| 1 |
| 2 |
* cmglare.c - routines for calculating glare autonomy.
| 3 |
| 4 |
* N. Jones
| 5 |
| 6 |
| 7 |
| 8 |
* Copyright (c) 2017-2019 Nathaniel Jones
| 9 |
| 10 |
* Permission is hereby granted, free of charge, to any person obtaining a copy
| 11 |
* of this software and associated documentation files (the "Software"), to deal
| 12 |
* in the Software without restriction, including without limitation the rights
| 13 |
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
| 14 |
* copies of the Software, and to permit persons to whom the Software is
| 15 |
* furnished to do so, subject to the following conditions:
| 16 |
| 17 |
* The above copyright notice and this permission notice shall be included in all
| 18 |
* copies or substantial portions of the Software.
| 19 |
| 20 |
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
| 21 |
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
| 22 |
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
| 23 |
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
| 24 |
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
| 25 |
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
| 26 |
* SOFTWARE.
| 27 |
| 28 |
| 29 |
#include "rtmath.h"
| 30 |
#include "cmglare.h"
| 31 |
| 32 |
#define LUMINOUS_EFFICACY 179 /* lumens per Watt */
| 33 |
#define LUMINANCE_THRESHOLD 100 /* minimum threshold that will be interpreted as luminance rather than ratio between Ev and glare source */
| 34 |
| 35 |
#define ANGLE(u,v) acos(DOT((u),(v))) // TODO need to normalize?
| 36 |
| 37 |
typedef struct reinhart_sky {
| 38 |
//int mf; /* Linear divisions per Tregenza patch. */
| 39 |
int rings; /* Number of rings of sky patches. */
| 40 |
//int patches; /* Number of sky patches. */
| 41 |
double ringElevationAngle; /* Angle in radians between rings. */
| 42 |
int *patchesPerRow; /* Sky patches per row. */
| 43 |
int *firstPatchIndex; /* Index of first sky patch in each row. */
| 44 |
double *solidAngle; /* Solid angle of each patch in each row. */
| 45 |
} ReinhartSky;
| 46 |
| 47 |
static const int tnaz[] = { 30, 30, 24, 24, 18, 12, 6 }; /* Number of patches per row */
| 48 |
| 49 |
extern char* progname;
| 50 |
| 51 |
static ReinhartSky* make_sky(const CMATRIX *smx)
| 52 |
| 53 |
int mf, count, i, j;
| 54 |
double remaining = PI / 2;
| 55 |
| 56 |
/* Check sky partitionss */
| 57 |
switch (smx->nrows) { // nrows is Reinhart sky subdivisoins plus one for miss
| 58 |
case 2: mf = 0; break;
| 59 |
case 146: mf = 1; break;
| 60 |
case 578: mf = 2; break;
| 61 |
case 1298: mf = 3; break;
| 62 |
case 2306: mf = 4; break;
| 63 |
case 3602: mf = 5; break;
| 64 |
case 5186: mf = 6; break;
| 65 |
case 7058: mf = 7; break;
| 66 |
case 9218: mf = 8; break;
| 67 |
case 11666: mf = 9; break;
| 68 |
case 14402: mf = 10; break;
| 69 |
case 17426: mf = 11; break;
| 70 |
case 20738: mf = 12; break;
| 71 |
default:
| 72 |
fprintf(stderr,
| 73 |
"%s: unknown number of sky patches %d\n",
| 74 |
progname, smx->nrows);
| 75 |
return NULL;
| 76 |
| 77 |
| 78 |
