root/Development/ray/src/util/contour.c
Revision: 1.3
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 10 months ago) by greg
Changes since 1.2: +5 -7 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.3 static const char RCSid[] = "$Id$";
3 greg 1.1 #endif
4     /*
5     * contour.c - program to make contour plots, mappings from 3 to
6     * 2 dimenstions.
7     *
8     * 8/22/86
9     */
10
11 greg 1.3 #include <stdio.h>
12
13     #include <stdlib.h>
14 greg 1.1
15 greg 1.3 #include <ctype.h>
16 greg 1.1
17     #define MAXPTS 2048 /* maximum number of input points */
18
19     typedef float DATAPT[3];
20
21     DATAPT xyz[MAXPTS]; /* the input data */
22     int xyzsiz;
23
24     double zmin = 1e20; /* z minimum */
25     double zmax = -1e20; /* z maximum */
26     int minset = 0; /* user set minimum? */
27     int maxset = 0; /* user set maximum? */
28
29     int ncurves = 6; /* number of contours */
30
31
32     main(argc, argv)
33     int argc;
34     char *argv[];
35     {
36     extern int xycmp();
37     FILE *fp;
38     int i;
39
40     for (i = 1; i < argc && argv[i][0] == '-'; i++)
41     switch (argv[i][1]) {
42     case 'n':
43     ncurves = atoi(argv[++i]);
44     break;
45     case 'l':
46     zmin = atof(argv[++i]);
47     minset = 1;
48     break;
49     case 'u':
50     zmax = atof(argv[++i]);
51     maxset = 1;
52     break;
53     default:
54     fprintf(stderr, "%s: unknown option: %s\n",
55     argv[0], argv[i]);
56     exit(1);
57     }
58
59     if (i == argc)
60     getdata(stdin);
61     else if (i < argc-1) {
62     fprintf(stderr, "%s: too many file names\n", argv[0]);
63     exit(1);
64     } else if ((fp = fopen(argv[i], "r")) == NULL) {
65     fprintf(stderr, "%s: file not found\n", argv[i]);
66     exit(1);
67     } else
68     getdata(fp);
69
70     qsort(xyz, xyzsiz, sizeof(DATAPT), xycmp); /* sort data */
71
72     for (i = 0; i < ncurves; i++) /* do contours */
73     contour(i);
74
75     exit(0);
76     }
77
78
79     getdata(fp) /* read input data */
80     FILE *fp;
81     {
82     register int i;
83
84     while (xyzsiz < MAXPTS) {
85     for (i = 0; i < 3; i++)
86     if (fscanf(fp, "%f", &xyz[xyzsiz][i]) != 1)
87     break;
88     if (i != 3)
89     break;
90     if (xyz[xyzsiz][2] < zmin)
91     if (minset)
92     continue;
93     else
94     zmin = xyz[xyzsiz][2];
95     if (xyz[xyzsiz][2] > zmax)
96     if (maxset)
97     continue;
98     else
99     zmax = xyz[xyzsiz][2];
100     xyzsiz++;
101     }
102     if (!feof(fp)) {
103     fprintf(stderr, "Error reading input data\n");
104     exit(1);
105     }
106     }
107
108
109     int
110     xycmp(p1, p2) /* -1 if p1 < p2, 0 if equal, 1 if p1 > p2 */
111     DATAPT p1, p2;
112     {
113     if (p1[0] > p2[0])
114     return(1);
115     if (p1[0] < p2[0])
116     return(-1);
117     if (p1[1] > p2[1])
118     return(1);
119     if (p1[1] < p2[1])
120     return(-1);
121     return(0);
122     }
123
124
125     contour(n) /* make contour n */
126     int n;
127     {
128     double z;
129
130     z = (n+.5)*(zmax-zmin)/ncurves + zmin;
131     printf("%clabel=\"%f\";\n", n+'A', z);
132     printf("%cdata=\n", n+'A');
133     crossings(z);
134     printf(";\n");
135     }
136
137
138     crossings(z) /* find crossings for z */
139     double z;
140     {
141     register DATAPT *p0, *p1;
142
143     p0 = p1 = xyz;
144     while (p0 < xyz+xyzsiz-2) {
145     while (p1 < xyz+xyzsiz-2) {
146     if (p0[0][0] < p1[0][0] && p0[0][1] <= p1[0][1])
147     break;
148     p1++;
149     }
150     if (p0[0][0] == p0[1][0])
151     cross(p0[0], p0[1], z);
152     if (p0[0][1] == p1[0][1])
153     cross(p0[0], p1[0], z);
154     p0++;
155     }
156     }
157
158
159     cross(p0, p1, z) /* mark crossing between p0 and p1 */
160     register DATAPT p0, p1;
161     double z;
162     {
163     if (p1[2] - p0[2] == 0.0)
164     return;
165     z = (z - p0[2])/(p1[2] - p0[2]);
166     if (z < 0.0 || z >= 1.0)
167     return;
168     printf("%e\t", p0[0]*(1.0 - z) + p1[0]*z);
169     printf("%e\n", p0[1]*(1.0 - z) + p1[1]*z);
170     }
