--- ray/src/util/cmatrix.h 2019/08/14 18:20:02 2.10 +++ ray/src/util/cmatrix.h 2020/03/25 01:51:09 2.12 @@ -1,4 +1,4 @@ -/* RCSid $Id: cmatrix.h,v 2.10 2019/08/14 18:20:02 greg Exp $ */ +/* RCSid $Id: cmatrix.h,v 2.12 2020/03/25 01:51:09 greg Exp $ */ /* * Color matrix routine declarations. * @@ -16,7 +16,7 @@ extern "C" { #endif /* Data types for file loading */ -enum {DTfromHeader=0, DTascii, DTrgbe, DTxyze, DTfloat, DTdouble, DTend}; +enum {DTfromHeader=0, DTrgbe, DTxyze, DTfloat, DTascii, DTdouble, DTend}; extern const char *cm_fmt_id[]; extern const int cm_elem_size[]; @@ -42,7 +42,8 @@ extern CMATRIX *cm_resize(CMATRIX *cm, int nrows); #define cm_free(cm) free(cm) /* Load header to obtain/check data type and matrix dimensions */ -extern char *cm_getheader(int *dt, int *nr, int *nc, int *swp, FILE *fp); +extern char *cm_getheader(int *dt, int *nr, int *nc, + int *swp, COLOR scale, FILE *fp); /* Allocate and load a matrix from the given input (or stdin if NULL) */ extern CMATRIX *cm_load(const char *inspec, int nrows, int ncols, int dtype);
