1 |
#!/bin/csh -f |
2 |
# SCCSid "$SunId$ LBL" |
3 |
4 |
# Interactive script to calculate daylight factors |
5 |
6 |
set nofile="none" |
7 |
set illumpic=$nofile |
8 |
set octree=$nofile |
9 |
set dfpict=$nofile |
10 |
set ilpict=$nofile |
11 |
set dspict=$nofile |
12 |
set nodaysav=1 |
13 |
set fcopts=($*) |
14 |
set designlvl=500 |
15 |
set wporig=(0 0 0) |
16 |
set wpsize=(1 1) |
17 |
set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .3 .3 .3) |
18 |
set maxres=128 |
19 |
20 |
alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' |
21 |
22 |
cat <<_EOF_ |
23 |
DAYLIGHT FACTOR CALCULATION |
24 |
25 |
This script calculates daylight factors, illuminance levels, and/or |
26 |
energy savings due to daylight on a rectangular workplane and produces |
27 |
a contour plot from the result. The input is a Radiance scene description |
28 |
(and octree) and the output is one or more color Radiance pictures. |
29 |
30 |
_EOF_ |
31 |
echo -n "Have you already calculated an illuminance picture with dayfact? " |
32 |
if ( "$<" =~ [yY]* ) then |
33 |
readvar illumpic |
34 |
if ( ! -r $illumpic ) then |
35 |
echo "Cannot read $illumpic" |
36 |
exit 1 |
37 |
endif |
38 |
set title=$illumpic:r |
39 |
set gotillumpic |
40 |
goto getgenskyf |
41 |
endif |
42 |
43 |
readvar octree |
44 |
if ( $octree == $nofile || ! -f $octree ) then |
45 |
echo "You must first create an octree with" |
46 |
echo "oconv before running this script." |
47 |
exit 1 |
48 |
endif |
49 |
set title="$octree:r" |
50 |
echo -n "Is the z-axis your zenith direction? " |
51 |
if ( "$<" !~ [yY]* ) then |
52 |
echo "I'm sorry, you cannot use this script" |
53 |
exit 1 |
54 |
endif |
55 |
echo "What is the origin (smallest x y z coordinates) of the workplane?" |
56 |
readvar wporig |
57 |
set wporig=($wporig) |
58 |
echo "What is the x and y size (width and length) of the workplane?" |
59 |
readvar wpsize |
60 |
set wpsize=($wpsize) |
61 |
set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`) |
62 |
set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`) |
63 |
echo "What calculation options do you want to give to rtrace?" |
64 |
echo "(It is very important to set the -a* options correctly.)" |
65 |
readvar rtargs |
66 |
echo "Do you want to save the illuminance picture for later runs?" |
67 |
readvar illumpic |
68 |
69 |
getgenskyf: |
70 |
set genskyf=$nofile |
71 |
echo "In what scene file is the gensky command located?" |
72 |
readvar genskyf |
73 |
if ( $genskyf == $nofile ) then |
74 |
echo "You will not be able to compute daylight factors" |
75 |
echo "or energy savings since there is no gensky file." |
76 |
else |
77 |
xform -e $genskyf > /usr/tmp/gsf$$ |
78 |
grep '^# gensky ' /usr/tmp/gsf$$ |
79 |
if ( $status ) then |
80 |
echo "The file $genskyf does not contain a gensky command\!" |
81 |
rm -f /usr/tmp/gsf$$ |
82 |
goto getgenskyf |
83 |
endif |
84 |
set title=$title\ `sed -n 's/^# gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' /usr/tmp/gsf$$` |
85 |
set extamb=`sed -n 's/^# Ground ambient level: //p' /usr/tmp/gsf$$` |
86 |
