root/radiance/ray/src/util/compamb.csh
Revision 3.6 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 16 05:40:11 2005 UTC (19 years, 1 month ago) by greg
Diff to previous 3.5 , to selected 3.3
Revision 3.5 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 22 02:07:30 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 3.4 , to selected 3.3
Revision 3.4 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Oct 18 10:08:10 1998 UTC (25 years, 5 months ago) by gwlarson
Diff to previous 3.3
changed exposure to make the brightest non-source a value of 2 r.t. 1
Revision 3.3 - (view) (download) (as text) (annotate) - [selected]
Fri Oct 16 17:31:06 1998 UTC (25 years, 5 months ago) by gwlarson
Diff to previous 3.2
added comment to modified RIF
Revision 3.2 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 28 10:47:11 1998 UTC (26 years, 2 months ago) by gwlarson
Diff to previous 3.1 , to selected 3.3
serious bug fix
Revision 3.1 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 23 17:18:17 1998 UTC (26 years, 2 months ago) by gregl
Diff to selected 3.3
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R9: (view) (download) (as text) (annotate)
