root/radiance/ray/src/util/contour.c
Revision: 1.1
Committed: Tue Mar 12 13:05:08 1991 UTC (33 years, 2 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * contour.c - program to make contour plots, mappings from 3 to
9 * 2 dimenstions.
10 *
11 * 8/22/86
12 */
13
14 #include "stdio.h"
15
16 #include "ctype.h"
17
18 #define MAXPTS 2048 /* maximum number of input points */
19
20 typedef float DATAPT[3];
21
22 DATAPT xyz[MAXPTS]; /* the input data */
23 int xyzsiz;
24
25 double zmin = 1e20; /* z minimum */
26 double zmax = -1e20; /* z maximum */
27 int minset = 0; /* user set minimum? */
28 int maxset = 0; /* user set maximum? */
29
30 int ncurves = 6; /* number of contours */
31
32
33 main(argc, argv)
34 int argc;
35 char *argv[];
36 {
37 extern double atof();
38 extern int xycmp();
39 FILE *fp;
40 int i;
41
42 for (i = 1; i < argc && argv[i][0] == '-'; i++)
43 switch (argv[i][1]) {
44 case 'n':
45 ncurves = atoi(argv[++i]);
46 break;
47 case 'l':
48 zmin = atof(argv[++i]);
49 minset = 1;
50 break;
51 case 'u':
52 zmax = atof(argv[++i]);
53 maxset = 1;
54 break;
55 default:
56 fprintf(stderr, "%s: unknown option: %s\n",
57 argv[0], argv[i]);
58 exit(1);
59 }
60
61 if (i == argc)
62 getdata(stdin);
63 else if (i < argc-1) {
64 fprintf(stderr, "%s: too many file names\n", argv[0]);
65 exit(1);
66 } else if ((fp = fopen(argv[i], "r")) == NULL) {
67 fprintf(stderr, "%s: file not found\n", argv[i]);
68 exit(1);
69 } else
70 getdata(fp);
71
72 qsort(xyz, xyzsiz, sizeof(DATAPT), xycmp); /* sort data */
73
74 for (i = 0; i < ncurves; i++) /* do contours */
75 contour(i);
76
77 exit(0);
78 }
79
80
81 getdata(fp) /* read input data */
82 FILE *fp;
83 {
84 register int i;
85
86 while (xyzsiz < MAXPTS) {
87 for (i = 0; i < 3; i++)
88 if (fscanf(fp, "%f", &xyz[xyzsiz][i]) != 1)
89 break;
90 if (i != 3)
91 break;
92 if (xyz[xyzsiz][2] < zmin)
93 if (minset)
94 continue;
95 else
96 zmin = xyz[xyzsiz][2];
97 if (xyz[xyzsiz][2] > zmax)
98 if (maxset)
99 continue;
100 else
101 zmax = xyz[xyzsiz][2];
102 xyzsiz++;
103 }
104 if (!feof(fp)) {
105 fprintf(stderr, "Error reading input data\n");
106 exit(1);
107 }
108 }
109
110
111 int
112 xycmp(p1, p2) /* -1 if p1 < p2, 0 if equal, 1 if p1 > p2 */
113 DATAPT p1, p2;
114 {
115 if (p1[0] > p2[0])
116 return(1);
117 if (p1[0] < p2[0])
118 return(-1);
119 if (p1[1] > p2[1])
120 return(1);
121 if (p1[1] < p2[1])
122 return(-1);
123 return(0);
124 }
125
126
127 contour(n) /* make contour n */
128 int n;
129 {
130 double z;
131
132 z = (n+.5)*(zmax-zmin)/ncurves + zmin;
133 printf("%clabel=\"%f\";\n", n+'A', z);
134 printf("%cdata=\n", n+'A');
135 crossings(z);
136 printf(";\n");
137 }
138
139
140 crossings(z) /* find crossings for z */
141 double z;
142 {
143 register DATAPT *p0, *p1;
144
145 p0 = p1 = xyz;
146 while (p0 < xyz+xyzsiz-2) {
147 while (p1 < xyz+xyzsiz-2) {
148 if (p0[0][0] < p1[0][0] && p0[0][1] <= p1[0][1])
149 break;
150 p1++;
151 }
152 if (p0[0][0] == p0[1][0])
153 cross(p0[0], p0[1], z);
154 if (p0[0][1] == p1[0][1])
155 cross(p0[0], p1[0], z);
156 p0++;
157 }
158 }
159
160
161 cross(p0, p1, z) /* mark crossing between p0 and p1 */
162 register DATAPT p0, p1;
163 double z;
164 {
165 if (p1[2] - p0[2] == 0.0)
166 return;
167 z = (z - p0[2])/(p1[2] - p0[2]);
168 if (z < 0.0 || z >= 1.0)
169 return;
170 printf("%e\t", p0[0]*(1.0 - z) + p1[0]*z);
171 printf("%e\n", p0[1]*(1.0 - z) + p1[1]*z);
172 }
