root/Development/ray/src/util/cmatrix.c
Revision: 2.41
Committed: Sat Apr 19 17:12:59 2025 UTC (8 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.40: +1 -12 lines
refactor: Isolated RMATRIX<->CMATRIX conversion routines
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.40 2025/03/22 01:27:22 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "resolu.h"
17
18 /* Allocate a color coefficient matrix */
19 CMATRIX *
20 cm_alloc(int nrows, int ncols)
21 {
22 CMATRIX *cm;
23
24 if ((nrows <= 0) | (ncols <= 0))
25 error(USER, "attempt to create empty matrix");
26 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
27 sizeof(COLOR)*((size_t)nrows*ncols - 1));
28 if (!cm)
29 error(SYSTEM, "out of memory in cm_alloc()");
30 cm->nrows = nrows;
31 cm->ncols = ncols;
32 return(cm);
33 }
34
35 static void
36 adjacent_ra_sizes(size_t bounds[2], size_t target)
37 {
38 bounds[0] = 0; bounds[1] = 2048;
39 while (bounds[1] < target) {
40 bounds[0] = bounds[1];
41 bounds[1] += bounds[1]>>1;
42 }
43 }
44
45 /* Resize color coefficient matrix */
46 CMATRIX *
47 cm_resize(CMATRIX *cm, int nrows)
48 {
49 size_t old_size, new_size, ra_bounds[2];
50
51 if (!cm)
52 return(NULL);
53 if (nrows == cm->nrows)
54 return(cm);
55 if (nrows <= 0) {
56 cm_free(cm);
57 return(NULL);
58 }
59 old_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)cm->nrows*cm->ncols - 1);
60 adjacent_ra_sizes(ra_bounds, old_size);
61 new_size = sizeof(CMATRIX) + sizeof(COLOR)*((size_t)nrows*cm->ncols - 1);
62 if (nrows < cm->nrows ? new_size <= ra_bounds[0] :
63 new_size > ra_bounds[1]) {
64 adjacent_ra_sizes(ra_bounds, new_size);
65 cm = (CMATRIX *)realloc(cm, ra_bounds[1]);
66 if (!cm)
67 error(SYSTEM, "out of memory in cm_resize()");
68 }
69 cm->nrows = nrows;
70 return(cm);
71 }
72
73 typedef struct {
74 int dtype; /* data type */
75 int need2swap; /* need byte swap? */
76 int nrows, ncols; /* matrix size */
77 COLOR expos; /* exposure value */
78 char *err; /* error message */
79 } CMINFO; /* header info record */
80
81 static int
82 get_cminfo(char *s, void *p)
83 {
84 CMINFO *ip = (CMINFO *)p;
85 char fmt[MAXFMTLEN];
86 int i;
87
88 if (isncomp(s) && ncompval(s) != 3) {
89 ip->err = "unexpected # components (must be 3)";
90 return(-1);
91 }
92 if (!strncmp(s, "NROWS=", 6)) {
93 ip->nrows = atoi(s+6);
94 return(0);
95 }
96 if (!strncmp(s, "NCOLS=", 6)) {
97 ip->ncols = atoi(s+6);
98 return(0);
99 }
100 if ((i = isbigendian(s)) >= 0) {
101 ip->need2swap = (nativebigendian() != i);
102 return(0);
103 }
104 if (isexpos(s)) {
105 double d = exposval(s);
106 scalecolor(ip->expos, d);
107 return(0);
108 }
109 if (iscolcor(s)) {
110 COLOR ctmp;
111 colcorval(ctmp, s);
112 multcolor(ip->expos, ctmp);
113 return(0);
114 }
115 if (!formatval(fmt, s))
116 return(0);
117 for (i = 1; i < DTend; i++)
118 if (!strcmp(fmt, cm_fmt_id[i]))
119 ip->dtype = i;
120 return(0);
121 }
122
123 /* Load header to obtain/check data type and number of columns */
124 char *
125 cm_getheader(int *dt, int *nr, int *nc, int *swp, COLOR scale, FILE *fp)
126 {
127 CMINFO cmi;
128 /* read header */
129 cmi.dtype = DTfromHeader;
130 cmi.need2swap = 0;
131 cmi.expos[0] = cmi.expos[1] = cmi.expos[2] = 1.f;
132 cmi.nrows = cmi.ncols = 0;
