--- ray/src/util/cmatrix.h 2014/05/30 00:00:54 2.5 +++ ray/src/util/cmatrix.h 2015/05/04 20:53:21 2.7 @@ -1,4 +1,4 @@ -/* RCSid $Id: cmatrix.h,v 2.5 2014/05/30 00:00:54 greg Exp $ */ +/* RCSid $Id: cmatrix.h,v 2.7 2015/05/04 20:53:21 greg Exp $ */ /* * Color matrix routine declarations. * @@ -15,7 +15,7 @@ extern "C" { #endif /* Data types for file loading */ -enum {DTfromHeader=0, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze, DTend}; +enum {DTfromHeader=0, DTascii, DTrgbe, DTxyze, DTfloat, DTdouble, DTend}; extern const char *cm_fmt_id[]; extern const int cm_elem_size[]; @@ -43,8 +43,8 @@ extern CMATRIX *cm_resize(CMATRIX *cm, int nrows); /* Load header to obtain/check data type and matrix dimensions */ extern char *cm_getheader(int *dt, int *nr, int *nc, FILE *fp); -/* Allocate and load a matrix from the given file (or stdin if NULL) */ -extern CMATRIX *cm_load(const char *fname, int nrows, int ncols, int dtype); +/* Allocate and load a matrix from the given input (or stdin if NULL) */ +extern CMATRIX *cm_load(const char *inspec, int nrows, int ncols, int dtype); /* Extract a column vector from a matrix */ extern CMATRIX *cm_column(const CMATRIX *cm, int c);
