root/radiance/ray/src/util/compamb.csh
Revision 3.7 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 25 04:50:32 2008 UTC (15 years, 8 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 3.6: +4 -3 lines
Diff to previous 3.6 , to selected 3.5
Made temporary files safe from malicious attackers
Revision 3.6 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 16 05:40:11 2005 UTC (19 years, 2 months ago) by greg
Diff to previous 3.5
Revision 3.5 - (view) (download) (as text) (annotate) - [selected]
Diff to previous 3.4
Revision 3.4 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Oct 18 10:08:10 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 3.3 , to selected 3.5
changed exposure to make the brightest non-source a value of 2 r.t. 1
Revision 3.3 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 16 17:31:06 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 3.2 , to selected 3.5
added comment to modified RIF
Revision 3.2 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 28 10:47:11 1998 UTC (26 years, 3 months ago) by gwlarson
Diff to previous 3.1 , to selected 3.5
serious bug fix
Revision 3.1 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 23 17:18:17 1998 UTC (26 years, 3 months ago) by gregl
Diff to selected 3.5
Links to HEAD: (view) (download) (as text) (annotate) Links to HEAD: (view) (download) (as text) (annotate)
