--- ray/src/util/dayfact.csh 2005/10/06 05:49:44 2.7 +++ ray/src/util/dayfact.csh 2008/08/25 04:50:32 2.8 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid: $Id: dayfact.csh,v 2.7 2005/10/06 05:49:44 greg Exp $ +# RCSid: $Id: dayfact.csh,v 2.8 2008/08/25 04:50:32 greg Exp $ # # Interactive script to calculate daylight factors # @@ -16,6 +16,7 @@ set wporig=(0 0 0) set wpsize=(1 1) set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .3 .3 .3) set maxres=128 +set td=`mktemp -d /tmp/df.XXXXXX` alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' @@ -74,18 +75,18 @@ if ( $genskyf == $nofile ) then echo "You will not be able to compute daylight factors" echo "or energy savings since there is no gensky file." else - xform -e $genskyf > /tmp/gsf$$ - grep '^# gensky ' /tmp/gsf$$ + xform -e $genskyf > $td/gsf + grep '^# gensky ' $td/gsf if ( $status ) then echo "The file $genskyf does not contain a gensky command\!" - rm -f /tmp/gsf$$ + rm -f $td/gsf goto getgenskyf endif - set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' /tmp/gsf$$` - set extamb=`sed -n 's/^# Ground ambient level: //p' /tmp/gsf$$` - grep -s '^# gensky .* -c' /tmp/gsf$$ + set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' $td/gsf` + set extamb=`sed -n 's/^# Ground ambient level: //p' $td/gsf` + grep -s '^# gensky .* -c' $td/gsf set nodaysav=$status - rm -f /tmp/gsf$$ + rm -f $td/gsf if ( $nodaysav ) then echo "The gensky command was not done for an overcast sky" echo "(-c option), so energy savings cannot be calculated." @@ -115,18 +116,17 @@ if ( $ilpict == $nofile && $dfpict == $nofile && $dspi endif echo "Title for output picture" readvar title -set sctemp=/tmp/sc$$.csh +set sctemp=$td/sc.csh cat <<'_EOF_' > $sctemp if ( $illumpic != $nofile ) then set iltemp="" else - set iltemp=/tmp/il$$.pic + set iltemp=$td/il.pic set illumpic=$iltemp endif -set tltemp=/tmp/tl$$.pic -set dstemp=/tmp/ds$$.pic -set temp1=/tmp/tfa$$ -set tempfiles=($iltemp $sctemp $tltemp $dstemp $temp1) +set tltemp=$td/tl.pic +set dstemp=$td/ds.pic +set temp1=$td/tfa echo "Your dayfact job is finished." echo "Please check for error messages below." echo "" @@ -160,7 +160,7 @@ if ( $dspict != $nofile ) then $fcopts -m 100 -p $illumpic \\ | pcompos -a 1 - $tltemp > $dspict' >> $sctemp endif -echo 'rm -f $tempfiles' >> $sctemp +echo 'rm -r $td' >> $sctemp (source $sctemp) |& mail `whoami` & echo "Your job is started in the background." echo "You will be notified by mail when it is done."
