1 |
greg |
1.1 |
#ifndef lint |
2 |
greg |
1.5 |
static const char RCSid[] = "$Id: contour.c,v 1.4 2004/03/26 23:34:23 schorsch Exp $"; |
3 |
greg |
1.1 |
#endif |
4 |
5 |
* contour.c - program to make contour plots, mappings from 3 to |
6 |
* 2 dimenstions. |
7 |
8 |
* 8/22/86 |
9 |
10 |
11 |
greg |
1.3 |
#include <stdio.h> |
12 |
13 |
#include <stdlib.h> |
14 |
greg |
1.1 |
15 |
greg |
1.3 |
#include <ctype.h> |
16 |
greg |
1.1 |
17 |
#define MAXPTS 2048 /* maximum number of input points */ |
18 |
19 |
typedef float DATAPT[3]; |
20 |
21 |
DATAPT xyz[MAXPTS]; /* the input data */ |
22 |
int xyzsiz; |
23 |
24 |
double zmin = 1e20; /* z minimum */ |
25 |
double zmax = -1e20; /* z maximum */ |
26 |
int minset = 0; /* user set minimum? */ |
27 |
int maxset = 0; /* user set maximum? */ |
28 |
29 |
int ncurves = 6; /* number of contours */ |
30 |
31 |
schorsch |
1.4 |
static void getdata(FILE *fp); |
32 |
static int xycmp(const void* p1, const void* p2); |
33 |
static void contour(int n); |
34 |
static void crossings(double z); |
35 |
static void cross(DATAPT p0, DATAPT p1, double z); |
36 |
greg |
1.1 |
37 |
schorsch |
1.4 |
38 |
int |
39 |
main( |
40 |
int argc, |
41 |
char *argv[] |
42 |
43 |
greg |
1.1 |
44 |
FILE *fp; |
45 |
int i; |
46 |
47 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
48 |
switch (argv[i][1]) { |
49 |
case 'n': |
50 |
ncurves = atoi(argv[++i]); |
51 |
break; |
52 |
case 'l': |
53 |
zmin = atof(argv[++i]); |
54 |
minset = 1; |
55 |
break; |
56 |
case 'u': |
57 |
zmax = atof(argv[++i]); |
58 |
maxset = 1; |
59 |
break; |
60 |
default: |
61 |
fprintf(stderr, "%s: unknown option: %s\n", |
62 |
argv[0], argv[i]); |
63 |
exit(1); |
64 |
65 |
66 |
if (i == argc) |
67 |
getdata(stdin); |
68 |
else if (i < argc-1) { |
69 |
fprintf(stderr, "%s: too many file names\n", argv[0]); |
70 |
exit(1); |
71 |
} else if ((fp = fopen(argv[i], "r")) == NULL) { |
72 |
fprintf(stderr, "%s: file not found\n", argv[i]); |
73 |
exit(1); |
74 |
} else |
75 |
getdata(fp); |
76 |
77 |
qsort(xyz, xyzsiz, sizeof(DATAPT), xycmp); /* sort data */ |
78 |
79 |
for (i = 0; i < ncurves; i++) /* do contours */ |
80 |
contour(i); |
81 |
82 |
exit(0); |
83 |
84 |
85 |
86 |
schorsch |
1.4 |
static void |
87 |
getdata( /* read input data */ |
88 |
FILE *fp |
89 |
90 |
greg |
1.1 |
91 |
register int i; |
92 |
93 |
while (xyzsiz < MAXPTS) { |
94 |
for (i = 0; i < 3; i++) |
95 |
if (fscanf(fp, "%f", &xyz[xyzsiz][i]) != 1) |
96 |
break; |
97 |
if (i != 3) |
98 |
break; |
99 |
schorsch |
1.4 |
if (xyz[xyzsiz][2] < zmin) { |
100 |
if (minset) { |
101 |
greg |
1.1 |
continue; |
102 |
schorsch |
1.4 |
} else { |
103 |
greg |
1.1 |
zmin = xyz[xyzsiz][2]; |
104 |
schorsch |
1.4 |
105 |
106 |
if (xyz[xyzsiz][2] > zmax) { |
107 |
if (maxset) { |
108 |
greg |
1.1 |
continue; |
109 |
schorsch |
1.4 |
} else { |
110 |
greg |
1.1 |
zmax = xyz[xyzsiz][2]; |
111 |
schorsch |
1.4 |
112 |
113 |
greg |
1.1 |
xyzsiz++; |
114 |
115 |
if (!feof(fp)) { |
116 |
fprintf(stderr, "Error reading input data\n"); |
117 |
exit(1); |
118 |
119 |
120 |
121 |
122 |
schorsch |
1.4 |
static int |
123 |
xycmp( /* -1 if p1 < p2, 0 if equal, 1 if p1 > p2 */ |
124 |
const void* p1, |
125 |
const void* p2 |
126 |
127 |
128 |
const float* pp1 = p1; |
129 |
const float* pp2 = p2; |
130 |
if (pp1[0] > pp2[0]) |
131 |
greg |
1.1 |
return(1); |
132 |
schorsch |
1.4 |
if (pp1[0] < pp2[0]) |
133 |
greg |
1.1 |
return(-1); |
134 |
schorsch |
1.4 |
if (pp1[1] > pp2[1]) |
135 |
greg |
1.1 |
return(1); |
136 |
schorsch |
1.4 |
if (pp1[1] < pp2[1]) |
137 |
greg |
1.1 |
return(-1); |
138 |
return(0); |
139 |
140 |
141 |
142 |
schorsch |
1.4 |
static void |
143 |
contour( /* make contour n */ |
144 |
int n |
145 |
146 |
greg |
1.1 |
147 |
double z; |
148 |
149 |
z = (n+.5)*(zmax-zmin)/ncurves + zmin; |
150 |
printf("%clabel=\"%f\";\n", n+'A', z); |
151 |
printf("%cdata=\n", n+'A'); |
152 |
crossings(z); |
153 |
printf(";\n"); |
154 |
155 |
156 |
157 |
schorsch |
1.4 |
static void |
158 |
crossings( /* find crossings for z */ |
159 |
double z |
160 |
161 |
greg |
1.1 |
162 |
register DATAPT *p0, *p1; |
163 |
164 |
p0 = p1 = xyz; |
165 |
while (p0 < xyz+xyzsiz-2) { |
166 |
while (p1 < xyz+xyzsiz-2) { |
167 |
if (p0[0][0] < p1[0][0] && p0[0][1] <= p1[0][1]) |
168 |
break; |
169 |
p1++; |
170 |
171 |
if (p0[0][0] == p0[1][0]) |
172 |
cross(p0[0], p0[1], z); |
173 |
if (p0[0][1] == p1[0][1]) |
174 |
cross(p0[0], p1[0], z); |
175 |
p0++; |
176 |
177 |
178 |
179 |
180 |
schorsch |
1.4 |
static void |
181 |
cross( /* mark crossing between p0 and p1 */ |
182 |
register DATAPT p0, |
183 |
register DATAPT p1, |
184 |
double z |
185 |
186 |
greg |
1.1 |
187 |
if (p1[2] - p0[2] == 0.0) |
188 |
return; |
189 |
z = (z - p0[2])/(p1[2] - p0[2]); |
190 |
if (z < 0.0 || z >= 1.0) |
191 |
return; |
192 |
printf("%e\t", p0[0]*(1.0 - z) + p1[0]*z); |
193 |
printf("%e\n", p0[1]*(1.0 - z) + p1[1]*z); |
194 |