/* Allocate sky */
| 79 |
ReinhartSky *sky = (ReinhartSky*)malloc(sizeof(ReinhartSky));
| 80 |
if (!sky) goto memerr;
| 81 |
| 82 |
/* Calculate patches per row */
| 83 |
sky->rings = 7 * mf + 1;
| 84 |
sky->patchesPerRow = (int*)malloc(sky->rings * sizeof(int));
| 85 |
sky->firstPatchIndex = (int*)malloc(sky->rings * sizeof(int));
| 86 |
if (!sky->patchesPerRow || !sky->firstPatchIndex) goto memerr;
| 87 |
count = 1; // The below horizon patch
| 88 |
for (i = 0; i < 7; i++)
| 89 |
for (j = 0; j < mf; j++) {
| 90 |
sky->firstPatchIndex[i * mf + j] = count;
| 91 |
count += sky->patchesPerRow[i * mf + j] = tnaz[i] * mf;
| 92 |
| 93 |
sky->firstPatchIndex[7 * mf] = count;
| 94 |
sky->patchesPerRow[7 * mf] = 1;
| 95 |
//sky->patches = count + 1;
| 96 |
| 97 |
/* Calculate solid angle of patches in each row */
| 98 |
sky->solidAngle = (double*)malloc(sky->rings * sizeof(double));
| 99 |
if (!sky->solidAngle) goto memerr;
| 100 |
sky->ringElevationAngle = PI / (2 * sky->rings - 1);
| 101 |
sky->solidAngle[0] = 2 * PI;
| 102 |
for (i = 1; i < sky->rings; i++) {
| 103 |
remaining -= sky->ringElevationAngle;
| 104 |
sky->solidAngle[i] = 2 * PI * (1 - cos(remaining)); // solid angle of cap
| 105 |
sky->solidAngle[i - 1] -= sky->solidAngle[i];
| 106 |
sky->solidAngle[i - 1] /= sky->patchesPerRow[i - 1];
| 107 |
| 108 |
| 109 |
return sky;
| 110 |
| 111 |
memerr:
| 112 |
fprintf(stderr,
| 113 |
"%s: out of memory\n",
| 114 |
progname);
| 115 |
return NULL;
| 116 |
| 117 |
| 118 |
static void free_sky(ReinhartSky *sky)
| 119 |
| 120 |
if (sky) {
| 121 |
free(sky->patchesPerRow);
| 122 |
free(sky->firstPatchIndex);
| 123 |
free(sky->solidAngle);
| 124 |
free(sky);
| 125 |
| 126 |
| 127 |
| 128 |
static void get_patch_direction(const ReinhartSky *sky, const int patch, FVECT target)
| 129 |
| 130 |
//if (patch >= sky->patches || patch < 0) throw new RuntimeException("Illegal patch " + patch);
| 131 |
if (!patch) {
| 132 |
target[0] = target[1] = 0;
| 133 |
target[2] = -1;
| 134 |
return; // Ignore below horizon?
| 135 |
| 136 |
int row = sky->rings - 1;
| 137 |
while (patch < sky->firstPatchIndex[row]) row--;
| 138 |
const double alt = PI / 2 - sky->ringElevationAngle * (row - (sky->rings - 1));
| 139 |
const double azi = 2 * PI * (patch - sky->firstPatchIndex[row]) / sky->patchesPerRow[row];
| 140 |
const double cos_alt = cos(alt);
| 141 |
target[0] = cos_alt * -sin(azi);
| 142 |
target[1] = cos_alt * -cos(azi);
| 143 |
target[2] = sin(alt);
| 144 |
| 145 |
| 146 |
static double get_patch_solid_angle(const ReinhartSky *sky, const int patch, const double cos_theta)
| 147 |
| 148 |
| 149 |
if (!patch) return 2 * (PI - 2 * acos(cos_theta)); // Solid angle overlap between visible hemisphere and ground hemisphere
| 150 |
| 151 |
| 152 |
return sky->solidAngle[row];
| 153 |
| 154 |
| 155 |
static double get_guth(const FVECT dir, const FVECT forward, const FVECT up)
| 156 |
| 157 |
double posindex;
| 158 |
FVECT hv, temp;
| 159 |
VCROSS(hv, forward, up);
| 160 |
normalize(hv);
| 161 |
VCROSS(temp, forward, hv);
