--- ray/src/util/cmatrix.h 2014/01/20 21:30:34 2.2 +++ ray/src/util/cmatrix.h 2014/02/08 01:28:06 2.4 @@ -1,4 +1,4 @@ -/* RCSid $Id: cmatrix.h,v 2.2 2014/01/20 21:30:34 greg Exp $ */ +/* RCSid $Id: cmatrix.h,v 2.4 2014/02/08 01:28:06 greg Exp $ */ /* * Color matrix routine declarations. * @@ -15,8 +15,11 @@ extern "C" { #endif /* Data types for file loading */ -enum {DTfromHeader, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze}; +enum {DTfromHeader, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze, DTend}; +extern const char *cm_fmt_id[]; +extern const int cm_elem_size[]; + /* A color coefficient matrix -- vectors have ncols==1 */ typedef struct { int nrows, ncols; @@ -52,11 +55,11 @@ extern CMATRIX *cm_scale(const CMATRIX *cm1, const COL /* Multiply two matrices (or a matrix and a vector) and allocate the result */ extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2); -/* print out matrix as ASCII text -- no header */ -extern void cm_print(const CMATRIX *cm, FILE *fp); +/* write out matrix to file (precede by resolution string if picture) */ +extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp); -/* Load and convert a matrix BSDF from the given XML file */ -extern CMATRIX *cm_loadBSDF(char *fname, COLOR cLamb); +/* Load and convert a matrix BTDF from the given XML file */ +extern CMATRIX *cm_loadBTDF(char *fname); #ifdef __cplusplus }
