root/radiance/ray/src/util/cmbsdf.c
Sat Mar 27 17:50:18 2021 UTC (3 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.9: +5 -2 lines
Tue Jan 19 23:32:00 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.8: +43 -7 lines
Tue Mar 17 23:24:05 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.7: +12 -4 lines
Corrected matrix for diffuse-only transmission, which needed proj. solid angle
Wed Sep 11 00:24:03 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.6: +5 -5 lines
Reversed order of matrix look-up macros to be more consistent
Wed Jul 31 22:00:08 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.5: +4 -10 lines
Switched off $RAYPATH search for XML loading in dctimestep, rmtxop
Tue Mar 22 03:56:17 2016 UTC (8 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Made error messages more consistent when library file not found
Thu Aug 27 04:33:31 2015 UTC (8 years, 8 months ago) by greg
Changes since 2.3: +3 -5 lines
Added mBSDF_chroma() macro
Fri Apr 17 01:47:03 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.2: +22 -15 lines
Add color BTDF support
Mon Jan 20 22:18:29 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.1: +27 -16 lines
Diff to previous 2.1
Fixed improper handling of diffuse transmission matrix
Mon Jan 20 21:29:04 2014 UTC (10 years, 3 months ago) by greg
Diff to selected 2.2