grep -s '^# gensky .* -c' /usr/tmp/gsf$$ |
87 |
set nodaysav=$status |
88 |
89 |
if ( $nodaysav ) then |
90 |
echo "The gensky command was not done for an overcast sky" |
91 |
echo "(-c option), so energy savings cannot be calculated." |
92 |
echo -n "Continue anyway? " |
93 |
if ( "$<" =~ [nN]* ) then |
94 |
exit 0 |
95 |
endif |
96 |
endif |
97 |
endif |
98 |
echo "Illuminance contour picture if you want one" |
99 |
readvar ilpict |
100 |
if ( $?extamb ) then |
101 |
echo "Daylight factor contour picture if you want one" |
102 |
readvar dfpict |
103 |
endif |
104 |
if ( ! $nodaysav ) then |
105 |
echo "Energy savings contour picture if you want one" |
106 |
readvar dspict |
107 |
if ( $dspict != $nofile ) then |
108 |
echo "Workplane design level (lux)" |
109 |
readvar designlvl |
110 |
endif |
111 |
endif |
112 |
if ( $ilpict == $nofile && $dfpict == $nofile && $dspict == $nofile ) then |
113 |
echo "Since you don't want any output, I guess we're done." |
114 |
exit 0 |
115 |
endif |
116 |
echo "Title for output picture" |
117 |
readvar title |
118 |
set sctemp=/usr/tmp/sc$$.csh |
119 |
cat <<'_EOF_' > $sctemp |
120 |
if ( $illumpic != $nofile ) then |
121 |
set iltemp="" |
122 |
else |
123 |
set iltemp=/usr/tmp/il$$.pic |
124 |
set illumpic=$iltemp |
125 |
endif |
126 |
set tltemp=/usr/tmp/tl$$.pic |
127 |
set dstemp=/usr/tmp/ds$$.pic |
128 |
set temp1=/usr/tmp/tfa$$ |
129 |
set tempfiles=($iltemp $sctemp $tltemp $dstemp $temp1) |
130 |
echo "Your dayfact job is finished." |
131 |
echo "Please check for error messages below." |
132 |
echo "" |
133 |
set echo |
134 |
if ( ! $?gotillumpic ) then |
135 |
cnt $wpres[2] $wpres[1] \ |
136 |
| rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \ |
137 |
-e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \ |
138 |
-e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \ |
139 |
| rtrace $rtargs -h+ -I+ -ov -faf $octree \ |
140 |
| pvalue -r -y $wpres[2] +x $wpres[1] -df > $temp1 |
141 |
pfilt -h 20 -n 0 -x 300 -y 300 -p 1 -r 1 $temp1 > $illumpic |
142 |
endif |
143 |
set maxval=`getinfo < $illumpic | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'` |
144 |
psign -h 42 " $title " | pfilt -1 -x /2 -y /2 > $tltemp |
145 |
'_EOF_' |
146 |
if ( $ilpict != $nofile ) then |
147 |
echo 'falsecolor -cb -l Lux -s "$maxval*179" \\ |
148 |
$fcopts -m 179 -ip $illumpic \\ |
149 |
| pcompos -a 1 - $tltemp > $ilpict' >> $sctemp |
150 |
endif |
151 |
if ( $dfpict != $nofile ) then |
152 |
echo 'falsecolor -cb -l DF -s 50 \\ |
153 |
$fcopts -m "100/PI/$extamb" -ip $illumpic \\ |
154 |
| pcompos -a 1 - $tltemp > $dfpict' >> $sctemp |
155 |
endif |
156 |
157 |
echo 'pcomb -e "lo=1-$designlvl/20000*3.1416*$extamb/li(1)" \\ |
158 |
-o $illumpic | falsecolor -cb -l "%Save" -s 100 \\ |
159 |
$fcopts -m 100 -p $illumpic \\ |
160 |
| pcompos -a 1 - $tltemp > $dspict' >> $sctemp |
161 |
endif |
162 |
echo 'rm -f $tempfiles' >> $sctemp |
163 |
(source $sctemp) |& mail `whoami` & |
164 |
echo "Your job is started in the background." |
165 |
echo "You will be notified by mail when it is done." |
