root/radiance/ray/src/util/dayfact.csh
Revision: 1.1
Committed: Wed Jun 5 10:04:24 1991 UTC (33 years ago) by greg
Content type: application/x-csh
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Interactive script to calculate daylight factors
5 #
6 set nofile="none"
7 set genskyf=$nofile
8 set octree=$nofile
9 set dfpict=$nofile
10 set ilpict=$nofile
11 set wporig=(0 0 0)
12 set wpsize=(1 1)
13 set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .1 .1 .1)
14
15 set maxres=64
16 set iltemp=/usr/tmp/il$$.pic
17 set tempfiles=($iltemp)
18
19 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
20
21 onintr quit
22
23 cat <<_EOF_
24 DAYLIGHT FACTOR CALCULATION
25
26 This script calculates daylight factors and/or illuminance levels on a
27 rectangular workplane and produces a contour plot from the result. The
28 input is a Radiance scene description (and octree) and the output is one
29 or more color Radiance pictures.
30
31 _EOF_
32 readvar octree
33 if ( "$octree" == "$nofile" || ! -f "$octree" ) then
34 echo "You must first create an octree with oconv"
35 echo "before running this script."
36 exit 1
37 endif
38 echo ""
39 echo "In what scene file is the gensky command located?"
40 readvar genskyf
41 if ( "$genskyf" == "$none" || ! -r "$genskyf" ) then
42 echo "You will not be able to compute"
43 echo "daylight factors without a gensky file"
44 else
45 set extamb=`xform -e $genskyf|sed -n 's/^# Ground ambient level: //p'`
46 endif
47 echo "Is the z-axis your zenith direction?"
48 if ( "$ans" !~ [yY]* ) then
49 echo "I'm sorry, you cannot use this script"
50 exit 1
51 endif
52 echo "What is the origin (smallest x y z coordinates) of the workplane?"
53 readvar wporig
54 set wporig=($wporig)
55 echo "What is the x and y size (width and length) of the workplane?"
56 read wpsize
57 set wpsize=($wpsize)
58 set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`)
59 set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`)
60 echo "What calculation options do you want to give to rtrace?"
61 echo "(It is very important to set the -a? options correctly.)"
62 readvar rtargs
63 echo "Illuminance contour picture if you want one"
64 readvar ilpict
65 if ( $?extamb ) then
66 echo "Daylight factor contour picture if you want one"
67 readvar dfpict
68 endif
69 if ( "$ilpict" == "$nofile" && "$dfpict" == "$nofile" ) then
70 echo "Since you don't want any output, I guess we're done."
71 exit 0
72 endif
73 echo "Starting rtrace calculation -- this will take some time..."
74 cnt $wpres | rcalc -e '$1=($1+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \
75 -e '$2=(1-($2+.5)/$wpres[2])*$wpsize[2]+$wporig[2]" \
76 -e '$3='"$wporig[3]" -e "$4=0;$5=0;$6=1" \
77 | rtrace $rtargs -I -ov -faf $octree \
78 | pvalue -r -x $wpres[1] -y $wpres[2] -df \
79 | pfilt -h 20 -n 0 -x 512 -y 512 -p 1 -r .7 > $iltemp
80 set maxval=`getinfo < $iltemp | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'`
81 if ( "$ilpict" != "$nofile" ) then
82 echo "Making illuminance contour picture $ilpict..."
83 falsecolor -s "$maxval*470" -l Lux -log 2 -cl -pi $iltemp > $ilpict
84 endif
85 if ( "$dfpict" != "$nofile" ) then
86 echo "Making daylight factor contour picture $dfpict..."
87 falsecolor -s "$maxval/$extamb" -m "1/$extamb" -l DF \
88 -log 2 -cl -pi $iltemp > $dfpict
89 endif
90 echo "Done."
91 quit:
92 rm -f $tempfiles
