| 1 |
/* RCSid $Id: cmatrix.h,v 2.5 2014/05/30 00:00:54 greg Exp $ */
| 2 |
| 3 |
* Color matrix routine declarations.
| 4 |
| 5 |
* G. Ward
| 6 |
| 7 |
| 8 |
#ifndef _RAD_CMATRIX_H_
| 9 |
#define _RAD_CMATRIX_H_
| 10 |
| 11 |
#include "color.h"
| 12 |
| 13 |
#ifdef __cplusplus
| 14 |
extern "C" {
| 15 |
#endif
| 16 |
| 17 |
/* Data types for file loading */
| 18 |
enum {DTfromHeader=0, DTascii, DTrgbe, DTxyze, DTfloat, DTdouble, DTend};
| 19 |
| 20 |
extern const char *cm_fmt_id[];
| 21 |
extern const int cm_elem_size[];
| 22 |
| 23 |
/* A color coefficient matrix -- vectors have ncols==1 */
| 24 |
typedef struct {
| 25 |
int nrows, ncols;
| 26 |
COLORV cmem[3]; /* extends struct */
| 27 |
} CMATRIX;
| 28 |
| 29 |
#define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf")
| 30 |
| 31 |
#define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c)))
| 32 |
| 33 |
#define cv_lval(cm,i) ((cm)->cmem + 3*(i))
| 34 |
| 35 |
/* Allocate a color coefficient matrix */
| 36 |
extern CMATRIX *cm_alloc(int nrows, int ncols);
| 37 |
| 38 |
/* Resize color coefficient matrix */
| 39 |
extern CMATRIX *cm_resize(CMATRIX *cm, int nrows);
| 40 |
| 41 |
#define cm_free(cm) free(cm)
| 42 |
| 43 |
/* Load header to obtain/check data type and matrix dimensions */
| 44 |
extern char *cm_getheader(int *dt, int *nr, int *nc, FILE *fp);
| 45 |
| 46 |
/* Allocate and load a matrix from the given file (or stdin if NULL) */
| 47 |
extern CMATRIX *cm_load(const char *fname, int nrows, int ncols, int dtype);
| 48 |
| 49 |
/* Extract a column vector from a matrix */
| 50 |
extern CMATRIX *cm_column(const CMATRIX *cm, int c);
| 51 |
| 52 |
/* Scale a matrix by a single value */
| 53 |
extern CMATRIX *cm_scale(const CMATRIX *cm1, const COLOR sca);
| 54 |
| 55 |
/* Multiply two matrices (or a matrix and a vector) and allocate the result */
| 56 |
extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2);
| 57 |
| 58 |
/* write out matrix to file (precede by resolution string if picture) */
| 59 |
extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp);
| 60 |
| 61 |
/* Load and convert a matrix BTDF from the given XML file */
| 62 |
extern CMATRIX *cm_loadBTDF(char *fname);
| 63 |
| 64 |
#ifdef __cplusplus
| 65 |
| 66 |
#endif
| 67 |
#endif /* _RAD_CMATRIX_H_ */
