root/radiance/ray/src/util/cmatrix.h
Revision: 2.16
Committed: Sat Apr 19 17:12:59 2025 UTC (3 weeks ago) by greg
Changes since 2.15: +2 -1 lines
refactor: Isolated RMATRIX<->CMATRIX conversion routines
1 /* RCSid $Id: cmatrix.h,v 2.15 2025/04/04 18:06:48 greg Exp $ */
2 /*
3 * Color matrix routine declarations.
4 *
5 * G. Ward
6 */
7
8 #ifndef _RAD_CMATRIX_H_
9 #define _RAD_CMATRIX_H_
10
11 #include <sys/types.h>
12 #include "color.h"
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 /* Data types for file loading (used to be an enum) */
19 #define DTfromHeader 0
20 #define DTrgbe 1
21 #define DTxyze 2
22 #define DTspec 3
23 #define DTfloat 4
24 #define DTascii 5
25 #define DTdouble 6
26 #define DTend 7
27
28 /* Defined in cmconst.c */
29 extern const char stdin_name[];
30 extern const char *cm_fmt_id[];
31 extern const int cm_elem_size[];
32
33 /* A color coefficient matrix -- vectors have ncols==1 */
34 typedef struct {
35 int nrows, ncols;
36 COLORV cmem[3]; /* extends struct */
37 } CMATRIX;
38
39 #define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf")
40
41 #define cm_lval(cm,r,c) ((cm)->cmem + 3*((size_t)(r)*(cm)->ncols + (c)))
42
43 #define cv_lval(cm,i) ((cm)->cmem + 3*(i))
44
45 /* Allocate a color coefficient matrix */
46 extern CMATRIX *cm_alloc(int nrows, int ncols);
47
48 /* Resize color coefficient matrix */
49 extern CMATRIX *cm_resize(CMATRIX *cm, int nrows);
50
51 #define cm_free(cm) free(cm)
52
53 /* Load header to obtain/check data type and matrix dimensions */
54 extern char *cm_getheader(int *dt, int *nr, int *nc,
55 int *swp, COLOR scale, FILE *fp);
56
57 /* Allocate and load a matrix from the given input (or stdin if NULL) */
58 extern CMATRIX *cm_load(const char *inspec, int nrows, int ncols, int dtype);
59
60 /* Extract a column vector from a matrix */
61 extern CMATRIX *cm_column(const CMATRIX *cm, int c);
62
63 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
64 extern CMATRIX *cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2);
65
66 /* write out matrix to file (precede by resolution string if picture) */
67 extern int cm_write(const CMATRIX *cm, int dtype, FILE *fp);
68
69 /* Load and convert a matrix BTDF from the given XML file */
70 extern CMATRIX *cm_loadBTDF(const char *fname);
71
72 /* Load and convert a matrix BRDF from the given XML file */
73 extern CMATRIX *cm_loadBRDF(const char *fname, int backside);
74
75 #ifdef __cplusplus
76 }
77 #endif
78 #endif /* _RAD_CMATRIX_H_ */
