--- ray/src/util/dayfact.csh 1991/06/05 14:01:20 1.4 +++ ray/src/util/dayfact.csh 1991/08/09 15:15:59 1.9 @@ -12,11 +12,7 @@ set fcopts=($*) set wporig=(0 0 0) set wpsize=(1 1) set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .1 .1 .1) - set maxres=128 -set iltemp=/usr/tmp/il$$.pic -set sctemp=/usr/tmp/sc$$.csh -set tempfiles=($iltemp $sctemp) alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' @@ -31,16 +27,18 @@ or more color Radiance pictures. _EOF_ readvar octree if ( "$octree" == "$nofile" || ! -f "$octree" ) then - echo "You must first create an octree with oconv" - echo "before running this script." + echo "You must first create an octree with" + echo "oconv before running this script." exit 1 endif +set title="$octree:r" echo "In what scene file is the gensky command located?" readvar genskyf if ( "$genskyf" == "$nofile" || ! -r "$genskyf" ) then - echo "You will not be able to compute" - echo "daylight factors without a gensky file" + echo "You will not be able to compute daylight" + echo "factors since there is no gensky file." else + set title=$title\ `sed -n 's/^.*\ $sctemp -onintr quit +set iltemp=/usr/tmp/il$$.pic +set tltemp=/usr/tmp/tl$$.pic +set tempfiles=($iltemp $sctemp $tltemp) echo "Your dayfact job is finished." echo "Please check for error messages below." echo "" @@ -79,20 +82,23 @@ cnt $wpres[2] $wpres[1] \ | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \ -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \ -e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \ - | rtrace $rtargs -I -ov -faf $octree \ + | rtrace $rtargs -h+ -I+ -ov -faf $octree \ | pvalue -r -x $wpres[1] -y $wpres[2] -df \ | pfilt -h 20 -n 0 -x 350 -y 350 -p 1 -r 1 > $iltemp set maxval=`getinfo < $iltemp | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'` +psign -h 50 " $title " | pfilt -1 -x /2 -y /2 > $tltemp '_EOF_' if ( "$ilpict" != "$nofile" ) then - echo 'falsecolor -cb -l Lux $fcopts -s "$maxval*470" -m 470 \\ - -pi $iltemp > $ilpict' >> $sctemp + echo 'falsecolor -cb -l Lux $fcopts \\ + -s "$maxval*470" -m 470 -ip $iltemp \\ + | pcompos -a 1 - $tltemp > $ilpict' >> $sctemp endif if ( "$dfpict" != "$nofile" ) then - echo 'falsecolor -cb -l DF $fcopts -s "$maxval/$extamb" \\ - -m "1/$extamb" -pi $iltemp > $dfpict' >> $sctemp + echo 'falsecolor -cb -l DF $fcopts \\ + -s "100/PI*$maxval/$extamb" -m "100/PI/$extamb" -ip $iltemp \\ + | pcompos -a 1 - $tltemp > $dfpict' >> $sctemp endif echo 'rm -f $tempfiles' >> $sctemp (source $sctemp) |& mail `whoami` & echo "Your job is started in the background." -echo "I will send you mail when it is done." +echo "You will be notified by mail when it is done."