| 162 |
double phi = ANGLE(dir, temp) - PI / 2;
| 163 |
| 164 |
/* Guth model, equation from IES lighting handbook */
| 165 |
if (phi >= 0) {
| 166 |
double sigma = ANGLE(dir, forward);
| 167 |
VSUM(hv, forward, dir, 1 / DOT(dir, forward));
| 168 |
normalize(hv);
| 169 |
double tau = ANGLE(hv, up);
| 170 |
tau *= 180.0 / PI;
| 171 |
sigma *= 180.0 / PI;
| 172 |
| 173 |
if (sigma <= 0)
| 174 |
sigma = -sigma;
| 175 |
| 176 |
posindex = exp((35.2 - 0.31889 * tau - 1.22 * exp(-2.0 * tau / 9.0)) / 1000.0 * sigma + (21.0 + 0.26667 * tau - 0.002963 * tau * tau) / 100000.0 * sigma * sigma);
| 177 |
| 178 |
/* below line of sight, using Iwata model */
| 179 |
else {
| 180 |
double teta = PI / 2 - ANGLE(dir, hv);
| 181 |
| 182 |
if (teta == 0.0)
| 183 |
teta = FTINY;
| 184 |
| 185 |
double fact = 0.8;
| 186 |
double d = 1 / tan(phi);
| 187 |
double s = tan(teta) / tan(phi);
| 188 |
double r = sqrt((1 + s * s) / (d * d));
| 189 |
if (r > 0.6)
| 190 |
fact = 1.2;
| 191 |
if (r > 3)
| 192 |
r = 3.0;
| 193 |
| 194 |
posindex = 1.0 + fact * r;
| 195 |
| 196 |
if (posindex > 16)
| 197 |
posindex = 16.0;
| 198 |
| 199 |
return posindex;
| 200 |
| 201 |
| 202 |
float* cm_glare(const CMATRIX *dcmx, const CMATRIX *evmx, const CMATRIX *smx, const int *occupied, const double dgp_limit, const double dgp_threshold, const FVECT *views, const FVECT dir, const FVECT up)
| 203 |
| 204 |
int p, t, c;
| 205 |
int hourly_output = dgp_limit < 0;
| 206 |
float *dgp_list;
| 207 |
ReinhartSky *sky;
| 208 |
FVECT vdir;
| 209 |
| 210 |
/* Check consistancy */
| 211 |
if ((dcmx->nrows != evmx->nrows) | (dcmx->ncols != smx->nrows) | (evmx->ncols != smx->ncols)) {
| 212 |
fprintf(stderr,
| 213 |
"%s: inconsistant matrix dimensions: dc(%d, %d) ev(%d, %d) s(%d, %d)\n",
| 214 |
progname, dcmx->nrows, dcmx->ncols, evmx->nrows, evmx->ncols, smx->nrows, smx->ncols);
| 215 |
return NULL;
| 216 |
| 217 |
| 218 |
/* Create output buffer */
| 219 |
dgp_list = (float*)malloc(evmx->nrows * (hourly_output ? evmx->ncols : 1) * sizeof(float));
| 220 |
if (!dgp_list) {
| 221 |
fprintf(stderr,
| 222 |
"%s: out of memory in cm_glare()\n",
| 223 |
progname);
| 224 |
return NULL;
| 225 |
| 226 |
| 227 |
/* Create sky */
| 228 |
sky = make_sky(smx);
| 229 |
if (!sky) return NULL;
| 230 |
| 231 |
/* Calculate glare limit */
| 232 |
double ev_max = -1;
| 233 |
if (!hourly_output) {
| 234 |
ev_max = (dgp_limit - 0.16) / 5.87e-5;
| 235 |
if (ev_max < 0) ev_max = 0;
| 236 |
| 237 |
| 238 |
/* For each position and direction */
| 239 |
if (!views) VCOPY(vdir, dir);
| 240 |
for (p = 0; p < evmx->nrows; p++) {
| 241 |
/* For each time step */
| 242 |
int occupied_hours = 0;
| 243 |
int glare_hours = 0;
| 244 |
if (views) VCOPY(vdir, views[p]);
| 245 |
for (t = 0; t < evmx->ncols; t++) {
| 246 |
if (!occupied[t]) {
| 247 |
/* Not occupied */
| 248 |
if (hourly_output) dgp_list[p * evmx->ncols + t] = 0.0f;
| 249 |
| 250 |
else {
| 251 |
/* Occupied */
| 252 |
double illum = LUMINOUS_EFFICACY * bright(cm_lval(evmx, p, t));
| 253 |
occupied_hours++;
