root/Development/ray/src/util/cmglare.c
Revision: 2.1
Committed: Mon Sep 9 17:19:51 2019 UTC (6 years, 3 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, HEAD
# User Rev Content
1 greg 2.1 /*
2     * cmglare.c - routines for calculating glare autonomy.
3     *
4     * N. Jones
5     */
6
7     /*
8     * Copyright (c) 2017-2019 Nathaniel Jones
9     *
10     * Permission is hereby granted, free of charge, to any person obtaining a copy
11     * of this software and associated documentation files (the "Software"), to deal
12     * in the Software without restriction, including without limitation the rights
13     * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
14     * copies of the Software, and to permit persons to whom the Software is
15     * furnished to do so, subject to the following conditions:
16     *
17     * The above copyright notice and this permission notice shall be included in all
18     * copies or substantial portions of the Software.
19     *
20     * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
21     * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
22     * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
23     * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
24     * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
25     * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
26     * SOFTWARE.
27     */
28
29     #include "rtmath.h"
30     #include "cmglare.h"
31
32     #define LUMINOUS_EFFICACY 179 /* lumens per Watt */
33     #define LUMINANCE_THRESHOLD 100 /* minimum threshold that will be interpreted as luminance rather than ratio between Ev and glare source */
34
35     #define ANGLE(u,v) acos(DOT((u),(v))) // TODO need to normalize?
36
37     typedef struct reinhart_sky {
38     //int mf; /* Linear divisions per Tregenza patch. */
39     int rings; /* Number of rings of sky patches. */
40     //int patches; /* Number of sky patches. */
41     double ringElevationAngle; /* Angle in radians between rings. */
42     int *patchesPerRow; /* Sky patches per row. */
43     int *firstPatchIndex; /* Index of first sky patch in each row. */
44     double *solidAngle; /* Solid angle of each patch in each row. */
45     } ReinhartSky;
46
47     static const int tnaz[] = { 30, 30, 24, 24, 18, 12, 6 }; /* Number of patches per row */
48
49     extern char* progname;
50
51     static ReinhartSky* make_sky(const CMATRIX *smx)
52     {
53     int mf, count, i, j;
54     double remaining = PI / 2;
55
56     /* Check sky partitionss */
57     switch (smx->nrows) { // nrows is Reinhart sky subdivisoins plus one for miss
58     case 2: mf = 0; break;
59     case 146: mf = 1; break;
60     case 578: mf = 2; break;
61     case 1298: mf = 3; break;
62     case 2306: mf = 4; break;
63     case 3602: mf = 5; break;
64     case 5186: mf = 6; break;
65     case 7058: mf = 7; break;
66     case 9218: mf = 8; break;
67     case 11666: mf = 9; break;
68     case 14402: mf = 10; break;
69     case 17426: mf = 11; break;
70     case 20738: mf = 12; break;
71     default:
72     fprintf(stderr,
73     "%s: unknown number of sky patches %d\n",
74     progname, smx->nrows);
75     return NULL;
76     }
77
78     /* Allocate sky */
79     ReinhartSky *sky = (ReinhartSky*)malloc(sizeof(ReinhartSky));
80     if (!sky) goto memerr;
81
82     /* Calculate patches per row */
83     sky->rings = 7 * mf + 1;
84     sky->patchesPerRow = (int*)malloc(sky->rings * sizeof(int));
85     sky->firstPatchIndex = (int*)malloc(sky->rings * sizeof(int));
86     if (!sky->patchesPerRow || !sky->firstPatchIndex) goto memerr;
87     count = 1; // The below horizon patch
88     for (i = 0; i < 7; i++)
89     for (j = 0; j < mf; j++) {
90     sky->firstPatchIndex[i * mf + j] = count;
91     count += sky->patchesPerRow[i * mf + j] = tnaz[i] * mf;
92     }
93     sky->firstPatchIndex[7 * mf] = count;
94     sky->patchesPerRow[7 * mf] = 1;
95     //sky->patches = count + 1;
96
97     /* Calculate solid angle of patches in each row */
98     sky->solidAngle = (double*)malloc(sky->rings * sizeof(double));
99     if (!sky->solidAngle) goto memerr;
100     sky->ringElevationAngle = PI / (2 * sky->rings - 1);
101     sky->solidAngle[0] = 2 * PI;
102     for (i = 1; i < sky->rings; i++) {
103     remaining -= sky->ringElevationAngle;
104     sky->solidAngle[i] = 2 * PI * (1 - cos(remaining)); // solid angle of cap
105     sky->solidAngle[i - 1] -= sky->solidAngle[i];
106     sky->solidAngle[i - 1] /= sky->patchesPerRow[i - 1];
107     }
108
109     return sky;
110
111     memerr:
112     fprintf(stderr,
113     "%s: out of memory\n",
114     progname);
115     return NULL;
116     }
117
118     static void free_sky(ReinhartSky *sky)
119     {
120     if (sky) {
121     free(sky->patchesPerRow);
122     free(sky->firstPatchIndex);
123     free(sky->solidAngle);
124     free(sky);
125     }
126     }
127
128     static void get_patch_direction(const ReinhartSky *sky, const int patch, FVECT target)
129     {
130     //if (patch >= sky->patches || patch < 0) throw new RuntimeException("Illegal patch " + patch);
131     if (!patch) {
132     target[0] = target[1] = 0;
133     target[2] = -1;
134     return; // Ignore below horizon?