133 cmi.err = "unexpected EOF in header";
134 if (getheader(fp, get_cminfo, &cmi) < 0)
135 return(cmi.err);
136 if (dt) { /* get/check data type? */
137 if (cmi.dtype == DTfromHeader) {
138 if (*dt == DTfromHeader)
139 return("missing/unknown data format in header");
140 } else if (*dt == DTfromHeader)
141 *dt = cmi.dtype;
142 else if (*dt != cmi.dtype)
143 return("unexpected data format in header");
144 }
145 if (nr) { /* get/check #rows? */
146 if (*nr <= 0)
147 *nr = cmi.nrows;
148 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
149 return("unexpected row count in header");
150 }
151 if (nc) { /* get/check #columns? */
152 if (*nc <= 0)
153 *nc = cmi.ncols;
154 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
155 return("unexpected column count in header");
156 }
157 if (swp) /* get/check swap? */
158 *swp = cmi.need2swap;
159 if (scale) { /* transfer exposure comp. */
160 scale[0] = 1.f/cmi.expos[0];
161 scale[1] = 1.f/cmi.expos[1];
162 scale[2] = 1.f/cmi.expos[2];
163 }
164 return(NULL);
165 }
166
167 /* Allocate and load image data into matrix */
168 static CMATRIX *
169 cm_load_rgbe(FILE *fp, int nrows, int ncols)
170 {
171 CMATRIX *cm;
172 COLORV *mp;
173 /* header already loaded */
174 cm = cm_alloc(nrows, ncols);
175 if (!cm)
176 return(NULL);
177 mp = cm->cmem;
178 while (nrows--) {
179 if (freadscan((COLOR *)mp, ncols, fp) < 0) {
180 error(USER, "error reading color picture as matrix");
181 cm_free(cm);
182 return(NULL);
183 }
184 mp += 3*ncols;
185 } /* caller closes stream */
186 return(cm);
187 }
188
189 /* Allocate and load a matrix from the given input (or stdin if NULL) */
190 CMATRIX *
191 cm_load(const char *inspec, int nrows, int ncols, int dtype)
192 {
193 const int ROWINC = 2048;
194 int dimsOK = (dtype == DTascii) | (nrows > 0) && ncols;
195 int swap = 0;
196 FILE *fp;
197 COLOR scale;
198 CMATRIX *cm;
199
200 if (!inspec)
201 inspec = stdin_name;
202 else if (!*inspec)
203 return(NULL);
204 if (inspec == stdin_name) { /* reading from stdin? */
205 fp = stdin;
206 } else if (inspec[0] == '!') {
207 fp = popen(inspec+1, "r");
208 if (!fp) {
209 sprintf(errmsg, "cannot start command '%s'", inspec);
210 error(SYSTEM, errmsg);
211 }
212 } else if (!(fp = fopen(inspec, "r"))) {
213 sprintf(errmsg, "cannot open file '%s'", inspec);
214 error(SYSTEM, errmsg);
215 }
216 #ifdef getc_unlocked
217 flockfile(fp);
218 #endif
219 if (dtype != DTascii)
220 SET_FILE_BINARY(fp); /* doesn't really work */
221 if (!dtype | !dimsOK) { /* expecting header? */
222 char *err = cm_getheader(&dtype, &nrows, &ncols, &swap, scale, fp);
223 if (err)
224 error(USER, err);
225 dimsOK = ncols > 0 && ( nrows > 0 ||
226 (dtype != DTrgbe) & (dtype != DTxyze) );
227 }
228 if (!dimsOK && !fscnresolu(&ncols, &nrows, fp))
229 error(USER, "unspecified matrix size");
230 switch (dtype) {
231 case DTascii:
232 case DTfloat:
233 case DTdouble:
234 break;
235 case DTrgbe:
236 case DTxyze:
237 cm = cm_load_rgbe(fp, nrows, ncols);
238 goto cleanup;
239 default:
240 error(USER, "unexpected data type in cm_load()");
241 }
242 if (nrows <= 0) { /* don't know length? */
243 int guessrows = 147; /* usually big enough */
244 if (cm_elem_size[dtype] && (fp != stdin) & (inspec[0] != '!')) {