| 254 |
| 255 |
if (illum <= FTINY) {
| 256 |
/* No light, so no glare */
| 257 |
| 258 |
| 259 |
else if ((illum >= ev_max) & (!hourly_output)) {
| 260 |
/* Guarangeed glare */
| 261 |
glare_hours++;
| 262 |
| 263 |
else {
| 264 |
/* Calculate enhanced simplified daylight glare probability */
| 265 |
double sum = 0.0;
| 266 |
FVECT patch_normal;
| 267 |
for (c = 0; c < smx->nrows; c++) {
| 268 |
const double dc = bright(cm_lval(dcmx, p, c));
| 269 |
if (dc > 0) {
| 270 |
get_patch_direction(sky, c, patch_normal);
| 271 |
if (!c) {
| 272 |
/* Direction toward the center of the visible ground */
| 273 |
VADD(patch_normal, patch_normal, vdir);
| 274 |
if (normalize(patch_normal) == 0) continue;
| 275 |
| 276 |
const double cos_theta = DOT(vdir, patch_normal);
| 277 |
if (cos_theta <= FTINY) continue;
| 278 |
const double s = LUMINOUS_EFFICACY * bright(cm_lval(smx, c, t));
| 279 |
const double omega = get_patch_solid_angle(sky, c, cos_theta);
| 280 |
const double patch_luminance = (dc * s) / (omega * cos_theta);
| 281 |
| 282 |
double min_patch_luminance = dgp_threshold;
| 283 |
if (dgp_threshold < LUMINANCE_THRESHOLD)
| 284 |
min_patch_luminance *= illum / PI; // TODO should use average luminance, not illuminance
| 285 |
if (patch_luminance < min_patch_luminance) continue;
| 286 |
const double P = get_guth(patch_normal, vdir, up);
| 287 |
sum += (patch_luminance * patch_luminance * omega) / (P * P);
| 288 |
| 289 |
| 290 |
| 291 |
//double dgp = 5.87e-5 * illum + 0.092 * log10(1 + dgp / pow(illum, 1.87)) + 0.159;
| 292 |
double eDGPs = 5.87e-5 * illum + 0.0918 * log10(1 + sum / pow(illum, 1.87)) + 0.16;
| 293 |
if (illum < 1000) /* low light correction */
| 294 |
eDGPs *= exp(0.024 * illum - 4) / (1 + exp(0.024 * illum - 4));
| 295 |
//eDGPs /= 1.1 - 0.5 * age / 100.0; /* age correction */
| 296 |
if (eDGPs > 1.0) eDGPs = 1.0;
| 297 |
| 298 |
if (hourly_output)
| 299 |
dgp_list[p * evmx->ncols + t] = (float)eDGPs;
| 300 |
else if (eDGPs >= dgp_limit)
| 301 |
glare_hours++;
| 302 |
| 303 |
| 304 |
| 305 |
| 306 |
/* Save glare autonomy */
| 307 |
dgp_list[p] = (float)(occupied_hours - glare_hours) / occupied_hours;
| 308 |
| 309 |
| 310 |
| 311 |
free_sky(sky);
| 312 |
| 313 |
return dgp_list;
| 314 |
| 315 |
| 316 |
static int getvec(FVECT vec, const int dtype, FILE *fp) /* get a vector from fp */
| 317 |
| 318 |
static float vf[3];
| 319 |
static double vd[3];
| 320 |
char buf[32];
| 321 |
int i;
| 322 |
| 323 |
switch (dtype) {
| 324 |
case DTascii:
| 325 |
for (i = 0; i < 3; i++) {
| 326 |
if (fgetword(buf, sizeof(buf), fp) == NULL ||
| 327 |
!isflt(buf))
| 328 |
return(-1);
| 329 |
vec[i] = atof(buf);
| 330 |
| 331 |
break;
| 332 |
case DTfloat:
| 333 |
if (getbinary(vf, sizeof(float), 3, fp) != 3)
| 334 |
return(-1);
| 335 |
VCOPY(vec, vf);
| 336 |
break;
| 337 |
case DTdouble:
| 338 |
if (getbinary(vd, sizeof(double), 3, fp) != 3)
| 339 |
return(-1);
| 340 |
VCOPY(vec, vd);
| 341 |
break;
| 342 |
default:
| 343 |
fprintf(stderr,
| 344 |
"%s: botched input format\n",
| 345 |