135     }
136     int row = sky->rings - 1;
137     while (patch < sky->firstPatchIndex[row]) row--;
138     const double alt = PI / 2 - sky->ringElevationAngle * (row - (sky->rings - 1));
139     const double azi = 2 * PI * (patch - sky->firstPatchIndex[row]) / sky->patchesPerRow[row];
140     const double cos_alt = cos(alt);
141     target[0] = cos_alt * -sin(azi);
142     target[1] = cos_alt * -cos(azi);
143     target[2] = sin(alt);
144     }
145
146     static double get_patch_solid_angle(const ReinhartSky *sky, const int patch, const double cos_theta)
147     {
148     //if (patch >= sky->patches || patch < 0) throw new RuntimeException("Illegal patch " + patch);
149     if (!patch) return 2 * (PI - 2 * acos(cos_theta)); // Solid angle overlap between visible hemisphere and ground hemisphere
150     int row = sky->rings - 1;
151     while (patch < sky->firstPatchIndex[row]) row--;
152     return sky->solidAngle[row];
153     }
154
155     static double get_guth(const FVECT dir, const FVECT forward, const FVECT up)
156     {
157     double posindex;
158     FVECT hv, temp;
159     VCROSS(hv, forward, up);
160     normalize(hv);
161     VCROSS(temp, forward, hv);
162     double phi = ANGLE(dir, temp) - PI / 2;
163
164     /* Guth model, equation from IES lighting handbook */
165     if (phi >= 0) {
166     double sigma = ANGLE(dir, forward);
167     VSUM(hv, forward, dir, 1 / DOT(dir, forward));
168     normalize(hv);
169     double tau = ANGLE(hv, up);
170     tau *= 180.0 / PI;
171     sigma *= 180.0 / PI;
172
173     if (sigma <= 0)
174     sigma = -sigma;
175
176     posindex = exp((35.2 - 0.31889 * tau - 1.22 * exp(-2.0 * tau / 9.0)) / 1000.0 * sigma + (21.0 + 0.26667 * tau - 0.002963 * tau * tau) / 100000.0 * sigma * sigma);
177     }
178     /* below line of sight, using Iwata model */
179     else {
180     double teta = PI / 2 - ANGLE(dir, hv);
181
182     if (teta == 0.0)
183     teta = FTINY;
184
185     double fact = 0.8;
186     double d = 1 / tan(phi);
187     double s = tan(teta) / tan(phi);
188     double r = sqrt((1 + s * s) / (d * d));
189     if (r > 0.6)
190     fact = 1.2;
191     if (r > 3)
192     r = 3.0;
193
194     posindex = 1.0 + fact * r;
195     }
196     if (posindex > 16)
197     posindex = 16.0;
198
199     return posindex;
200     }
201
202     float* cm_glare(const CMATRIX *dcmx, const CMATRIX *evmx, const CMATRIX *smx, const int *occupied, const double dgp_limit, const double dgp_threshold, const FVECT *views, const FVECT dir, const FVECT up)
203     {
204     int p, t, c;
205     int hourly_output = dgp_limit < 0;
206     float *dgp_list;
207     ReinhartSky *sky;
208     FVECT vdir;
209
210     /* Check consistancy */
211     if ((dcmx->nrows != evmx->nrows) | (dcmx->ncols != smx->nrows) | (evmx->ncols != smx->ncols)) {
212     fprintf(stderr,
213     "%s: inconsistant matrix dimensions: dc(%d, %d) ev(%d, %d) s(%d, %d)\n",
214     progname, dcmx->nrows, dcmx->ncols, evmx->nrows, evmx->ncols, smx->nrows, smx->ncols);
215     return NULL;
216     }
217
218     /* Create output buffer */
219     dgp_list = (float*)malloc(evmx->nrows * (hourly_output ? evmx->ncols : 1) * sizeof(float));
220     if (!dgp_list) {
221     fprintf(stderr,
222     "%s: out of memory in cm_glare()\n",
223     progname);
224     return NULL;
225     }
226
227     /* Create sky */
228     sky = make_sky(smx);
229     if (!sky) return NULL;
230
231     /* Calculate glare limit */
