--- ray/src/util/dayfact.csh 1991/06/05 12:07:43 1.2 +++ ray/src/util/dayfact.csh 2008/11/10 19:08:19 2.9 @@ -1,50 +1,53 @@ #!/bin/csh -f -# SCCSid "$SunId$ LBL" +# RCSid: $Id: dayfact.csh,v 2.9 2008/11/10 19:08:19 greg Exp $ # # Interactive script to calculate daylight factors # set nofile="none" -set genskyf=$nofile +set illumpic=$nofile set octree=$nofile set dfpict=$nofile set ilpict=$nofile +set dspict=$nofile +set nodaysav=1 +set fcopts=($*) +set designlvl=500 set wporig=(0 0 0) set wpsize=(1 1) -set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .1 .1 .1) +set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .3 .3 .3) +set maxres=128 +set td=`mktemp -d /tmp/df.XXXXXX` -set maxres=64 -set iltemp=/usr/tmp/il$$.pic -set tempfiles=($iltemp) - alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' -onintr quit - cat <<_EOF_ DAYLIGHT FACTOR CALCULATION -This script calculates daylight factors and/or illuminance levels on a -rectangular workplane and produces a contour plot from the result. The -input is a Radiance scene description (and octree) and the output is one -or more color Radiance pictures. +This script calculates daylight factors, illuminance levels, and/or +energy savings due to daylight on a rectangular workplane and produces +a contour plot from the result. The input is a Radiance scene description +(and octree) and the output is one or more color Radiance pictures. _EOF_ +echo "Have you already calculated an illuminance picture using dayfact?" +readvar illumpic +if ( $illumpic != $nofile ) then + if ( ! -r $illumpic ) then + echo "Cannot read $illumpic" + exit 1 + endif + set title=$illumpic:r + set gotillumpic + goto getgenskyf +endif + readvar octree -if ( "$octree" == "$nofile" || ! -f "$octree" ) then - echo "You must first create an octree with oconv" - echo "before running this script." +if ( $octree == $nofile || ! -f $octree ) then + echo "You must first create an octree with" + echo "oconv before running this script." exit 1 endif -echo "" -echo "In what scene file is the gensky command located?" -readvar genskyf -if ( "$genskyf" == "$nofile" || ! -r "$genskyf" ) then - echo "You will not be able to compute" - echo "daylight factors without a gensky file" -else - set extamb=`xform -e $genskyf|sed -n 's/^# Ground ambient level: //p'` - echo extamb = $extamb -endif +set title="$octree:r" echo -n "Is the z-axis your zenith direction? " if ( "$<" !~ [yY]* ) then echo "I'm sorry, you cannot use this script" @@ -59,36 +62,105 @@ set wpsize=($wpsize) set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`) set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`) echo "What calculation options do you want to give to rtrace?" -echo "(It is very important to set the -a? options correctly.)" +echo "(It is very important to set the -a* options correctly.)" readvar rtargs +echo "Do you want to save the illuminance picture for later runs?" +readvar illumpic +############ +getgenskyf: +set genskyf=$nofile +echo "In what scene file is the gensky command located?" +readvar genskyf +if ( $genskyf == $nofile ) then + echo "You will not be able to compute daylight factors" + echo "or energy savings since there is no gensky file." +else + xform -e $genskyf > $td/gsf + grep '^# gensky ' $td/gsf + if ( $status ) then + echo "The file $genskyf does not contain a gensky command\!" + rm -f $td/gsf + goto getgenskyf + endif + set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' $td/gsf` + set extamb=`sed -n 's/^# Ground ambient level: //p' $td/gsf` + grep -s '^# gensky .* -c' $td/gsf + set nodaysav=$status + rm -f $td/gsf + if ( $nodaysav ) then + echo "The gensky command was not done for an overcast sky" + echo "(-c option), so energy savings cannot be calculated." + echo -n "Continue anyway? " + if ( "$<" =~ [nN]* ) then + exit 0 + endif + endif +endif echo "Illuminance contour picture if you want one" readvar ilpict if ( $?extamb ) then echo "Daylight factor contour picture if you want one" readvar dfpict endif -if ( "$ilpict" == "$nofile" && "$dfpict" == "$nofile" ) then +if ( ! $nodaysav ) then + echo "Energy savings contour picture if you want one" + readvar dspict + if ( $dspict != $nofile ) then + echo "Workplane design level (lux)" + readvar designlvl + endif +endif +if ( $ilpict == $nofile && $dfpict == $nofile && $dspict == $nofile ) then echo "Since you don't want any output, I guess we're done." exit 0 endif -echo "Starting rtrace calculation -- this will take some time..." -cnt $wpres[2] $wpres[1] \ +echo "Title for output picture" +readvar title +set sctemp=$td/sc.csh +cat <<'_EOF_' > $sctemp +if ( $illumpic != $nofile ) then + set iltemp="" +else + set iltemp=$td/il.hdr + set illumpic=$iltemp +endif +set tltemp=$td/tl.hdr +set dstemp=$td/ds.hdr +set temp1=$td/tfa +echo "Your dayfact job is finished." +echo "Please check for error messages below." +echo "" +set echo +if ( ! $?gotillumpic ) then + cnt $wpres[2] $wpres[1] \ | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \ -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \ -e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \ - | rtrace $rtargs -I -ov -faf $octree \ - | pvalue -r -x $wpres[1] -y $wpres[2] -df \ - | pfilt -h 20 -n 0 -x 256 -y 256 -p 1 -r 1 > $iltemp -set maxval=`getinfo < $iltemp | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'` -if ( "$ilpict" != "$nofile" ) then - echo "Making illuminance contour picture $ilpict..." - falsecolor -s "$maxval*470" -l Lux -log 2 -cl -pi $iltemp > $ilpict + | rtrace $rtargs -h+ -I+ -ov -fac -x $wpres[1] -y $wpres[2] $octree \ + > $temp1 + pfilt -h 20 -n 0 -x 300 -y 300 -p 1 -r 1 $temp1 > $illumpic endif -if ( "$dfpict" != "$nofile" ) then - echo "Making daylight factor contour picture $dfpict..." - falsecolor -s "$maxval/$extamb" -m "1/$extamb" -l DF \ - -log 2 -cl -pi $iltemp > $dfpict +set maxval=`getinfo < $illumpic | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'` +if ("$maxval" == "") set maxval=3 +psign -h 42 " $title " | pfilt -1 -x /2 -y /2 > $tltemp +'_EOF_' +if ( $ilpict != $nofile ) then + echo 'falsecolor -cb -l Lux -s "$maxval*179" \\ + $fcopts -m 179 -ip $illumpic \\ + | pcompos -a 1 - $tltemp > $ilpict' >> $sctemp endif -echo "Done." -quit: - rm -f $tempfiles +if ( $dfpict != $nofile ) then + echo 'falsecolor -cb -l DF -s 16 \\ + $fcopts -m "100/PI/$extamb" -ip $illumpic \\ + | pcompos -a 1 - $tltemp > $dfpict' >> $sctemp +endif +if ( $dspict != $nofile ) then + echo 'pcomb -e "lo=1-$designlvl/20000*3.1416*$extamb/li(1)" \\ + -o $illumpic | falsecolor -cb -l "%Save" -s 100 \\ + $fcopts -m 100 -p $illumpic \\ + | pcompos -a 1 - $tltemp > $dspict' >> $sctemp +endif +echo 'rm -r $td' >> $sctemp +(source $sctemp) |& mail `whoami` & +echo "Your job is started in the background." +echo "You will be notified by mail when it is done."