245 long startpos = ftell(fp);
246 if (fseek(fp, 0L, SEEK_END) == 0) {
247 long rowsiz = (long)ncols*cm_elem_size[dtype];
248 long endpos = ftell(fp);
249
250 if ((endpos - startpos) % rowsiz) {
251 sprintf(errmsg,
252 "improper length for binary file '%s'",
253 inspec);
254 error(USER, errmsg);
255 }
256 guessrows = (endpos - startpos)/rowsiz;
257 if (fseek(fp, startpos, SEEK_SET) < 0) {
258 sprintf(errmsg,
259 "fseek() error on file '%s'",
260 inspec);
261 error(SYSTEM, errmsg);
262 }
263 nrows = guessrows; /* we're confident */
264 }
265 }
266 cm = cm_alloc(guessrows, ncols);
267 } else
268 cm = cm_alloc(nrows, ncols);
269 if (!cm) /* XXX never happens */
270 return(NULL);
271 if (dtype == DTascii) { /* read text file */
272 int maxrow = (nrows > 0 ? nrows : 32000);
273 int r, c;
274 for (r = 0; r < maxrow; r++) {
275 if (r >= cm->nrows) /* need more space? */
276 cm = cm_resize(cm, cm->nrows+ROWINC);
277 for (c = 0; c < ncols; c++) {
278 COLORV *cv = cm_lval(cm,r,c);
279 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) {
280 if ((nrows <= 0) & (r > 0) & !c) {
281 cm = cm_resize(cm, maxrow=r);
282 break;
283 } else
284 goto EOFerror;
285 }
286 }
287 }
288 while ((c = getc(fp)) != EOF)
289 if (!isspace(c)) {
290 sprintf(errmsg,
291 "unexpected data at end of ascii input '%s'",
292 inspec);
293 error(WARNING, errmsg);
294 break;
295 }
296 } else { /* read binary file */
297 if (sizeof(COLOR) == cm_elem_size[dtype]) {
298 size_t nread = 0;
299 do { /* read all we can */
300 nread += getbinary(cm->cmem + 3*nread,
301 sizeof(COLOR),
302 (size_t)cm->nrows*cm->ncols - nread,
303 fp);
304 if (nrows <= 0) { /* unknown length */
305 if (nread == (size_t)cm->nrows*cm->ncols)
306 /* need more space? */
307 cm = cm_resize(cm, cm->nrows+ROWINC);
308 else if (nread && !(nread % cm->ncols))
309 /* seem to be done */
310 cm = cm_resize(cm, nread/cm->ncols);
311 else /* ended mid-row */
312 goto EOFerror;
313 } else if (nread < (size_t)cm->nrows*cm->ncols)
314 goto EOFerror;
315 } while (nread < (size_t)cm->nrows*cm->ncols);
316
317 if (swap) {
318 if (sizeof(COLORV) == 4)
319 swap32((char *)cm->cmem,
320 3*(size_t)cm->nrows*cm->ncols);
321 else /* sizeof(COLORV) == 8 */
322 swap64((char *)cm->cmem,
323 3*(size_t)cm->nrows*cm->ncols);
324 }
325 } else if (dtype == DTdouble) {
326 double dc[3]; /* load from double */
327 COLORV *cvp = cm->cmem;
328 size_t n = (size_t)nrows*ncols;
329
330 if (n <= 0)
331 goto not_handled;
332 while (n--) {
333 if (getbinary(dc, sizeof(double), 3, fp) != 3)
334 goto EOFerror;
335 if (swap) swap64((char *)dc, 3);
336 copycolor(cvp, dc);
337 cvp += 3;
338 }
339 } else /* dtype == DTfloat */ {
340 float fc[3]; /* load from float */
341 COLORV *cvp = cm->cmem;
342 size_t n = (size_t)nrows*ncols;
343
344 if (n <= 0)
345 goto not_handled;
346 while (n--) {
347 if (getbinary(fc, sizeof(float), 3, fp) != 3)
348 goto EOFerror;
349 if (swap) swap32((char *)fc, 3);
350 copycolor(cvp, fc);
351 cvp += 3;
352 }
353 }
354 if (fgetc(fp) != EOF) {
355 sprintf(errmsg,
356 "unexpected data at end of binary input '%s'",
357 inspec);
358 error(WARNING, errmsg);
359 }
360 }
361 cleanup:
362 if (fp != stdin) {
363 if (inspec[0] != '!')