232     double ev_max = -1;
233     if (!hourly_output) {
234     ev_max = (dgp_limit - 0.16) / 5.87e-5;
235     if (ev_max < 0) ev_max = 0;
236     }
237
238     /* For each position and direction */
239     if (!views) VCOPY(vdir, dir);
240     for (p = 0; p < evmx->nrows; p++) {
241     /* For each time step */
242     int occupied_hours = 0;
243     int glare_hours = 0;
244     if (views) VCOPY(vdir, views[p]);
245     for (t = 0; t < evmx->ncols; t++) {
246     if (!occupied[t]) {
247     /* Not occupied */
248     if (hourly_output) dgp_list[p * evmx->ncols + t] = 0.0f;
249     }
250     else {
251     /* Occupied */
252     double illum = LUMINOUS_EFFICACY * bright(cm_lval(evmx, p, t));
253     occupied_hours++;
254
255     if (illum <= FTINY) {
256     /* No light, so no glare */
257     if (hourly_output) dgp_list[p * evmx->ncols + t] = 0.0f;
258     }
259     else if ((illum >= ev_max) & (!hourly_output)) {
260     /* Guarangeed glare */
261     glare_hours++;
262     }
263     else {
264     /* Calculate enhanced simplified daylight glare probability */
265     double sum = 0.0;
266     FVECT patch_normal;
267     for (c = 0; c < smx->nrows; c++) {
268     const double dc = bright(cm_lval(dcmx, p, c));
269     if (dc > 0) {
270     get_patch_direction(sky, c, patch_normal);
271     if (!c) {
272     /* Direction toward the center of the visible ground */
273     VADD(patch_normal, patch_normal, vdir);
274     if (normalize(patch_normal) == 0) continue;
275     }
276     const double cos_theta = DOT(vdir, patch_normal);
277     if (cos_theta <= FTINY) continue;
278     const double s = LUMINOUS_EFFICACY * bright(cm_lval(smx, c, t));
279     const double omega = get_patch_solid_angle(sky, c, cos_theta);
280     const double patch_luminance = (dc * s) / (omega * cos_theta);
281
282     double min_patch_luminance = dgp_threshold;
283     if (dgp_threshold < LUMINANCE_THRESHOLD)
284     min_patch_luminance *= illum / PI; // TODO should use average luminance, not illuminance
285     if (patch_luminance < min_patch_luminance) continue;
286     const double P = get_guth(patch_normal, vdir, up);
287     sum += (patch_luminance * patch_luminance * omega) / (P * P);
288     }
289     }
290
291     //double dgp = 5.87e-5 * illum + 0.092 * log10(1 + dgp / pow(illum, 1.87)) + 0.159;
292     double eDGPs = 5.87e-5 * illum + 0.0918 * log10(1 + sum / pow(illum, 1.87)) + 0.16;
293     if (illum < 1000) /* low light correction */
294     eDGPs *= exp(0.024 * illum - 4) / (1 + exp(0.024 * illum - 4));
295     //eDGPs /= 1.1 - 0.5 * age / 100.0; /* age correction */
296     if (eDGPs > 1.0) eDGPs = 1.0;
297
298     if (hourly_output)
299     dgp_list[p * evmx->ncols + t] = (float)eDGPs;
300     else if (eDGPs >= dgp_limit)
301     glare_hours++;
302     }
303     }
304     }
305     if (!hourly_output) {
306     /* Save glare autonomy */
307     dgp_list[p] = (float)(occupied_hours - glare_hours) / occupied_hours;
308     }
309     }
310
311     free_sky(sky);
312
313     return dgp_list;
314     }
315
316     static int getvec(FVECT vec, const int dtype, FILE *fp) /* get a vector from fp */
317     {
318     static float vf[3];
319     static double vd[3];
320     char buf[32];
321     int i;
322
323     switch (dtype) {
324     case DTascii:
325     for (i = 0; i < 3; i++) {
326     if (fgetword(buf, sizeof(buf), fp) == NULL ||
327     !isflt(buf))
328     return(-1);
