root/radiance/ray/src/util/cmatrix.h
Revision: 2.15
Committed: Fri Apr 4 18:06:48 2025 UTC (5 weeks ago) by greg
Changes since 2.14: +10 -3 lines
1 /* RCSid $Id: cmatrix.h,v 2.14 2023/11/21 01:30:20 greg Exp $ */
2 /*
3 * Color matrix routine declarations.
4 *
5 * G. Ward
6 */
7
8 #ifndef _RAD_CMATRIX_H_
9 #define _RAD_CMATRIX_H_
10
11 #include <sys/types.h>
12 #include "color.h"
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 /* Data types for file loading (used to be an enum) */
19 #define DTfromHeader 0
20 #define DTrgbe 1
21 #define DTxyze 2
22 #define DTspec 3
23 #define DTfloat 4
24 #define DTascii 5
25 #define DTdouble 6
26 #define DTend 7
27
28 extern const char stdin_name[];
29 extern const char *cm_fmt_id[];
30 extern const int cm_elem_size[];
31
32 /* A color coefficient matrix -- vectors have ncols==1 */
33 typedef struct {
34 int nrows, ncols;
35 COLORV cmem[3]; /* extends struct */
36 } CMATRIX;
37
38 #define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf")
39
40 #define cm_lval(cm,r,c) ((cm)->cmem + 3*((size_t)(r)*(cm)->ncols + (c)))
41
42 #define cv_lval(cm,i) ((cm)->cmem + 3*(i))
43
44 /* Allocate a color coefficient matrix */
45 extern CMATRIX *cm_alloc(int nrows, int ncols);
46
47 /* Resize color coefficient matrix */
48 extern CMATRIX *cm_resize(CMATRIX *cm, int nrows);
49
50 #define cm_free(cm) free(cm)
51
52 /* Load header to obtain/check data type and matrix dimensions */
53 extern char *cm_getheader(int *dt, int *nr, int *nc,
54 int *swp, COLOR scale, FILE *fp);
55
56 /* Allocate and load a matrix from the given input (or stdin if NULL) */
57 extern CMATRIX *cm_load(const char *inspec, int nrows, int ncols, int dtype);
58
59 /* Extract a column vector from a matrix */
60 extern CMATRIX *cm_column(const CMATRIX *cm, int c);
61
62 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
63 extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2);
64
65 /* write out matrix to file (precede by resolution string if picture) */
66 extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp);
67
68 /* Load and convert a matrix BTDF from the given XML file */
69 extern CMATRIX *cm_loadBTDF(const char *fname);
70
71 /* Load and convert a matrix BRDF from the given XML file */
72 extern CMATRIX *cm_loadBRDF(const char *fname, int backside);
73
74 #ifdef __cplusplus
75 }
76 #endif
77 #endif /* _RAD_CMATRIX_H_ */