364 fclose(fp);
365 else if (pclose(fp)) {
366 sprintf(errmsg, "error running command '%s'", inspec);
367 error(WARNING, errmsg);
368 }
369 }
370 #ifdef getc_unlocked
371 else
372 funlockfile(fp);
373 #endif
374 if ((scale[0] < .99) | (scale[0] > 1.01) |
375 (scale[1] < .99) | (scale[1] > 1.01) |
376 (scale[2] < .99) | (scale[2] > 1.01)) {
377 size_t n = (size_t)ncols*nrows;
378 COLORV *mp = cm->cmem;
379 while (n--) { /* apply exposure scaling */
380 *mp++ *= scale[0];
381 *mp++ *= scale[1];
382 *mp++ *= scale[2];
383 }
384 }
385 return(cm);
386 EOFerror:
387 sprintf(errmsg, "unexpected EOF reading %s", inspec);
388 error(USER, errmsg);
389 return(NULL);
390 not_handled:
391 error(INTERNAL, "unhandled data size or length in cm_load()");
392 return(NULL); /* gratis return */
393 }
394
395 /* Extract a column vector from a matrix */
396 CMATRIX *
397 cm_column(const CMATRIX *cm, int c)
398 {
399 CMATRIX *cvr;
400 int dr;
401
402 if (!cm)
403 return(NULL);
404 if ((c < 0) | (c >= cm->ncols))
405 error(INTERNAL, "column requested outside matrix");
406 cvr = cm_alloc(cm->nrows, 1);
407 if (!cvr)
408 return(NULL);
409 for (dr = 0; dr < cm->nrows; dr++) {
410 const COLORV *sp = cm_lval(cm,dr,c);
411 COLORV *dp = cv_lval(cvr,dr);
412 dp[0] = sp[0];
413 dp[1] = sp[1];
414 dp[2] = sp[2];
415 }
416 return(cvr);
417 }
418
419 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
420 CMATRIX *
421 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
422 {
423 char *rowcheck=NULL, *colcheck=NULL;
424 CMATRIX *cmr;
425 int dr, dc, i;
426
427 if (!cm1 | !cm2)
428 return(NULL);
429 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
430 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
431 cmr = cm_alloc(cm1->nrows, cm2->ncols);
432 if (!cmr)
433 return(NULL);
434 /* optimization: check for zero rows & cols */
435 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
436 static const COLOR czero;
437 rowcheck = (char *)calloc(cmr->nrows, 1);
438 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
439 for (dc = cm1->ncols; dc--; )
440 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
441 rowcheck[dr] = 1;
442 break;
443 }
444 colcheck = (char *)calloc(cmr->ncols, 1);
445 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
446 for (dr = cm2->nrows; dr--; )
447 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
448 colcheck[dc] = 1;
449 break;
450 }
451 }
452 for (dr = 0; dr < cmr->nrows; dr++)
453 for (dc = 0; dc < cmr->ncols; dc++) {
454 COLORV *dp = cm_lval(cmr,dr,dc);
455 double res[3];
456 dp[0] = dp[1] = dp[2] = 0;
457 if (rowcheck && !rowcheck[dr])
458 continue;
459 if (colcheck && !colcheck[dc])
460 continue;
461 res[0] = res[1] = res[2] = 0;
462 for (i = 0; i < cm1->ncols; i++) {
463 const COLORV *cp1 = cm_lval(cm1,dr,i);
464 const COLORV *cp2 = cm_lval(cm2,i,dc);
465 res[0] += (double)cp1[0] * cp2[0];
466 res[1] += (double)cp1[1] * cp2[1];
467 res[2] += (double)cp1[2] * cp2[2];
468 }
469 copycolor(dp, res);
470 }
471 if (rowcheck) free(rowcheck);
472 if (colcheck) free(colcheck);
473 return(cmr);
474 }
475
476 /* write out matrix to file (precede by resolution string if picture) */
477 int
478 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
479 {
480 static const char tabEOL[2] = {'\t','\n'};
481 const COLORV *mp;
482 int r, c;
483 size_t n, rv;
484
485 if (!cm)
486 return(0);
487 #ifdef getc_unlocked
488 flockfile(fp);
489 #endif
490 mp = cm->cmem;
491 switch (dtype) {
492 case DTascii:
493 for (r = 0; r < cm->nrows; r++)
494 for (c = 0; c < cm->ncols; c++, mp += 3)
495 fprintf(fp, "%.6e %.6e %.6e%c",
496 mp[0], mp[1], mp[2],
497 tabEOL[c >= cm->ncols-1]);
498 break;
499 case DTfloat:
500 case DTdouble:
501 if (sizeof(COLOR) == cm_elem_size[dtype]) {
502 n = (size_t)cm->ncols*cm->nrows;
503 while (n > 0) {
504 rv = fwrite(mp, sizeof(COLOR), n, fp);
505 if (rv <= 0)
506 return(0);
507 mp += 3*rv;
508 n -= rv;
509 }
510 } else if (dtype == DTdouble) {
511 double dc[3];
512 n = (size_t)cm->ncols*cm->nrows;
513 while (n--) {
514 copycolor(dc, mp);
515 if (putbinary(dc, sizeof(double), 3, fp) != 3)
516 return(0);
517 mp += 3;
518 }
519 } else /* dtype == DTfloat */ {
520 float fc[3];
521 n = (size_t)cm->ncols*cm->nrows;
522 while (n--) {
523 copycolor(fc, mp);
524 if (putbinary(fc, sizeof(float), 3, fp) != 3)
525 return(0);
526 mp += 3;
527 }
528 }
529 break;
530 case DTrgbe:
531 case DTxyze:
532 fprtresolu(cm->ncols, cm->nrows, fp);
533 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
534 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
535 return(0);
536 break;
537 default:
538 fputs("Unsupported data type in cm_write()!\n", stderr);
539 return(0);
540 }
541 #ifdef getc_unlocked
542 funlockfile(fp);
543 #endif
544 return(fflush(fp) == 0);
545 }
