root/radiance/ray/src/util/dayfact.csh
Revision: 2.1
Committed: Tue Nov 12 17:19:31 1991 UTC (32 years, 11 months ago) by greg
Content type: application/x-csh
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Interactive script to calculate daylight factors
5 #
6 set nofile="none"
7 set genskyf=$nofile
8 set octree=$nofile
9 set dfpict=$nofile
10 set ilpict=$nofile
11 set fcopts=($*)
12 set wporig=(0 0 0)
13 set wpsize=(1 1)
14 set rtargs=(-ab 1 -ad 256 -as 128 -aa .15 -av .1 .1 .1)
15 set maxres=128
16
17 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
18
19 cat <<_EOF_
20 DAYLIGHT FACTOR CALCULATION
21
22 This script calculates daylight factors and/or illuminance levels on a
23 rectangular workplane and produces a contour plot from the result. The
24 input is a Radiance scene description (and octree) and the output is one
25 or more color Radiance pictures.
26
27 _EOF_
28 readvar octree
29 if ( "$octree" == "$nofile" || ! -f "$octree" ) then
30 echo "You must first create an octree with"
31 echo "oconv before running this script."
32 exit 1
33 endif
34 set title="$octree:r"
35 echo "In what scene file is the gensky command located?"
36 readvar genskyf
37 if ( "$genskyf" == "$nofile" || ! -r "$genskyf" ) then
38 echo "You will not be able to compute daylight"
39 echo "factors since there is no gensky file."
40 else
41 set title=$title\ `sed -n 's/^.*gensky *\([0-9][0-9]* *[0-9][0-9]* *[0-9][0-9.]*\).*$/\1/p' $genskyf`
42 set extamb=`xform -e $genskyf|sed -n 's/^# Ground ambient level: //p'`
43 endif
44 echo -n "Is the z-axis your zenith direction? "
45 if ( "$<" !~ [yY]* ) then
46 echo "I'm sorry, you cannot use this script"
47 exit 1
48 endif
49 echo "What is the origin (smallest x y z coordinates) of the workplane?"
50 readvar wporig
51 set wporig=($wporig)
52 echo "What is the x and y size (width and length) of the workplane?"
53 readvar wpsize
54 set wpsize=($wpsize)
55 set wpres=(`rcalc -n -e '$1=if(l,'"floor($maxres*$wpsize[1]/$wpsize[2]),$maxres);"'$2=if(l,'"$maxres,floor($maxres*$wpsize[2]/$wpsize[1]));l=$wpsize[2]-$wpsize[1]"`)
56 set rtargs=($rtargs -ar `getinfo -d<$octree|rcalc -e '$1=floor(16*$4/'"($wpsize[1]+$wpsize[2]))"`)
57 echo "What calculation options do you want to give to rtrace?"
58 echo "(It is very important to set the -a* options correctly.)"
59 readvar rtargs
60 echo "Illuminance contour picture if you want one"
61 readvar ilpict
62 if ( $?extamb ) then
63 echo "Daylight factor contour picture if you want one"
64 readvar dfpict
65 endif
66 if ( "$ilpict" == "$nofile" && "$dfpict" == "$nofile" ) then
67 echo "Since you don't want any output, I guess we're done."
68 exit 0
69 endif
70 echo "Title for output picture"
71 readvar title
72 set sctemp=/usr/tmp/sc$$.csh
73 cat <<'_EOF_' > $sctemp
74 set iltemp=/usr/tmp/il$$.pic
75 set tltemp=/usr/tmp/tl$$.pic
76 set tempfiles=($iltemp $sctemp $tltemp)
77 echo "Your dayfact job is finished."
78 echo "Please check for error messages below."
79 echo ""
80 set echo
81 cnt $wpres[2] $wpres[1] \
82 | rcalc -e '$1=($2+.5)/'"$wpres[1]*$wpsize[1]+$wporig[1]" \
83 -e '$2=(1-($1+.5)/'"$wpres[2])*$wpsize[2]+$wporig[2]" \
84 -e '$3='"$wporig[3]" -e '$4=0;$5=0;$6=1' \
85 | rtrace $rtargs -h+ -I+ -ov -faf $octree \
86 | pvalue -r -x $wpres[1] -y $wpres[2] -df \
87 | pfilt -h 20 -n 0 -x 350 -y 350 -p 1 -r 1 > $iltemp
88 set maxval=`getinfo < $iltemp | rcalc -i 'EXPOSURE=${e}' -e '$1=3/e'`
89 psign -h 50 " $title " | pfilt -1 -x /2 -y /2 > $tltemp
90 '_EOF_'
91 if ( "$ilpict" != "$nofile" ) then
92 echo 'falsecolor -cb -l Lux -s "$maxval*470" \\
93 $fcopts -m 470 -ip $iltemp \\
94 | pcompos -a 1 - $tltemp > $ilpict' >> $sctemp
95 endif
96 if ( "$dfpict" != "$nofile" ) then
97 echo 'falsecolor -cb -l DF -s 100 \\
98 $fcopts -m "100/PI/$extamb" -ip $iltemp \\
99 | pcompos -a 1 - $tltemp > $dfpict' >> $sctemp
100 endif
101 echo 'rm -f $tempfiles' >> $sctemp
102 (source $sctemp) |& mail `whoami` &
103 echo "Your job is started in the background."
104 echo "You will be notified by mail when it is done."
