1 |
/* RCSid $Id: cmatrix.h,v 2.6 2014/08/02 17:10:43 greg Exp $ */ |
2 |
3 |
* Color matrix routine declarations. |
4 |
5 |
* G. Ward |
6 |
7 |
8 |
#ifndef _RAD_CMATRIX_H_ |
9 |
#define _RAD_CMATRIX_H_ |
10 |
11 |
#include "color.h" |
12 |
13 |
#ifdef __cplusplus |
14 |
extern "C" { |
15 |
#endif |
16 |
17 |
/* Data types for file loading */ |
18 |
enum {DTfromHeader=0, DTascii, DTrgbe, DTxyze, DTfloat, DTdouble, DTend}; |
19 |
20 |
extern const char *cm_fmt_id[]; |
21 |
extern const int cm_elem_size[]; |
22 |
23 |
/* A color coefficient matrix -- vectors have ncols==1 */ |
24 |
typedef struct { |
25 |
int nrows, ncols; |
26 |
COLORV cmem[3]; /* extends struct */ |
27 |
} CMATRIX; |
28 |
29 |
#define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf") |
30 |
31 |
#define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c))) |
32 |
33 |
#define cv_lval(cm,i) ((cm)->cmem + 3*(i)) |
34 |
35 |
/* Allocate a color coefficient matrix */ |
36 |
extern CMATRIX *cm_alloc(int nrows, int ncols); |
37 |
38 |
/* Resize color coefficient matrix */ |
39 |
extern CMATRIX *cm_resize(CMATRIX *cm, int nrows); |
40 |
41 |
#define cm_free(cm) free(cm) |
42 |
43 |
/* Load header to obtain/check data type and matrix dimensions */ |
44 |
extern char *cm_getheader(int *dt, int *nr, int *nc, FILE *fp); |
45 |
46 |
/* Allocate and load a matrix from the given input (or stdin if NULL) */ |
47 |
extern CMATRIX *cm_load(const char *inspec, int nrows, int ncols, int dtype); |
48 |
49 |
/* Extract a column vector from a matrix */ |
50 |
extern CMATRIX *cm_column(const CMATRIX *cm, int c); |
51 |
52 |
/* Scale a matrix by a single value */ |
53 |
extern CMATRIX *cm_scale(const CMATRIX *cm1, const COLOR sca); |
54 |
55 |
/* Multiply two matrices (or a matrix and a vector) and allocate the result */ |
56 |
extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2); |
57 |
58 |
/* write out matrix to file (precede by resolution string if picture) */ |
59 |
extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp); |
60 |
61 |
/* Load and convert a matrix BTDF from the given XML file */ |
62 |
extern CMATRIX *cm_loadBTDF(char *fname); |
63 |
64 |
65 |
66 |
#endif |
67 |
#endif /* _RAD_CMATRIX_H_ */ |
