root/radiance/ray/src/util/contour.c
Revision: 1.5
Committed: Fri Nov 5 03:31:39 2004 UTC (19 years, 7 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.5 static const char RCSid[] = "$Id: contour.c,v 1.4 2004/03/26 23:34:23 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * contour.c - program to make contour plots, mappings from 3 to
6     * 2 dimenstions.
7     *
8     * 8/22/86
9     */
10
11 greg 1.3 #include <stdio.h>
12
13     #include <stdlib.h>
14 greg 1.1
15 greg 1.3 #include <ctype.h>
16 greg 1.1
17     #define MAXPTS 2048 /* maximum number of input points */
18
19     typedef float DATAPT[3];
20
21     DATAPT xyz[MAXPTS]; /* the input data */
22     int xyzsiz;
23
24     double zmin = 1e20; /* z minimum */
25     double zmax = -1e20; /* z maximum */
26     int minset = 0; /* user set minimum? */
27     int maxset = 0; /* user set maximum? */
28
29     int ncurves = 6; /* number of contours */
30
31 schorsch 1.4 static void getdata(FILE *fp);
32     static int xycmp(const void* p1, const void* p2);
33     static void contour(int n);
34     static void crossings(double z);
35     static void cross(DATAPT p0, DATAPT p1, double z);
36 greg 1.1
37 schorsch 1.4
38     int
39     main(
40     int argc,
41     char *argv[]
42     )
43 greg 1.1 {
44     FILE *fp;
45     int i;
46
47     for (i = 1; i < argc && argv[i][0] == '-'; i++)
48     switch (argv[i][1]) {
49     case 'n':
50     ncurves = atoi(argv[++i]);
51     break;
52     case 'l':
53     zmin = atof(argv[++i]);
54     minset = 1;
55     break;
56     case 'u':
57     zmax = atof(argv[++i]);
58     maxset = 1;
59     break;
60     default:
61     fprintf(stderr, "%s: unknown option: %s\n",
62     argv[0], argv[i]);
63     exit(1);
64     }
65
66     if (i == argc)
67     getdata(stdin);
68     else if (i < argc-1) {
69     fprintf(stderr, "%s: too many file names\n", argv[0]);
70     exit(1);
71     } else if ((fp = fopen(argv[i], "r")) == NULL) {
72     fprintf(stderr, "%s: file not found\n", argv[i]);
73     exit(1);
74     } else
75     getdata(fp);
76
77     qsort(xyz, xyzsiz, sizeof(DATAPT), xycmp); /* sort data */
78
79     for (i = 0; i < ncurves; i++) /* do contours */
80     contour(i);
81
82     exit(0);
83     }
84
85
86 schorsch 1.4 static void
87     getdata( /* read input data */
88     FILE *fp
89     )
90 greg 1.1 {
91     register int i;
92
93     while (xyzsiz < MAXPTS) {
94     for (i = 0; i < 3; i++)
95     if (fscanf(fp, "%f", &xyz[xyzsiz][i]) != 1)
96     break;
97     if (i != 3)
98     break;
99 schorsch 1.4 if (xyz[xyzsiz][2] < zmin) {
100     if (minset) {
101 greg 1.1 continue;
102 schorsch 1.4 } else {
103 greg 1.1 zmin = xyz[xyzsiz][2];
104 schorsch 1.4 }
105     }
106     if (xyz[xyzsiz][2] > zmax) {
107     if (maxset) {
108 greg 1.1 continue;
109 schorsch 1.4 } else {
110 greg 1.1 zmax = xyz[xyzsiz][2];
111 schorsch 1.4 }
112     }
113 greg 1.1 xyzsiz++;
114     }
115     if (!feof(fp)) {
116     fprintf(stderr, "Error reading input data\n");
117     exit(1);
118     }
119     }
120
121
122 schorsch 1.4 static int
123     xycmp( /* -1 if p1 < p2, 0 if equal, 1 if p1 > p2 */
124     const void* p1,
125     const void* p2
126     )
127     {
128     const float* pp1 = p1;
129     const float* pp2 = p2;
130     if (pp1[0] > pp2[0])
131 greg 1.1 return(1);
132 schorsch 1.4 if (pp1[0] < pp2[0])
133 greg 1.1 return(-1);
134 schorsch 1.4 if (pp1[1] > pp2[1])
135 greg 1.1 return(1);
136 schorsch 1.4 if (pp1[1] < pp2[1])
137 greg 1.1 return(-1);
138     return(0);
139     }
140
141
142 schorsch 1.4 static void
143     contour( /* make contour n */
144     int n
145     )
146 greg 1.1 {
147     double z;
148
149     z = (n+.5)*(zmax-zmin)/ncurves + zmin;
150     printf("%clabel=\"%f\";\n", n+'A', z);
151     printf("%cdata=\n", n+'A');
152     crossings(z);
153     printf(";\n");
154     }
155
156
157 schorsch 1.4 static void
158     crossings( /* find crossings for z */
159     double z
160     )
161 greg 1.1 {
162     register DATAPT *p0, *p1;
163
164     p0 = p1 = xyz;
165     while (p0 < xyz+xyzsiz-2) {
166     while (p1 < xyz+xyzsiz-2) {
167     if (p0[0][0] < p1[0][0] && p0[0][1] <= p1[0][1])
168     break;
169     p1++;
170     }
171     if (p0[0][0] == p0[1][0])
172     cross(p0[0], p0[1], z);
173     if (p0[0][1] == p1[0][1])
174     cross(p0[0], p1[0], z);
175     p0++;
176     }
177     }
178
179
180 schorsch 1.4 static void
181     cross( /* mark crossing between p0 and p1 */
182     register DATAPT p0,
183     register DATAPT p1,
184     double z
185     )
186 greg 1.1 {
187     if (p1[2] - p0[2] == 0.0)
188     return;
189     z = (z - p0[2])/(p1[2] - p0[2]);
190     if (z < 0.0 || z >= 1.0)
191     return;
192     printf("%e\t", p0[0]*(1.0 - z) + p1[0]*z);
193     printf("%e\n", p0[1]*(1.0 - z) + p1[1]*z);
194     }
