root/radiance/ray/src/util/cmatrix.h
Revision: 2.5
Committed: Fri May 30 00:00:54 2014 UTC (10 years, 11 months ago) by greg
CVS Tags: rad4R2
Changes since 2.4: +12 -12 lines
1 /* RCSid $Id: cmatrix.h,v 2.4 2014/02/08 01:28:06 greg Exp $ */
2 /*
3 * Color matrix routine declarations.
4 *
5 * G. Ward
6 */
7
8 #ifndef _RAD_CMATRIX_H_
9 #define _RAD_CMATRIX_H_
10
11 #include "color.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 /* Data types for file loading */
18 enum {DTfromHeader=0, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze, DTend};
19
20 extern const char *cm_fmt_id[];
21 extern const int cm_elem_size[];
22
23 /* A color coefficient matrix -- vectors have ncols==1 */
24 typedef struct {
25 int nrows, ncols;
26 COLORV cmem[3]; /* extends struct */
27 } CMATRIX;
28
29 #define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf")
30
31 #define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c)))
32
33 #define cv_lval(cm,i) ((cm)->cmem + 3*(i))
34
35 /* Allocate a color coefficient matrix */
36 extern CMATRIX *cm_alloc(int nrows, int ncols);
37
38 /* Resize color coefficient matrix */
39 extern CMATRIX *cm_resize(CMATRIX *cm, int nrows);
40
41 #define cm_free(cm) free(cm)
42
43 /* Load header to obtain/check data type and matrix dimensions */
44 extern char *cm_getheader(int *dt, int *nr, int *nc, FILE *fp);
45
46 /* Allocate and load a matrix from the given file (or stdin if NULL) */
47 extern CMATRIX *cm_load(const char *fname, int nrows, int ncols, int dtype);
48
49 /* Extract a column vector from a matrix */
50 extern CMATRIX *cm_column(const CMATRIX *cm, int c);
51
52 /* Scale a matrix by a single value */
53 extern CMATRIX *cm_scale(const CMATRIX *cm1, const COLOR sca);
54
55 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
56 extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2);
57
58 /* write out matrix to file (precede by resolution string if picture) */
59 extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp);
60
61 /* Load and convert a matrix BTDF from the given XML file */
62 extern CMATRIX *cm_loadBTDF(char *fname);
63
64 #ifdef __cplusplus
65 }
66 #endif
67 #endif /* _RAD_CMATRIX_H_ */
