root/radiance/ray/src/util/cmbsdf.c
Revision: 2.5
Committed: Tue Mar 22 03:56:17 2016 UTC (9 years, 3 months ago) by greg
CVS Tags: rad5R2, rad5R1
Made error messages more consistent when library file not found
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.5 static const char RCSid[] = "$Id: cmbsdf.c,v 2.4 2015/08/27 04:33:31 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Load and convert BSDF into color coefficient matrix representation.
6     *
7     * G. Ward
8     */
9
10     #include "standard.h"
11     #include "cmatrix.h"
12     #include "paths.h"
13     #include "bsdf.h"
14     #include "bsdf_m.h"
15
16     /* Convert a BSDF to our matrix representation */
17     static CMATRIX *
18 greg 2.3 cm_bsdf(const COLOR diffBSDF, const SDMat *bsdf)
19 greg 2.1 {
20     CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc);
21     int nbadohm = 0;
22     int nneg = 0;
23     int r, c;
24     /* loop over incident angles */
25     for (c = 0; c < cm->ncols; c++) {
26     const double dom = mBSDF_incohm(bsdf,c);
27     /* projected solid angle */
28     nbadohm += (dom <= 0);
29
30     for (r = 0; r < cm->nrows; r++) {
31     float f = mBSDF_value(bsdf,c,r);
32     COLORV *mp = cm_lval(cm,r,c);
33     /* check BSDF value */
34     if ((f <= 0) | (dom <= 0)) {
35     nneg += (f < -FTINY);
36 greg 2.3 setcolor(mp, .0f, .0f, .0f);
37     } else if (bsdf->chroma != NULL) {
38     C_COLOR cxy;
39 greg 2.4 c_decodeChroma(&cxy, mBSDF_chroma(bsdf,c,r));
40 greg 2.3 ccy2rgb(&cxy, f, mp);
41     } else
42     setcolor(mp, f, f, f);
43 greg 2.2 addcolor(mp, diffBSDF);
44 greg 2.1 scalecolor(mp, dom);
45     }
46     }
47     if (nneg | nbadohm) {
48     sprintf(errmsg,
49     "BTDF has %d negatives and %d bad incoming solid angles",
50     nneg, nbadohm);
51     error(WARNING, errmsg);
52     }
53     return(cm);
54     }
55
56     /* Convert between input and output indices for reciprocity */
57     static int
58     recip_out_from_in(const SDMat *bsdf, int in_recip)
59     {
60     FVECT v;
61
62     if (!mBSDF_incvec(v, bsdf, in_recip+.5))
63     return(in_recip); /* XXX should be error! */
64     v[2] = -v[2];
65     return(mBSDF_outndx(bsdf, v));
66     }
67
68     /* Convert between output and input indices for reciprocity */
69     static int
70     recip_in_from_out(const SDMat *bsdf, int out_recip)
71     {
72     FVECT v;
73
74     if (!mBSDF_outvec(v, bsdf, out_recip+.5))
75     return(out_recip); /* XXX should be error! */
76     v[2] = -v[2];
77     return(mBSDF_incndx(bsdf, v));
78     }
79
80     /* Convert a BSDF to our matrix representation, applying reciprocity */
81     static CMATRIX *
82 greg 2.3 cm_bsdf_recip(const COLOR diffBSDF, const SDMat *bsdf)
83 greg 2.1 {
84     CMATRIX *cm = cm_alloc(bsdf->ninc, bsdf->nout);
85     int nbadohm = 0;
86     int nneg = 0;
87     int r, c;
88     /* loop over incident angles */
89     for (c = 0; c < cm->ncols; c++) {
90     const int ro = recip_out_from_in(bsdf,c);
91     const double dom = mBSDF_outohm(bsdf,ro);
92     /* projected solid angle */
93     nbadohm += (dom <= 0);
94
95     for (r = 0; r < cm->nrows; r++) {
96     const int ri = recip_in_from_out(bsdf,r);
97     float f = mBSDF_value(bsdf,ri,ro);
98     COLORV *mp = cm_lval(cm,r,c);
99     /* check BSDF value */
100     if ((f <= 0) | (dom <= 0)) {
101     nneg += (f < -FTINY);
102 greg 2.3 setcolor(mp, .0f, .0f, .0f);
103     } else if (bsdf->chroma != NULL) {
104     C_COLOR cxy;
105 greg 2.4 c_decodeChroma(&cxy, mBSDF_chroma(bsdf,ri,ro));
106 greg 2.3 ccy2rgb(&cxy, f, mp);
107     } else
108     setcolor(mp, f, f, f);
109 greg 2.2 addcolor(mp, diffBSDF);
110 greg 2.1 scalecolor(mp, dom);
111     }
112     }
113     if (nneg | nbadohm) {
114     sprintf(errmsg,
115     "BTDF has %d negatives and %d bad incoming solid angles",
116     nneg, nbadohm);
117     error(WARNING, errmsg);
118     }
119     return(cm);
120     }
121
122 greg 2.2 /* Return a Lambertian (diffuse) matrix */
123     static CMATRIX *
124     cm_bsdf_Lamb(const COLOR diffBSDF)
125     {
126     CMATRIX *cm = cm_alloc(145, 145); /* this is a hack */
127     int r, c;
128
129     for (c = 0; c < cm->ncols; c++)
130     for (r = 0; r < cm->nrows; r++) {
131     COLORV *mp = cm_lval(cm,r,c);
132     copycolor(mp, diffBSDF);
133     }
134     return(cm);
135     }
136
137     /* Load and convert a matrix BTDF from the given XML file */
138 greg 2.1 CMATRIX *
139 greg 2.2 cm_loadBTDF(char *fname)
140 greg 2.1 {
141     CMATRIX *Tmat;
142     char *fpath;
143     int recip;
144     SDError ec;
145     SDData myBSDF;
146     SDSpectralDF *tdf;
147 greg 2.3 COLOR diffBSDF;
148 greg 2.1 /* find path to BSDF file */
149     fpath = getpath(fname, getrlibpath(), R_OK);
150     if (fpath == NULL) {
151     sprintf(errmsg, "cannot find BSDF file '%s'", fname);
152 greg 2.5 error(SYSTEM, errmsg);
153 greg 2.1 }
154     SDclearBSDF(&myBSDF, fname); /* load XML and check type */
155     ec = SDloadFile(&myBSDF, fpath);
156     if (ec)
157     error(USER, transSDError(ec));
158 greg 2.2 ccy2rgb(&myBSDF.tLamb.spec, myBSDF.tLamb.cieY/PI, diffBSDF);
159 greg 2.1 recip = (myBSDF.tb == NULL);
160     tdf = recip ? myBSDF.tf : myBSDF.tb;
161     if (tdf == NULL) { /* no non-Lambertian transmission? */
162     SDfreeBSDF(&myBSDF);
163 greg 2.2 return(cm_bsdf_Lamb(diffBSDF));
164 greg 2.1 }
165     if (tdf->ncomp != 1 || tdf->comp[0].func != &SDhandleMtx) {
166     sprintf(errmsg, "unsupported BSDF '%s'", fpath);
167     error(USER, errmsg);
168     }
169     /* convert BTDF to matrix */
170 greg 2.3 Tmat = recip ? cm_bsdf_recip(diffBSDF, (SDMat *)tdf->comp[0].dist)
171     : cm_bsdf(diffBSDF, (SDMat *)tdf->comp[0].dist);
172 greg 2.1 /* free BSDF and return */
173     SDfreeBSDF(&myBSDF);
174     return(Tmat);
175     }