progname);
| 346 |
return(-1);
| 347 |
| 348 |
return(0);
| 349 |
| 350 |
| 351 |
int cm_load_schedule(const int count, int* schedule, FILE *fp)
| 352 |
| 353 |
char buf[512];
| 354 |
char *cp;
| 355 |
char *comma;
| 356 |
double val;
| 357 |
int i = 0;
| 358 |
| 359 |
while (fgetline(buf, sizeof(buf), fp) != NULL) {
| 360 |
if (buf[0] == '#') continue; // Comment line
| 361 |
comma = NULL;
| 362 |
for (cp = buf; *cp; cp++) {
| 363 |
/* If there are multiple commas, assume the value is after the last comma */
| 364 |
if (*cp == ',') {
| 365 |
comma = cp; /* Record position of last comma */
| 366 |
| 367 |
| 368 |
if (comma)
| 369 |
val = atof(comma + 1);
| 370 |
else
| 371 |
val = atof(buf);
| 372 |
| 373 |
if (i < count) {
| 374 |
/* Add the value to the schedule */
| 375 |
schedule[i++] = (val > 0);
| 376 |
| 377 |
else {
| 378 |
fprintf(stderr,
| 379 |
"%s: too many schedule entries\n",
| 380 |
progname);
| 381 |
return(1);
| 382 |
| 383 |
| 384 |
fclose(fp);
| 385 |
| 386 |
if (i < count) {
| 387 |
fprintf(stderr,
| 388 |
"%s: too few schedule entries\n",
| 389 |
progname);
| 390 |
return(-1);
| 391 |
| 392 |
| 393 |
return 0;
| 394 |
| 395 |
| 396 |
FVECT* cm_load_views(const int nrows, const int dtype, FILE *fp)
| 397 |
| 398 |
int i;
| 399 |
double d;
| 400 |
FVECT orig;
| 401 |
| 402 |
FVECT *views = (FVECT*)malloc(nrows * sizeof(FVECT));
| 403 |
if (!views) {
| 404 |
fprintf(stderr,
| 405 |
"%s: out of memory in cm_load_views()\n",
| 406 |
progname);
| 407 |
return NULL;
| 408 |
| 409 |
| 410 |
for (i = 0; i < nrows; i++) {
| 411 |
if (getvec(orig, dtype, fp) | getvec(views[i], dtype, fp)) {
| 412 |
fprintf(stderr,
| 413 |
"%s: unexpected end of input, missing %d entries\n",
| 414 |
progname, i);
| 415 |
return NULL;
| 416 |
| 417 |
| 418 |
d = normalize(views[i]);
| 419 |
if (d == 0.0) { /* zero ==> flush */
| 420 |
fprintf(stderr,
| 421 |
"%s: zero length direction detected\n",
| 422 |
progname);
| 423 |
return NULL;
| 424 |
| 425 |
| 426 |
| 427 |
return views;
| 428 |
| 429 |
| 430 |
int cm_write_glare(const float *mp, const int nrows, const int ncols, const int dtype, FILE *fp)
| 431 |
| 432 |
static const char tabEOL[2] = { '\t', '\n' };
| 433 |
int r, c;
| 434 |
double dc[1];
| 435 |
| 436 |
switch (dtype) {
| 437 |
case DTascii:
| 438 |
for (r = 0; r < nrows; r++)
| 439 |
for (c = 0; c < ncols; c++, mp++)
| 440 |
fprintf(fp, "%.6e%c",
| 441 |
mp[0],
| 442 |
tabEOL[c >= ncols - 1]);
| 443 |
break;
| 444 |
case DTfloat:
| 445 |
r = ncols*nrows;
| 446 |
while (r > 0) {
| 447 |
c = putbinary(mp, sizeof(float), r, fp);
| 448 |
if (c <= 0)
| 449 |
return(0);
| 450 |
mp += c;
| 451 |
r -= c;
| 452 |
| 453 |
break;
| 454 |
case DTdouble:
| 455 |
r = ncols*nrows;
| 456 |
while (r--) {
| 457 |
dc[0] = mp[0];
| 458 |
if (putbinary(dc, sizeof(double), 1, fp) != 1)
| 459 |
return(0);
| 460 |
mp++;
| 461 |
| 462 |
break;
| 463 |
default:
| 464 |
fputs("Unsupported data type in cm_write_glare()!\n", stderr);
| 465 |
return(0);
| 466 |
| 467 |
return(fflush(fp) == 0);
| 468 |
