root/radiance/ray/src/util/cmatrix.h
Sat Apr 19 17:12:59 2025 UTC (13 days, 9 hours ago) by greg
Changes since 2.15: +2 -1 lines
Diff to previous 2.15 , to selected 2.13
refactor: Isolated RMATRIX<->CMATRIX conversion routines
Fri Apr 4 18:06:48 2025 UTC (4 weeks ago) by greg
Changes since 2.14: +10 -3 lines
Tue Nov 21 01:30:20 2023 UTC (17 months, 1 week ago) by greg
Diff to previous 2.13
Revision 2.13 - (view) (download) (annotate) - [selected]
Tue Jan 19 23:32:00 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.12: +6 -2 lines
Diff to previous 2.12
Wed Mar 25 01:51:09 2020 UTC (5 years, 1 month ago) by greg
Thu Nov 7 23:10:18 2019 UTC (5 years, 5 months ago) by greg
Fixed priority of output formats
Wed Aug 14 18:20:02 2019 UTC (5 years, 8 months ago) by greg
Mon Aug 12 18:28:37 2019 UTC (5 years, 8 months ago) by greg
Changes since 2.8: +1 -4 lines
Made error checking more consistent and eliminated unused function call
Wed Oct 31 22:19:57 2018 UTC (6 years, 6 months ago) by greg
Fix potential issues on very large matrices (> 2GB)
Mon May 4 20:53:21 2015 UTC (10 years ago) by greg
Sat Aug 2 17:10:43 2014 UTC (10 years, 9 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Fri May 30 00:00:54 2014 UTC (10 years, 11 months ago) by greg
CVS Tags: rad4R2
Changes since 2.4: +12 -12 lines
Sat Feb 8 01:28:06 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.3: +7 -4 lines
Mon Jan 20 22:18:29 2014 UTC (11 years, 3 months ago) by greg
Fixed improper handling of diffuse transmission matrix
Mon Jan 20 21:30:34 2014 UTC (11 years, 3 months ago) by greg
Added missing (and unnecessary) "extern" in declaration
Mon Jan 20 21:29:04 2014 UTC (11 years, 3 months ago) by greg
Diff to selected 2.13
