1 |
2 |
* cmglare.c - routines for calculating glare autonomy. |
3 |
4 |
* N. Jones |
5 |
6 |
7 |
8 |
* Copyright (c) 2017-2019 Nathaniel Jones |
9 |
10 |
* Permission is hereby granted, free of charge, to any person obtaining a copy |
11 |
* of this software and associated documentation files (the "Software"), to deal |
12 |
* in the Software without restriction, including without limitation the rights |
13 |
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell |
14 |
* copies of the Software, and to permit persons to whom the Software is |
15 |
* furnished to do so, subject to the following conditions: |
16 |
17 |
* The above copyright notice and this permission notice shall be included in all |
18 |
* copies or substantial portions of the Software. |
19 |
20 |
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR |
21 |
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, |
22 |
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE |
23 |
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER |
24 |
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, |
25 |
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE |
26 |
* SOFTWARE. |
27 |
28 |
29 |
#include "rtmath.h" |
30 |
#include "cmglare.h" |
31 |
32 |
#define LUMINOUS_EFFICACY 179 /* lumens per Watt */ |
33 |
#define LUMINANCE_THRESHOLD 100 /* minimum threshold that will be interpreted as luminance rather than ratio between Ev and glare source */ |
34 |
35 |
#define ANGLE(u,v) acos(DOT((u),(v))) // TODO need to normalize? |
36 |
37 |
typedef struct reinhart_sky { |
38 |
//int mf; /* Linear divisions per Tregenza patch. */ |
39 |
int rings; /* Number of rings of sky patches. */ |
40 |
//int patches; /* Number of sky patches. */ |
41 |
double ringElevationAngle; /* Angle in radians between rings. */ |
42 |
int *patchesPerRow; /* Sky patches per row. */ |
43 |
int *firstPatchIndex; /* Index of first sky patch in each row. */ |
44 |
double *solidAngle; /* Solid angle of each patch in each row. */ |
45 |
} ReinhartSky; |
46 |
47 |
static const int tnaz[] = { 30, 30, 24, 24, 18, 12, 6 }; /* Number of patches per row */ |
48 |
49 |
extern char* progname; |
50 |
51 |
static ReinhartSky* make_sky(const CMATRIX *smx) |
52 |
53 |
int mf, count, i, j; |
54 |
double remaining = PI / 2; |
55 |
56 |
/* Check sky partitionss */ |
57 |
switch (smx->nrows) { // nrows is Reinhart sky subdivisoins plus one for miss |
58 |
case 2: mf = 0; break; |
59 |
case 146: mf = 1; break; |
60 |
case 578: mf = 2; break; |
61 |
case 1298: mf = 3; break; |
62 |
case 2306: mf = 4; break; |
63 |
case 3602: mf = 5; break; |
64 |
case 5186: mf = 6; break; |
65 |
case 7058: mf = 7; break; |
66 |
case 9218: mf = 8; break; |
67 |
case 11666: mf = 9; break; |
68 |
case 14402: mf = 10; break; |
69 |
case 17426: mf = 11; break; |
70 |
case 20738: mf = 12; break; |
71 |
default: |
72 |
fprintf(stderr, |
73 |
"%s: unknown number of sky patches %d\n", |
74 |
progname, smx->nrows); |
75 |
return NULL; |
76 |
77 |
