root/Development/ray/src/util/cmatrix.h
Revision: 2.16
Committed: Sat Apr 19 17:12:59 2025 UTC (8 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.15: +2 -1 lines
refactor: Isolated RMATRIX<->CMATRIX conversion routines
# User Rev Content
1 greg 2.16 /* RCSid $Id: cmatrix.h,v 2.15 2025/04/04 18:06:48 greg Exp $ */
2 greg 2.1 /*
3     * Color matrix routine declarations.
4     *
5     * G. Ward
6     */
7
8     #ifndef _RAD_CMATRIX_H_
9     #define _RAD_CMATRIX_H_
10
11 greg 2.8 #include <sys/types.h>
12 greg 2.1 #include "color.h"
13
14     #ifdef __cplusplus
15     extern "C" {
16     #endif
17
18 greg 2.15 /* Data types for file loading (used to be an enum) */
19     #define DTfromHeader 0
20     #define DTrgbe 1
21     #define DTxyze 2
22     #define DTspec 3
23     #define DTfloat 4
24     #define DTascii 5
25     #define DTdouble 6
26     #define DTend 7
27 greg 2.4
28 greg 2.16 /* Defined in cmconst.c */
29 greg 2.13 extern const char stdin_name[];
30 greg 2.4 extern const char *cm_fmt_id[];
31     extern const int cm_elem_size[];
32 greg 2.1
33     /* A color coefficient matrix -- vectors have ncols==1 */
34     typedef struct {
35     int nrows, ncols;
36     COLORV cmem[3]; /* extends struct */
37     } CMATRIX;
38
39     #define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf")
40
41 greg 2.8 #define cm_lval(cm,r,c) ((cm)->cmem + 3*((size_t)(r)*(cm)->ncols + (c)))
42 greg 2.1
43     #define cv_lval(cm,i) ((cm)->cmem + 3*(i))
44
45     /* Allocate a color coefficient matrix */
46 greg 2.5 extern CMATRIX *cm_alloc(int nrows, int ncols);
47 greg 2.1
48     /* Resize color coefficient matrix */
49 greg 2.5 extern CMATRIX *cm_resize(CMATRIX *cm, int nrows);
50 greg 2.1
51     #define cm_free(cm) free(cm)
52
53 greg 2.5 /* Load header to obtain/check data type and matrix dimensions */
54 greg 2.12 extern char *cm_getheader(int *dt, int *nr, int *nc,
55     int *swp, COLOR scale, FILE *fp);
56 greg 2.1
57 greg 2.7 /* Allocate and load a matrix from the given input (or stdin if NULL) */
58     extern CMATRIX *cm_load(const char *inspec, int nrows, int ncols, int dtype);
59 greg 2.1
60     /* Extract a column vector from a matrix */
61 greg 2.5 extern CMATRIX *cm_column(const CMATRIX *cm, int c);
62 greg 2.1
63     /* Multiply two matrices (or a matrix and a vector) and allocate the result */
64 greg 2.5 extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2);
65 greg 2.1
66 greg 2.4 /* write out matrix to file (precede by resolution string if picture) */
67 greg 2.5 extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp);
68 greg 2.1
69 greg 2.3 /* Load and convert a matrix BTDF from the given XML file */
70 greg 2.13 extern CMATRIX *cm_loadBTDF(const char *fname);
71
72     /* Load and convert a matrix BRDF from the given XML file */
73     extern CMATRIX *cm_loadBRDF(const char *fname, int backside);
74 greg 2.1
75     #ifdef __cplusplus
76     }
77     #endif
78     #endif /* _RAD_CMATRIX_H_ */