329     vec[i] = atof(buf);
330     }
331     break;
332     case DTfloat:
333     if (getbinary(vf, sizeof(float), 3, fp) != 3)
334     return(-1);
335     VCOPY(vec, vf);
336     break;
337     case DTdouble:
338     if (getbinary(vd, sizeof(double), 3, fp) != 3)
339     return(-1);
340     VCOPY(vec, vd);
341     break;
342     default:
343     fprintf(stderr,
344     "%s: botched input format\n",
345     progname);
346     return(-1);
347     }
348     return(0);
349     }
350
351     int cm_load_schedule(const int count, int* schedule, FILE *fp)
352     {
353     char buf[512];
354     char *cp;
355     char *comma;
356     double val;
357     int i = 0;
358
359     while (fgetline(buf, sizeof(buf), fp) != NULL) {
360     if (buf[0] == '#') continue; // Comment line
361     comma = NULL;
362     for (cp = buf; *cp; cp++) {
363     /* If there are multiple commas, assume the value is after the last comma */
364     if (*cp == ',') {
365     comma = cp; /* Record position of last comma */
366     }
367     }
368     if (comma)
369     val = atof(comma + 1);
370     else
371     val = atof(buf);
372
373     if (i < count) {
374     /* Add the value to the schedule */
375     schedule[i++] = (val > 0);
376     }
377     else {
378     fprintf(stderr,
379     "%s: too many schedule entries\n",
380     progname);
381     return(1);
382     }
383     }
384     fclose(fp);
385
386     if (i < count) {
387     fprintf(stderr,
388     "%s: too few schedule entries\n",
389     progname);
390     return(-1);
391     }
392
393     return 0;
394     }
395
396     FVECT* cm_load_views(const int nrows, const int dtype, FILE *fp)
397     {
398     int i;
399     double d;
400     FVECT orig;
401
402     FVECT *views = (FVECT*)malloc(nrows * sizeof(FVECT));
403     if (!views) {
404     fprintf(stderr,
405     "%s: out of memory in cm_load_views()\n",
406     progname);
407     return NULL;
408     }
409
410     for (i = 0; i < nrows; i++) {
411     if (getvec(orig, dtype, fp) | getvec(views[i], dtype, fp)) {
412     fprintf(stderr,
413     "%s: unexpected end of input, missing %d entries\n",
414     progname, i);
415     return NULL;
416     }
417
418     d = normalize(views[i]);
419     if (d == 0.0) { /* zero ==> flush */
420     fprintf(stderr,
421     "%s: zero length direction detected\n",
422     progname);
423     return NULL;
424     }
425     }
426
427     return views;
428     }
429
430     int cm_write_glare(const float *mp, const int nrows, const int ncols, const int dtype, FILE *fp)
431     {
432     static const char tabEOL[2] = { '\t', '\n' };
433     int r, c;
434     double dc[1];
435
436     switch (dtype) {
437     case DTascii:
438     for (r = 0; r < nrows; r++)
439     for (c = 0; c < ncols; c++, mp++)
440     fprintf(fp, "%.6e%c",
441     mp[0],
442     tabEOL[c >= ncols - 1]);
443     break;
444     case DTfloat:
445     r = ncols*nrows;
446     while (r > 0) {
447     c = putbinary(mp, sizeof(float), r, fp);
448     if (c <= 0)
449     return(0);
450     mp += c;
451     r -= c;
452     }
453     break;
454     case DTdouble:
455     r = ncols*nrows;
456     while (r--) {
457     dc[0] = mp[0];
458     if (putbinary(dc, sizeof(double), 1, fp) != 1)
459     return(0);
460     mp++;
461     }
462     break;
463     default:
464     fputs("Unsupported data type in cm_write_glare()!\n", stderr);
465     return(0);
466     }
467     return(fflush(fp) == 0);
468     }