78 |
/* Allocate sky */ |
79 |
ReinhartSky *sky = (ReinhartSky*)malloc(sizeof(ReinhartSky)); |
80 |
if (!sky) goto memerr; |
81 |
82 |
/* Calculate patches per row */ |
83 |
sky->rings = 7 * mf + 1; |
84 |
sky->patchesPerRow = (int*)malloc(sky->rings * sizeof(int)); |
85 |
sky->firstPatchIndex = (int*)malloc(sky->rings * sizeof(int)); |
86 |
if (!sky->patchesPerRow || !sky->firstPatchIndex) goto memerr; |
87 |
count = 1; // The below horizon patch |
88 |
for (i = 0; i < 7; i++) |
89 |
for (j = 0; j < mf; j++) { |
90 |
sky->firstPatchIndex[i * mf + j] = count; |
91 |
count += sky->patchesPerRow[i * mf + j] = tnaz[i] * mf; |
92 |
93 |
sky->firstPatchIndex[7 * mf] = count; |
94 |
sky->patchesPerRow[7 * mf] = 1; |
95 |
//sky->patches = count + 1; |
96 |
97 |
/* Calculate solid angle of patches in each row */ |
98 |
sky->solidAngle = (double*)malloc(sky->rings * sizeof(double)); |
99 |
if (!sky->solidAngle) goto memerr; |
100 |
sky->ringElevationAngle = PI / (2 * sky->rings - 1); |
101 |
sky->solidAngle[0] = 2 * PI; |
102 |
for (i = 1; i < sky->rings; i++) { |
103 |
remaining -= sky->ringElevationAngle; |
104 |
sky->solidAngle[i] = 2 * PI * (1 - cos(remaining)); // solid angle of cap |
105 |
sky->solidAngle[i - 1] -= sky->solidAngle[i]; |
106 |
sky->solidAngle[i - 1] /= sky->patchesPerRow[i - 1]; |
107 |
108 |
109 |
return sky; |
110 |
111 |
memerr: |
112 |
fprintf(stderr, |
113 |
"%s: out of memory\n", |
114 |
progname); |
115 |
return NULL; |
116 |
117 |
118 |
static void free_sky(ReinhartSky *sky) |
119 |
120 |
if (sky) { |
121 |
free(sky->patchesPerRow); |
122 |
free(sky->firstPatchIndex); |
123 |
free(sky->solidAngle); |
124 |
free(sky); |
125 |
126 |
127 |
128 |
static void get_patch_direction(const ReinhartSky *sky, const int patch, FVECT target) |
129 |
130 |
//if (patch >= sky->patches || patch < 0) throw new RuntimeException("Illegal patch " + patch); |
131 |
if (!patch) { |
132 |
target[0] = target[1] = 0; |
133 |
target[2] = -1; |
134 |
return; // Ignore below horizon? |
135 |
136 |
int row = sky->rings - 1; |
137 |
while (patch < sky->firstPatchIndex[row]) row--; |
138 |
const double alt = PI / 2 - sky->ringElevationAngle * (row - (sky->rings - 1)); |
139 |
const double azi = 2 * PI * (patch - sky->firstPatchIndex[row]) / sky->patchesPerRow[row]; |
140 |
const double cos_alt = cos(alt); |
141 |
target[0] = cos_alt * -sin(azi); |
142 |
target[1] = cos_alt * -cos(azi); |
143 |
target[2] = sin(alt); |
144 |
145 |
146 |
static double get_patch_solid_angle(const ReinhartSky *sky, const int patch, const double cos_theta) |
147 |
148 |
149 |
if (!patch) return 2 * (PI - 2 * acos(cos_theta)); // Solid angle overlap between visible hemisphere and ground hemisphere |
150 |
151 |
152 |
return sky->solidAngle[row]; |
153 |
154 |
155 |
static double get_guth(const FVECT dir, const FVECT forward, const FVECT up) |
156 |
157 |
double posindex; |
158 |
FVECT hv, temp; |
159 |
VCROSS(hv, forward, up); |
160 |
normalize(hv); |
161 |
