--- ray/src/util/cmatrix.h 2014/05/30 00:00:54 2.5 +++ ray/src/util/cmatrix.h 2025/04/04 18:06:48 2.15 @@ -1,4 +1,4 @@ -/* RCSid $Id: cmatrix.h,v 2.5 2014/05/30 00:00:54 greg Exp $ */ +/* RCSid $Id: cmatrix.h,v 2.15 2025/04/04 18:06:48 greg Exp $ */ /* * Color matrix routine declarations. * @@ -8,15 +8,24 @@ #ifndef _RAD_CMATRIX_H_ #define _RAD_CMATRIX_H_ +#include #include "color.h" #ifdef __cplusplus extern "C" { #endif -/* Data types for file loading */ -enum {DTfromHeader=0, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze, DTend}; +/* Data types for file loading (used to be an enum) */ +#define DTfromHeader 0 +#define DTrgbe 1 +#define DTxyze 2 +#define DTspec 3 +#define DTfloat 4 +#define DTascii 5 +#define DTdouble 6 +#define DTend 7 +extern const char stdin_name[]; extern const char *cm_fmt_id[]; extern const int cm_elem_size[]; @@ -28,7 +37,7 @@ typedef struct { #define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf") -#define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c))) +#define cm_lval(cm,r,c) ((cm)->cmem + 3*((size_t)(r)*(cm)->ncols + (c))) #define cv_lval(cm,i) ((cm)->cmem + 3*(i)) @@ -41,17 +50,15 @@ extern CMATRIX *cm_resize(CMATRIX *cm, int nrows); #define cm_free(cm) free(cm) /* Load header to obtain/check data type and matrix dimensions */ -extern char *cm_getheader(int *dt, int *nr, int *nc, FILE *fp); +extern char *cm_getheader(int *dt, int *nr, int *nc, + int *swp, COLOR scale, FILE *fp); -/* Allocate and load a matrix from the given file (or stdin if NULL) */ -extern CMATRIX *cm_load(const char *fname, int nrows, int ncols, int dtype); +/* Allocate and load a matrix from the given input (or stdin if NULL) */ +extern CMATRIX *cm_load(const char *inspec, int nrows, int ncols, int dtype); /* Extract a column vector from a matrix */ extern CMATRIX *cm_column(const CMATRIX *cm, int c); -/* Scale a matrix by a single value */ -extern CMATRIX *cm_scale(const CMATRIX *cm1, const COLOR sca); - /* Multiply two matrices (or a matrix and a vector) and allocate the result */ extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2); @@ -59,7 +66,10 @@ extern CMATRIX *cm_multiply(const CMATRIX *cm1, const extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp); /* Load and convert a matrix BTDF from the given XML file */ -extern CMATRIX *cm_loadBTDF(char *fname); +extern CMATRIX *cm_loadBTDF(const char *fname); + +/* Load and convert a matrix BRDF from the given XML file */ +extern CMATRIX *cm_loadBRDF(const char *fname, int backside); #ifdef __cplusplus }
