root/radiance/ray/src/util/dayfact.csh
Revision: 2.2
Committed: Thu Nov 28 11:49:12 1991 UTC (33 years, 7 months ago) by greg
Content type: application/x-csh
Changes since 2.1: +91 -30 lines
added daylight savings calculation and reuse of illuminance picture
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Interactive script to calculate daylight factors
5 #
6 set nofile="none"
7 set illumpic=$nofile
8 set octree=$nofile
9 set dfpict=$nofile
10 set ilpict=$nofile
11 set dspict=$nofile
12 set nodaysav=1
13 set fcopts=($*)
14 set designlvl=500
15 set wporig=(0 0 0)
16 set wpsize=(1 1)
17 set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .3 .3 .3)
18 set maxres=128
19
20 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
21
22 cat <<_EOF_
23 DAYLIGHT FACTOR CALCULATION
24
25 This script calculates daylight factors, illuminance levels, and/or
26 energy savings due to daylight on a rectangular workplane and produces
27 a contour plot from the result. The input is a Radiance scene description
28 (and octree) and the output is one or more color Radiance pictures.
29
30 _EOF_
31 echo -n "Have you already calculated an illuminance picture with dayfact? "
32 if ( "$<" =~ [yY]* ) then
33 readvar illumpic
34 if ( ! -r $illumpic ) then
35 echo "Cannot read $illumpic"
36 exit 1
37 endif
38 set title=$illumpic:r
39 set gotillumpic
40 goto getgenskyf
41 endif
42
43 readvar octree
44 if ( $octree == $nofile || ! -f $octree ) then
45 echo "You must first create an octree with"
46 echo "oconv before running this script."
47 exit 1
48 endif
49 set title="$octree:r"
50 echo -n "Is the z-axis your zenith direction? "
51 if ( "$<" !~ [yY]* ) then
52 echo "I'm sorry, you cannot use this script"
53 exit 1
54 endif
55 echo "What is the origin (smallest x y z coordinates) of the workplane?"
56 readvar wporig
57 set wporig=($wporig)
58 echo "What is the x and y size (width and length) of the workplane?"
59 readvar wpsize
60 set wpsize=($wpsize)
61 set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`)
62 set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`)
63 echo "What calculation options do you want to give to rtrace?"
64 echo "(It is very important to set the -a* options correctly.)"
65 readvar rtargs
66 echo "Do you want to save the illuminance picture for later runs?"
67 readvar illumpic
68 ############
69 getgenskyf:
70 set genskyf=$nofile
71 echo "In what scene file is the gensky command located?"
72 readvar genskyf
73 if ( $genskyf == $nofile ) then
74 echo "You will not be able to compute daylight factors"
75 echo "or energy savings since there is no gensky file."
76 else
77 xform -e $genskyf > /usr/tmp/gsf$$
78 grep '^# gensky ' /usr/tmp/gsf$$
79 if ( $status ) then
80 echo "The file $genskyf does not contain a gensky command\!"
81 rm -f /usr/tmp/gsf$$
82 goto getgenskyf
83 endif
84 set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' /usr/tmp/gsf$$`
85 set extamb=`sed -n 's/^# Ground ambient level: //p' /usr/tmp/gsf$$`
86 grep -s '^# gensky .* -c' /usr/tmp/gsf$$
87 set nodaysav=$status
88 rm -f /usr/tmp/gsf$$
89 if ( $nodaysav ) then
90 echo "The gensky command was not done for an overcast sky"
91 echo "(-c option), so energy savings cannot be calculated."
92 echo -n "Continue anyway? "
93 if ( "$<" =~ [nN]* ) then
94 exit 0
95 endif
96 endif
97 endif
98 echo "Illuminance contour picture if you want one"
99 readvar ilpict
100 if ( $?extamb ) then
101 echo "Daylight factor contour picture if you want one"
102 readvar dfpict
103 endif
104 if ( ! $nodaysav ) then
105 echo "Energy savings contour picture if you want one"
106 readvar dspict
107 if ( $dspict != $nofile ) then
108 echo "Workplane design level (lux)"
109 readvar designlvl
110 endif
111 endif
112 if ( $ilpict == $nofile && $dfpict == $nofile && $dspict == $nofile ) then
113 echo "Since you don't want any output, I guess we're done."
114 exit 0
115 endif
116 echo "Title for output picture"
117 readvar title
118 set sctemp=/usr/tmp/sc$$.csh
119 cat <<'_EOF_' > $sctemp
120 if ( $illumpic != $nofile ) then
121 set iltemp=""
122 else
123 set iltemp=/usr/tmp/il$$.pic
124 set illumpic=$iltemp
125 endif
126 set tltemp=/usr/tmp/tl$$.pic
127 set dstemp=/usr/tmp/ds$$.pic
128 set temp1=/usr/tmp/tfa$$
129 set tempfiles=($iltemp $sctemp $tltemp $dstemp $temp1)
130 echo "Your dayfact job is finished."
131 echo "Please check for error messages below."
132 echo ""
133 set echo
134 if ( ! $?gotillumpic ) then
135 cnt $wpres[2] $wpres[1] \
136 | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \
137 -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \
138 -e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \
139 | rtrace $rtargs -h+ -I+ -ov -faf $octree \
140 | pvalue -r -y $wpres[2] +x $wpres[1] -df > $temp1
141 pfilt -h 20 -n 0 -x 300 -y 300 -p 1 -r 1 $temp1 > $illumpic
142 endif
143 set maxval=`getinfo < $illumpic | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'`
144 psign -h 42 " $title " | pfilt -1 -x /2 -y /2 > $tltemp
145 '_EOF_'
146 if ( $ilpict != $nofile ) then
147 echo 'falsecolor -cb -l Lux -s "$maxval*179" \\
148 $fcopts -m 179 -ip $illumpic \\
149 | pcompos -a 1 - $tltemp > $ilpict' >> $sctemp
150 endif
151 if ( $dfpict != $nofile ) then
152 echo 'falsecolor -cb -l DF -s 50 \\
153 $fcopts -m "100/PI/$extamb" -ip $illumpic \\
154 | pcompos -a 1 - $tltemp > $dfpict' >> $sctemp
155 endif
156 if ( $dspict != $nofile ) then
157 echo 'pcomb -e "lo=1-$designlvl/20000*3.1416*$extamb/li(1)" \\
158 -o $illumpic | falsecolor -cb -l "%Save" -s 100 \\
159 $fcopts -m 100 -p $illumpic \\
160 | pcompos -a 1 - $tltemp > $dspict' >> $sctemp
161 endif
162 echo 'rm -f $tempfiles' >> $sctemp
163 (source $sctemp) |& mail `whoami` &
164 echo "Your job is started in the background."
165 echo "You will be notified by mail when it is done."