VCROSS(temp, forward, hv); |
162 |
double phi = ANGLE(dir, temp) - PI / 2; |
163 |
164 |
/* Guth model, equation from IES lighting handbook */ |
165 |
if (phi >= 0) { |
166 |
double sigma = ANGLE(dir, forward); |
167 |
VSUM(hv, forward, dir, 1 / DOT(dir, forward)); |
168 |
normalize(hv); |
169 |
double tau = ANGLE(hv, up); |
170 |
tau *= 180.0 / PI; |
171 |
sigma *= 180.0 / PI; |
172 |
173 |
if (sigma <= 0) |
174 |
sigma = -sigma; |
175 |
176 |
posindex = exp((35.2 - 0.31889 * tau - 1.22 * exp(-2.0 * tau / 9.0)) / 1000.0 * sigma + (21.0 + 0.26667 * tau - 0.002963 * tau * tau) / 100000.0 * sigma * sigma); |
177 |
178 |
/* below line of sight, using Iwata model */ |
179 |
else { |
180 |
double teta = PI / 2 - ANGLE(dir, hv); |
181 |
182 |
if (teta == 0.0) |
183 |
teta = FTINY; |
184 |
185 |
double fact = 0.8; |
186 |
double d = 1 / tan(phi); |
187 |
double s = tan(teta) / tan(phi); |
188 |
double r = sqrt((1 + s * s) / (d * d)); |
189 |
if (r > 0.6) |
190 |
fact = 1.2; |
191 |
if (r > 3) |
192 |
r = 3.0; |
193 |
194 |
posindex = 1.0 + fact * r; |
195 |
196 |
if (posindex > 16) |
197 |
posindex = 16.0; |
198 |
199 |
return posindex; |
200 |
201 |
202 |
float* cm_glare(const CMATRIX *dcmx, const CMATRIX *evmx, const CMATRIX *smx, const int *occupied, const double dgp_limit, const double dgp_threshold, const FVECT *views, const FVECT dir, const FVECT up) |
203 |
204 |
int p, t, c; |
205 |
int hourly_output = dgp_limit < 0; |
206 |
float *dgp_list; |
207 |
ReinhartSky *sky; |
208 |
FVECT vdir; |
209 |
210 |
/* Check consistancy */ |
211 |
if ((dcmx->nrows != evmx->nrows) | (dcmx->ncols != smx->nrows) | (evmx->ncols != smx->ncols)) { |
212 |
fprintf(stderr, |
213 |
"%s: inconsistant matrix dimensions: dc(%d, %d) ev(%d, %d) s(%d, %d)\n", |
214 |
progname, dcmx->nrows, dcmx->ncols, evmx->nrows, evmx->ncols, smx->nrows, smx->ncols); |
215 |
return NULL; |
216 |
217 |
218 |
/* Create output buffer */ |
219 |
dgp_list = (float*)malloc(evmx->nrows * (hourly_output ? evmx->ncols : 1) * sizeof(float)); |
220 |
if (!dgp_list) { |
221 |
fprintf(stderr, |
222 |
"%s: out of memory in cm_glare()\n", |
223 |
progname); |
224 |
return NULL; |
225 |
226 |
227 |
/* Create sky */ |
228 |
sky = make_sky(smx); |
229 |
if (!sky) return NULL; |
230 |
231 |
/* Calculate glare limit */ |
232 |
double ev_max = -1; |
233 |
if (!hourly_output) { |
234 |
ev_max = (dgp_limit - 0.16) / 5.87e-5; |
235 |
if (ev_max < 0) ev_max = 0; |
236 |
237 |
238 |
/* For each position and direction */ |
239 |
if (!views) VCOPY(vdir, dir); |
240 |
for (p = 0; p < evmx->nrows; p++) { |
241 |
/* For each time step */ |
242 |
int occupied_hours = 0; |
243 |
int glare_hours = 0; |
244 |
if (views) VCOPY(vdir, views[p]); |
245 |
for (t = 0; t < evmx->ncols; t++) { |
246 |
if (!occupied[t]) { |
247 |
/* Not occupied */ |
248 |
if (hourly_output) dgp_list[p * evmx->ncols + t] = 0.0f; |
249 |
250 |
else { |
251 |
/* Occupied */ |
252 |
double illum = LUMINOUS_EFFICACY * bright(cm_lval(evmx, p, t)); |
253 |
