root/radiance/ray/src/util/dayfact.csh
Mon Nov 10 19:08:19 2008 UTC (16 years, 7 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.8: +4 -4 lines
Mon Aug 25 04:50:32 2008 UTC (16 years, 10 months ago) by greg
Changes since 2.7: +15 -15 lines
Made temporary files safe from malicious attackers
Thu Oct 6 05:49:44 2005 UTC (19 years, 9 months ago) by greg
CVS Tags: rad3R8, rad3R9
Wed Feb 16 05:40:12 2005 UTC (20 years, 4 months ago) by greg
Changes since 2.5: +13 -13 lines
Sat Feb 22 02:07:30 2003 UTC (22 years, 4 months ago) by greg
Sun Mar 6 15:03:30 1994 UTC (31 years, 4 months ago) by greg
eliminated pvalue command that is no longer needed
Thu Nov 28 17:09:03 1991 UTC (33 years, 7 months ago) by greg
minor change to input
Thu Nov 28 11:49:12 1991 UTC (33 years, 7 months ago) by greg
Changes since 2.1: +91 -30 lines
added daylight savings calculation and reuse of illuminance picture
Tue Nov 12 17:19:31 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.11 , to selected 1.2
Revision 1.11 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 14 12:11:12 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.10: +4 -4 lines
Diff to previous 1.10 , to selected 1.2
Changed maximum of daylight factor computation to constant 100%
Revision 1.10 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 30 16:46:17 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.9 , to selected 1.2
fixed bug with SYSV sed
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 9 15:15:59 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.8 , to selected 1.2
*** empty log message ***
Fri Aug 9 11:06:18 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 1.2
fixed wrong formula and options
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jun 7 17:21:18 1991 UTC (34 years, 1 month ago) by greg
finally remembered to scale daylight factor to percentage
Fri Jun 7 11:04:16 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.5: +6 -6 lines
minor wording changes
Wed Jun 5 16:50:45 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.4: +15 -9 lines
added title to output image
Wed Jun 5 14:01:20 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.3: +18 -12 lines
made rtrace run in background
Wed Jun 5 12:49:16 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.2: +4 -6 lines
Diff to previous 1.2
minor modifications
Revision 1.2 - (view) (download) (as text) (annotate) - [selected]
Wed Jun 5 12:07:43 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.1: +10 -8 lines
initial bug fixes
Wed Jun 5 10:04:24 1991 UTC (34 years, 1 month ago) by greg
Diff to selected 1.2
Links to HEAD: (view) (download) (as text) (annotate) Links to rad5R4: (view) (download) (as text) (annotate)
