root/radiance/ray/src/util/dayfact.csh
Revision: 2.9
Committed: Mon Nov 10 19:08:19 2008 UTC (16 years, 6 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3, HEAD
Changes since 2.8: +4 -4 lines
Error occurred while calculating annotation data.
1 #!/bin/csh -f
2 # RCSid: $Id: dayfact.csh,v 2.8 2008/08/25 04:50:32 greg Exp $
3 #
4 # Interactive script to calculate daylight factors
5 #
6 set nofile="none"
7 set illumpic=$nofile
8 set octree=$nofile
9 set dfpict=$nofile
10 set ilpict=$nofile
11 set dspict=$nofile
12 set nodaysav=1
13 set fcopts=($*)
14 set designlvl=500
15 set wporig=(0 0 0)
16 set wpsize=(1 1)
17 set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .3 .3 .3)
18 set maxres=128
19 set td=`mktemp -d /tmp/df.XXXXXX`
20
21 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
22
23 cat <<_EOF_
24 DAYLIGHT FACTOR CALCULATION
25
26 This script calculates daylight factors, illuminance levels, and/or
27 energy savings due to daylight on a rectangular workplane and produces
28 a contour plot from the result. The input is a Radiance scene description
29 (and octree) and the output is one or more color Radiance pictures.
30
31 _EOF_
32 echo "Have you already calculated an illuminance picture using dayfact?"
33 readvar illumpic
34 if ( $illumpic != $nofile ) then
35 if ( ! -r $illumpic ) then
36 echo "Cannot read $illumpic"
37 exit 1
38 endif
39 set title=$illumpic:r
40 set gotillumpic
41 goto getgenskyf
42 endif
43
44 readvar octree
45 if ( $octree == $nofile || ! -f $octree ) then
46 echo "You must first create an octree with"
47 echo "oconv before running this script."
48 exit 1
49 endif
50 set title="$octree:r"
51 echo -n "Is the z-axis your zenith direction? "
52 if ( "$<" !~ [yY]* ) then
53 echo "I'm sorry, you cannot use this script"
54 exit 1
55 endif
56 echo "What is the origin (smallest x y z coordinates) of the workplane?"
57 readvar wporig
58 set wporig=($wporig)
59 echo "What is the x and y size (width and length) of the workplane?"
60 readvar wpsize
61 set wpsize=($wpsize)
62 set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`)
63 set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`)
64 echo "What calculation options do you want to give to rtrace?"
65 echo "(It is very important to set the -a* options correctly.)"
66 readvar rtargs
67 echo "Do you want to save the illuminance picture for later runs?"
68 readvar illumpic
69 ############
70 getgenskyf:
71 set genskyf=$nofile
72 echo "In what scene file is the gensky command located?"
73 readvar genskyf
74 if ( $genskyf == $nofile ) then
75 echo "You will not be able to compute daylight factors"
76 echo "or energy savings since there is no gensky file."
77 else
78 xform -e $genskyf > $td/gsf
79 grep '^# gensky ' $td/gsf
80 if ( $status ) then
81 echo "The file $genskyf does not contain a gensky command\!"
82 rm -f $td/gsf
83 goto getgenskyf
84 endif
85 set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' $td/gsf`
86 set extamb=`sed -n 's/^# Ground ambient level: //p' $td/gsf`
87 grep -s '^# gensky .* -c' $td/gsf
88 set nodaysav=$status
89 rm -f $td/gsf
90 if ( $nodaysav ) then
91 echo "The gensky command was not done for an overcast sky"
92 echo "(-c option), so energy savings cannot be calculated."
93 echo -n "Continue anyway? "
94 if ( "$<" =~ [nN]* ) then
95 exit 0
96 endif
97 endif
98 endif
99 echo "Illuminance contour picture if you want one"
100 readvar ilpict
101 if ( $?extamb ) then
102 echo "Daylight factor contour picture if you want one"
103 readvar dfpict
104 endif
105 if ( ! $nodaysav ) then
106 echo "Energy savings contour picture if you want one"
107 readvar dspict
108 if ( $dspict != $nofile ) then
109 echo "Workplane design level (lux)"
110 readvar designlvl
111 endif
112 endif
113 if ( $ilpict == $nofile && $dfpict == $nofile && $dspict == $nofile ) then
114 echo "Since you don't want any output, I guess we're done."
115 exit 0
116 endif
117 echo "Title for output picture"
118 readvar title
119 set sctemp=$td/sc.csh
120 cat <<'_EOF_' > $sctemp
121 if ( $illumpic != $nofile ) then
122 set iltemp=""
123 else
124 set iltemp=$td/il.hdr
125 set illumpic=$iltemp
126 endif
127 set tltemp=$td/tl.hdr
128 set dstemp=$td/ds.hdr
129 set temp1=$td/tfa
130 echo "Your dayfact job is finished."
131 echo "Please check for error messages below."
132 echo ""
133 set echo
134 if ( ! $?gotillumpic ) then
135 cnt $wpres[2] $wpres[1] \
136 | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \
137 -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \
138 -e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \
139 | rtrace $rtargs -h+ -I+ -ov -fac -x $wpres[1] -y $wpres[2] $octree \
140 > $temp1
141 pfilt -h 20 -n 0 -x 300 -y 300 -p 1 -r 1 $temp1 > $illumpic
142 endif
143 set maxval=`getinfo < $illumpic | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'`
144 if ("$maxval" == "") set maxval=3
145 psign -h 42 " $title " | pfilt -1 -x /2 -y /2 > $tltemp
146 '_EOF_'
147 if ( $ilpict != $nofile ) then
148 echo 'falsecolor -cb -l Lux -s "$maxval*179" \\
149 $fcopts -m 179 -ip $illumpic \\
150 | pcompos -a 1 - $tltemp > $ilpict' >> $sctemp
151 endif
152 if ( $dfpict != $nofile ) then
153 echo 'falsecolor -cb -l DF -s 16 \\
154 $fcopts -m "100/PI/$extamb" -ip $illumpic \\
155 | pcompos -a 1 - $tltemp > $dfpict' >> $sctemp
156 endif
157 if ( $dspict != $nofile ) then
158 echo 'pcomb -e "lo=1-$designlvl/20000*3.1416*$extamb/li(1)" \\
159 -o $illumpic | falsecolor -cb -l "%Save" -s 100 \\
160 $fcopts -m 100 -p $illumpic \\
161 | pcompos -a 1 - $tltemp > $dspict' >> $sctemp
162 endif
163 echo 'rm -r $td' >> $sctemp
164 (source $sctemp) |& mail `whoami` &
165 echo "Your job is started in the background."
166 echo "You will be notified by mail when it is done."