occupied_hours++; |
254 |
255 |
if (illum <= FTINY) { |
256 |
/* No light, so no glare */ |
257 |
258 |
259 |
else if ((illum >= ev_max) & (!hourly_output)) { |
260 |
/* Guarangeed glare */ |
261 |
glare_hours++; |
262 |
263 |
else { |
264 |
/* Calculate enhanced simplified daylight glare probability */ |
265 |
double sum = 0.0; |
266 |
FVECT patch_normal; |
267 |
for (c = 0; c < smx->nrows; c++) { |
268 |
const double dc = bright(cm_lval(dcmx, p, c)); |
269 |
if (dc > 0) { |
270 |
get_patch_direction(sky, c, patch_normal); |
271 |
if (!c) { |
272 |
/* Direction toward the center of the visible ground */ |
273 |
VADD(patch_normal, patch_normal, vdir); |
274 |
if (normalize(patch_normal) == 0) continue; |
275 |
276 |
const double cos_theta = DOT(vdir, patch_normal); |
277 |
if (cos_theta <= FTINY) continue; |
278 |
const double s = LUMINOUS_EFFICACY * bright(cm_lval(smx, c, t)); |
279 |
const double omega = get_patch_solid_angle(sky, c, cos_theta); |
280 |
const double patch_luminance = (dc * s) / (omega * cos_theta); |
281 |
282 |
double min_patch_luminance = dgp_threshold; |
283 |
if (dgp_threshold < LUMINANCE_THRESHOLD) |
284 |
min_patch_luminance *= illum / PI; // TODO should use average luminance, not illuminance |
285 |
if (patch_luminance < min_patch_luminance) continue; |
286 |
const double P = get_guth(patch_normal, vdir, up); |
287 |
sum += (patch_luminance * patch_luminance * omega) / (P * P); |
288 |
289 |
290 |
291 |
//double dgp = 5.87e-5 * illum + 0.092 * log10(1 + dgp / pow(illum, 1.87)) + 0.159; |
292 |
double eDGPs = 5.87e-5 * illum + 0.0918 * log10(1 + sum / pow(illum, 1.87)) + 0.16; |
293 |
if (illum < 1000) /* low light correction */ |
294 |
eDGPs *= exp(0.024 * illum - 4) / (1 + exp(0.024 * illum - 4)); |
295 |
//eDGPs /= 1.1 - 0.5 * age / 100.0; /* age correction */ |
296 |
if (eDGPs > 1.0) eDGPs = 1.0; |
297 |
298 |
if (hourly_output) |
299 |
dgp_list[p * evmx->ncols + t] = (float)eDGPs; |
300 |
else if (eDGPs >= dgp_limit) |
301 |
glare_hours++; |
302 |
303 |
304 |
305 |
306 |
/* Save glare autonomy */ |
307 |
dgp_list[p] = (float)(occupied_hours - glare_hours) / occupied_hours; |
308 |
309 |
310 |
311 |
free_sky(sky); |
312 |
313 |
return dgp_list; |
314 |
315 |
316 |
static int getvec(FVECT vec, const int dtype, FILE *fp) /* get a vector from fp */ |
317 |
318 |
static float vf[3]; |
319 |
static double vd[3]; |
320 |
char buf[32]; |
321 |
int i; |
322 |
323 |
switch (dtype) { |
324 |
case DTascii: |
325 |
for (i = 0; i < 3; i++) { |
326 |
if (fgetword(buf, sizeof(buf), fp) == NULL || |
327 |
!isflt(buf)) |
328 |
return(-1); |
329 |
vec[i] = atof(buf); |
330 |
331 |
break; |
332 |
case DTfloat: |
333 |
if (getbinary(vf, sizeof(float), 3, fp) != 3) |
334 |
return(-1); |
335 |
VCOPY(vec, vf); |
336 |
break; |
337 |
case DTdouble: |
338 |
if (getbinary(vd, sizeof(double), 3, fp) != 3) |
339 |
return(-1); |
340 |
VCOPY(vec, vd); |
341 |
break; |
342 |
default: |
343 |
fprintf(stderr, |
344 |
"%s: botched input format\n", |
