running this script." exit 1 endif +set title="$octree:r" echo "In what scene file is the gensky command located?" readvar genskyf if ( "$genskyf" == "$nofile" || ! -r "$genskyf" ) then - echo "You will not be able to compute" - echo "daylight factors without a gensky file" + echo "You will not be able to compute daylight" + echo "factors since there is no gensky file." else + set title=$title\ `sed -n 's/^.*\ $sctemp +set iltemp=/usr/tmp/il$$.pic +set sctemp=/usr/tmp/sc$$.csh +set tltemp=/usr/tmp/tl$$.pic +set tempfiles=($iltemp $sctemp $tltemp) +echo "Your dayfact job is finished." +echo "Please check for error messages below." +echo "" +set echo cnt $wpres[2] $wpres[1] \ | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \ -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \ @@ -78,15 +86,19 @@ cnt $wpres[2] $wpres[1] \ | pvalue -r -x $wpres[1] -y $wpres[2] -df \ | pfilt -h 20 -n 0 -x 350 -y 350 -p 1 -r 1 > $iltemp set maxval=`getinfo < $iltemp | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'` +psign -h 50 " $title " | pfilt -1 -x /2 -y /2 > $tltemp +'_EOF_' if ( "$ilpict" != "$nofile" ) then - echo "Making illuminance contour picture $ilpict..." - falsecolor -s "$maxval*470" -m 470 -l Lux -cb -pi $iltemp > $ilpict + echo 'falsecolor -cb -l Lux $fcopts \\ + -s "$maxval*470" -m 470 -pi $iltemp \\ + | pcompos -a 1 - $tltemp > $ilpict' >> $sctemp endif if ( "$dfpict" != "$nofile" ) then - echo "Making daylight factor contour picture $dfpict..." - falsecolor -s "$maxval/$extamb" -m "1/$extamb" -l DF \ - -cb -pi $iltemp > $dfpict + echo 'falsecolor -cb -l DF $fcopts \\ + -s "100*$maxval/$extamb" -m "100/$extamb" -pi $iltemp \\ + | pcompos -a 1 - $tltemp > $dfpict' >> $sctemp endif -echo "Done." -quit: - rm -f $tempfiles +echo 'rm -f $tempfiles' >> $sctemp +(source $sctemp) |& mail `whoami` & +echo "Your job is started in the background." +echo "You will be notified by mail when it is done."