345 |
progname); |
346 |
return(-1); |
347 |
348 |
return(0); |
349 |
350 |
351 |
int cm_load_schedule(const int count, int* schedule, FILE *fp) |
352 |
353 |
char buf[512]; |
354 |
char *cp; |
355 |
char *comma; |
356 |
double val; |
357 |
int i = 0; |
358 |
359 |
while (fgetline(buf, sizeof(buf), fp) != NULL) { |
360 |
if (buf[0] == '#') continue; // Comment line |
361 |
comma = NULL; |
362 |
for (cp = buf; *cp; cp++) { |
363 |
/* If there are multiple commas, assume the value is after the last comma */ |
364 |
if (*cp == ',') { |
365 |
comma = cp; /* Record position of last comma */ |
366 |
367 |
368 |
if (comma) |
369 |
val = atof(comma + 1); |
370 |
else |
371 |
val = atof(buf); |
372 |
373 |
if (i < count) { |
374 |
/* Add the value to the schedule */ |
375 |
schedule[i++] = (val > 0); |
376 |
377 |
else { |
378 |
fprintf(stderr, |
379 |
"%s: too many schedule entries\n", |
380 |
progname); |
381 |
return(1); |
382 |
383 |
384 |
fclose(fp); |
385 |
386 |
if (i < count) { |
387 |
fprintf(stderr, |
388 |
"%s: too few schedule entries\n", |
389 |
progname); |
390 |
return(-1); |
391 |
392 |
393 |
return 0; |
394 |
395 |
396 |
FVECT* cm_load_views(const int nrows, const int dtype, FILE *fp) |
397 |
398 |
int i; |
399 |
double d; |
400 |
FVECT orig; |
401 |
402 |
FVECT *views = (FVECT*)malloc(nrows * sizeof(FVECT)); |
403 |
if (!views) { |
404 |
fprintf(stderr, |
405 |
"%s: out of memory in cm_load_views()\n", |
406 |
progname); |
407 |
return NULL; |
408 |
409 |
410 |
for (i = 0; i < nrows; i++) { |
411 |
if (getvec(orig, dtype, fp) | getvec(views[i], dtype, fp)) { |
412 |
fprintf(stderr, |
413 |
"%s: unexpected end of input, missing %d entries\n", |
414 |
progname, i); |
415 |
return NULL; |
416 |
417 |
418 |
d = normalize(views[i]); |
419 |
if (d == 0.0) { /* zero ==> flush */ |
420 |
fprintf(stderr, |
421 |
"%s: zero length direction detected\n", |
422 |
progname); |
423 |
return NULL; |
424 |
425 |
426 |
427 |
return views; |
428 |
429 |
430 |
int cm_write_glare(const float *mp, const int nrows, const int ncols, const int dtype, FILE *fp) |
431 |
432 |
static const char tabEOL[2] = { '\t', '\n' }; |
433 |
int r, c; |
434 |
double dc[1]; |
435 |
436 |
switch (dtype) { |
437 |
case DTascii: |
438 |
for (r = 0; r < nrows; r++) |
439 |
for (c = 0; c < ncols; c++, mp++) |
440 |
fprintf(fp, "%.6e%c", |
441 |
mp[0], |
442 |
tabEOL[c >= ncols - 1]); |
443 |
break; |
444 |
case DTfloat: |
445 |
r = ncols*nrows; |
446 |
while (r > 0) { |
447 |
c = putbinary(mp, sizeof(float), r, fp); |
448 |
if (c <= 0) |
449 |
return(0); |
450 |
mp += c; |
451 |
r -= c; |
452 |
453 |
break; |
454 |
case DTdouble: |
455 |
r = ncols*nrows; |
456 |
while (r--) { |
457 |
dc[0] = mp[0]; |
458 |
if (putbinary(dc, sizeof(double), 1, fp) != 1) |
459 |
return(0); |
460 |
mp++; |
461 |
462 |
break; |
463 |
default: |
464 |
fputs("Unsupported data type in cm_write_glare()!\n", stderr); |
465 |
return(0); |
466 |
467 |
return(fflush(fp) == 0); |
468 |
